Rip with 'remux if possible' doesn't work with Atmos/TrueHD
dosibo51
Post by dosibo51 »
I've ripped 2 BRs with my preferred .m2ts profile settings (as usual, remux if possible) with BR Converter 4.x (acutal versions in May & August 2016) but finally have no audio when I play it back with VSO, VLC, JRiver MC.
After ripping the film I've checked the result and noticed the (not-playing) audio and ripped it with AC-3 (ok).
Does this mean I would have to check each BR manually before ripping it and remove the "remux if possible" setting from my profile (for these discs) or will there be any other future solution in BR Converter (support Atmos/TrueHD or not remuxing?)?
The "bad" results also don't play on my PC nor on my Linux-Receiver (at the moment) (and I'm not sure the audio-ripping part would be really ok).
Solution?
Film a:
Code: Select all
General
Complete name                            : a.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 40.1 GiB
Overall bit rate mode                    : Variable
Overall bit rate                         : 31.4 Mb/s
Maximum Overall bit rate                 : 48.0 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=10
Codec ID                                 : 27
Duration                                 : 3 h 2 min
Bit rate mode                            : Variable
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : Atmos / TrueHD
Codec ID                                 : 131
Maximum bit rate                         : 8 046 kb/s
Channel(s)                               : Object Based / 8 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            :  / 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 spf)
Language                                 : German
Audio #2
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Delay relative to video                  : 2 s 26 ms
Language                                 : German
Film b:
Code: Select all
General
Complete name                            : b.m2ts
Format                                   : BDAV
File size                                : 25.0 GiB
Overall bit rate                         : 32.1 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Codec ID                                 : 27
Duration                                 : 1 h 51 min
Color space                              : YUV
Bit depth                                : 8 bits
Audio #1
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Maximum bit rate                         : 8 283 kb/s
Language                                 : German
Audio #2
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Delay relative to video                  : 4 s 53 ms
Language                                 : German
Profile:
Code: Select all
<?xml version="1.0" encoding="Windows-1252" standalone="no"?>
<Configuration>
  <VSO_custom_profile>
    <Description/>
    <DefaultFileExtension>m2ts</DefaultFileExtension>
    <ContextName>Film BR (M2TS-R+H264-R+DTS)</ContextName>
    <VideoProfile>
      <Item0>codec=h264</Item0>
      <Item1>remuxifpossible=1</Item1>
      <Item2>width=1920</Item2>
      <Item3>height=1080</Item3>
      <Item4>h264_profile=high</Item4>
      <Item5>h264_level=4.1</Item5>
      <Item6>qmin=2</Item6>
      <Item7>qmax=31</Item7>
      <Item8>qdiff=3</Item8>
      <Item9>me_method=hex</Item9>
      <Item10>subq=6</Item10>
      <Item11>me_range=16</Item11>
      <Item12>refs=3</Item12>
      <Item13>bf=3</Item13>
      <Item14>coder=1</Item14>
      <Item15>trellis=0</Item15>
      <Item16>b_strategy=1</Item16>
      <Count>17</Count>
    </VideoProfile>
    <AudioProfile>
      <Item0>codec=dts</Item0>
      <Count>2</Count>
    </AudioProfile>
    <SubtitleProfile>
      <Item0>codec=hdmv_pgs_subtitle</Item0>
      <Count>2</Count>
    </SubtitleProfile>
    <ImageIndex>18</ImageIndex>
    <TemplateName>Custom profiles</TemplateName>
    <editor_link>FALSE</editor_link>
    <OutputFolder>L:\Filme</OutputFolder>
    <Container>Sm_M2Ts</Container>
  </VSO_custom_profile>
</Configuration>
Re: Rip with 'remux if possible' doesn't work with Atmos/Tru
As a test and you do a MKV FULL remux and see if the audio plays on that output?
(You can make a cut, so that only a short part is converted)
Post your custom profile here.
dosibo51
Post by dosibo51 »
Hi Claire,
I've returned the BRs in the meantime and currently I don't have one for testing. Sorry.
But I will order a few BRs today or tomorrow. Hopefully an Atmos/TrueHD BR is included.
