not sure how to use EZ-PLAY
ell132
Post by ell132 » Mon Aug 23, 2010 6:55 pm
i am having trouble using the disk i have burned. i have burned battle fro middle earth 2, and when i go to use it says that i must insert the correct cd to play then it exits.
I heard of EZ-Play and i have it and it doesn't look like it does anything can someoine help me use it because i'm not sure how to use it ?
thank
Phil
Post by Phil » Tue Aug 24, 2010 2:19 pm
Check that your disc has been tagged for EZ-Play while burning (Help > Open Log), and that EZ-Play is installed and active on your system (Start > Programs > VSO > Blindwrite > EZ Play Manager).
If everything is set, then EZ-Play might not be compatible with the protection on disc.
ell132
Post by ell132 » Tue Aug 24, 2010 4:32 pm
Thank you i have done everything and the log says "EZ-Play driver active. Version 8," and then i popped in the disc i created and still the same message
"please insert correct Cd" oh well it must be the game then thanks anyway..
is there anything else i could do in this situation like software or something?
Post by Cougar_II » Tue Aug 24, 2010 11:36 pm
As Phil mentioned, it totally depends on the protection on the disk.
There are so many protections these days, and real hard one to crack/emulate.
I forget the name but there is a Scanner out there that could scan your original disk and identify which protection is on there.
Most likely Blindwrite cannot reproduce/emulate this hard protection.
There we go, A-Ray Scanner v2.0.2.3
http://www.softpedia.com/get/CD-DVD-Too ... nner.shtml
Run this and tell us what protection is identified.
ell132
Post by ell132 » Wed Aug 25, 2010 1:57 am
thanks for the reply
I scanned the disk and found it was a safedisk 2/3 is that a harder one to copy than most ?
