Error burnind ISO 4.15GB
korazet
Post by korazet »
hello
I am trying to burn an ISO image which is 4.15GB of size but i always end up with errors!
I'm using Berbatim DVD-R, bought specially as you guys have said that they are one of the best media quality :)
I tried burning on 1 PC and 1 Laptop and both failed.
This is the PC Log:
Before Firmware update:
Code: Select all
2010-09-28 13:02:06    ----            ******************** Log session stop  28-Sep 13:02:06.140 PID 1748********************
2010-09-28 13:00:29    Info            Writing completed in 05:59
2010-09-28 13:00:23    Info            Finalize started
2010-09-28 13:00:23    Error           Write error at 1856 (16) - Code 05 21 00 [Illegal request, LBA out of range]
2010-09-28 13:00:23    Warning         at sector 1856 (16) - recover sequence started
2010-09-28 13:00:23    Warning         Write error - Code 03 0C 00 [Write error] - Info 0 - CSI 0
2010-09-28 13:00:23    Info            Try #0 - duration 28906799 µs
2010-09-28 12:55:24    Info            Lead-in burning time (mS) 54222
2010-09-28 12:54:29    Info            Write started
2010-09-28 12:54:29    Info            Buffer Under-run protection is enabled
2010-09-28 12:54:29    Info            Writing speed requested x4.0, effective x4.0
2010-09-28 12:54:29    Info            Media ID : MCC 03RG20
2010-09-28 12:54:29    Info            Writing DVD-ROM Disc [] - Image Size 4.15 Gb.
2010-09-28 12:54:29    Info            Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
2010-09-28 12:54:29    Info            Using : 0:0:0 - TSSTcorp CD/DVDW SH-W162C TS10 [D] (Ide)
2010-09-28 12:39:31    Info            Imported file format - ISO@2048 (DVD ISO)
2010-09-28 12:39:24    Info            Loaded write profile ISO image
2010-09-28 12:39:02    Info            Using Advanced SPTI interface
2010-09-28 12:38:02    Info            Paramstr #00 : "C:\PROGRA~1\VSO\BLINDW~1\bw.exe"
2010-09-28 12:38:02    Info            System default language : English (United States)
2010-09-28 12:38:02    Info            User default language   : English (United States)
2010-09-28 12:38:02    Info            Version : 6.3.1.6
2010-09-28 12:38:02    Info            ExeName : C:\PROGRA~1\VSO\BLINDW~1\bw.exe
2010-09-28 12:38:02    Info            OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-09-28 12:38:01    ----            ******************** Log session start 28-Sep 12:38:01.656 PID 1748********************
2010-09-28 08:08:25    ----            ******************** Log session stop  28-Sep 08:08:25.120 PID 2536********************
2010-09-28 08:08:07    Info            Writing completed in 06:07
2010-09-28 08:08:00    Info            Finalize started
2010-09-28 08:07:59    Error           Write error at 14336 (16) - Code 05 21 00 [Illegal request, LBA out of range]
2010-09-28 08:07:49    Warning         Stop write requested
2010-09-28 08:03:32    Info            Lead-in burning time (mS) 92172
2010-09-28 08:02:00    Info            Write started
2010-09-28 08:02:00    Info            Buffer Under-run protection is enabled
2010-09-28 08:02:00    Info            Writing speed requested x4.0, effective x4.0
2010-09-28 08:01:59    Info            Media ID : PRINCORGM1
2010-09-28 08:01:59    Info            Writing DVD-ROM Disc [] - Image Size 4.15 Gb.
2010-09-28 08:01:59    Info            Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
2010-09-28 08:01:59    Info            Using : 0:0:0 - TSSTcorp CD/DVDW SH-W162C TS10 [D] (Ide)
2010-09-28 07:58:03    Info            Imported file format - ISO@2048 (DVD ISO)
2010-09-28 07:53:56    Info            Loaded write profile ISO image
2010-09-28 07:35:54    Info            Loaded copy profile Audio CD
2010-09-28 07:35:41    Info            Using Advanced SPTI interface
2010-09-28 07:35:41    Info            Paramstr #00 : "C:\PROGRA~1\VSO\BLINDW~1\bw.exe"
2010-09-28 07:35:41    Info            System default language : English (United States)
2010-09-28 07:35:41    Info            User default language   : English (United States)
2010-09-28 07:35:41    Info            Version : 6.3.1.6
2010-09-28 07:35:41    Info            ExeName : C:\PROGRA~1\VSO\BLINDW~1\bw.exe
2010-09-28 07:35:41    Info            OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-09-28 07:35:40    ----            ******************** Log session start 28-Sep 07:35:40.525 PID 2536********************
After Firmware update:
Code: Select all
2010-09-28 13:17:16	Info        	Writing completed in 06:28
2010-09-28 13:17:02	Info        	Finalize started
2010-09-28 13:17:02	Error       	Write error at 0 (16) - Code 06 29 00 [Unit attention, Power On or Bus device reset occured]
2010-09-28 13:10:48	Info        	Write started
2010-09-28 13:10:48	Info        	Buffer Under-run protection is enabled
2010-09-28 13:10:48	Info        	Writing speed requested x8.0, effective x8.0
2010-09-28 13:10:48	Info        	Media ID : MCC 03RG20
2010-09-28 13:10:48	Info        	Writing DVD-ROM Disc [] - Image Size 4.15 Gb.
2010-09-28 13:10:48	Info        	Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
2010-09-28 13:10:48	Info        	Using : 0:0:0 - TSSTcorp CD/DVDW SH-W162C TS12 [D] (Ide)
2010-09-28 13:10:40	Info        	Loaded write profile ISO image
2010-09-28 13:10:38	Info        	Imported file format - ISO@2048 (DVD ISO)
2010-09-28 13:10:05	Info        	Using Advanced SPTI interface
2010-09-28 13:10:05	Info        	Paramstr #00 : "C:\PROGRA~1\VSO\BLINDW~1\bw.exe"
2010-09-28 13:10:05	Info        	System default language : English (United States)
2010-09-28 13:10:05	Info        	User default language   : English (United States)
2010-09-28 13:10:05	Info        	Version : 6.3.1.6
2010-09-28 13:10:05	Info        	ExeName : C:\PROGRA~1\VSO\BLINDW~1\bw.exe
2010-09-28 13:10:05	Info        	OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-09-28 13:10:03	----        	******************** Log session start 28-Sep 13:10:03.671 PID 2044********************
On the Laptop:
Code: Select all
2010-09-28 11:37:36    Info            Finalize started
2010-09-28 11:37:36    Error           Write error recovery failed at 16 (16) - Code 03 0C 00 [Write error]
2010-09-28 11:37:36    Info            Try #2532 - duration 372411 µs
2010-09-28 11:35:33    Info            Lead-in burning time (mS) 244725
2010-09-28 11:31:27    Info            Write started
2010-09-28 11:31:27    Info            Buffer Under-run protection is enabled
2010-09-28 11:31:27    Info            Writing speed requested x4.0, effective x4.0
2010-09-28 11:31:27    Info            Media ID : MCC 03RG20
2010-09-28 11:31:27    Info            Writing DVD-ROM Disc [] - Image Size 4.15 Gb.
2010-09-28 11:31:27    Info            Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-09-28 11:31:24    Info            Using : 0:1:0 - Slimtype DVDRW SSW-8015S HRS2 [E] (Ide)
2010-09-28 11:30:57    Info            Loaded write profile ISO image
2010-09-28 11:30:56    Info            Imported file format - ISO@2048 (DVD ISO)
2010-09-28 11:30:51    Info            Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2010-09-28 11:30:51    Info            Paramstr #00 : "C:\PROGRA~1\VSO\BLINDW~1\bw.exe"
2010-09-28 11:30:51    Info            System default language : English (United States)
2010-09-28 11:30:51    Info            User default language   : English (United States)
2010-09-28 11:30:51    Info            Version : 6.3.1.6
2010-09-28 11:30:51    Info            ExeName : C:\PROGRA~1\VSO\BLINDW~1\bw.exe
2010-09-28 11:30:51    Info            OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-09-28 11:30:48    ----            ******************** Log session start 28-Sep 11:30:48.953 PID 2320********************
2010-09-28 11:24:17    ----            ******************** Log session stop  28-Sep 11:24:17.109 PID 1228********************
2010-09-28 11:20:31    Info            Writing completed in 02:12
2010-09-28 11:20:23    Info            Finalize started
2010-09-28 11:20:23    Error           Write error at 0 (16) - Code 03 73 03 [Medium error, Power calibration fail (CD-burner is dirty)]
2010-09-28 11:18:18    Info            Write started
2010-09-28 11:18:18    Info            Buffer Under-run protection is enabled
2010-09-28 11:18:18    Info            Writing speed requested x4.0, effective x4.0
2010-09-28 11:18:18    Info            Media ID : MCC 03RG20
2010-09-28 11:18:18    Info            Writing DVD-ROM Disc [] - Image Size 4.15 Gb.
2010-09-28 11:18:18    Info            Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-09-28 11:18:18    Info            Using : 0:1:0 - Slimtype DVDRW SSW-8015S HRS2 [E] (Ide)
2010-09-28 11:18:14    Info            Imported file format - ISO@2048 (DVD ISO)
2010-09-28 11:18:12    Info            Loaded write profile ISO image
2010-09-28 11:18:09    Info            Loaded write profile Audio CD
2010-09-28 11:18:02    Info            Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2010-09-28 11:17:41    Info            Paramstr #00 : "C:\PROGRA~1\VSO\BLINDW~1\bw.exe"
2010-09-28 11:17:41    Info            System default language : English (United States)
2010-09-28 11:17:41    Info            User default language   : English (United States)
2010-09-28 11:17:41    Info            Version : 6.3.1.6
2010-09-28 11:17:41    Info            ExeName : C:\PROGRA~1\VSO\BLINDW~1\bw.exe
2010-09-28 11:17:41    Info            OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-09-28 11:17:39    ----            ******************** Log session start 28-Sep 11:17:39.500 PID 1228********************
please help me in sorting this problem, thank you :)
korazet
Post by korazet »
update:
i just extracted the iso file and burned the file inside of it using CopytoDVD on my PC.
and it worked.. but i still need to burn the ISO.
thanks for helping
you need to burn with Blindwrite on your laptop? Is that where you are stuck now?
Can you do it with ImgBurn?
