Single HD File
create AVCHD stucture
eon_designs
Single HD File
Post by eon_designs » Wed Jan 26, 2011 10:43 am
Hello
I have just been looking at your AVCHD Editor.
In the Action menu there is another selection called "Select Output Format" - in this there are 3 options: AVCHD, Single HD File and HD Web Project. Only one of these is currently selectable - AVCHD.
How do you select / enable the output to a single HD file?
Many thanks. eon.
felicia
Post by felicia » Wed Jan 26, 2011 11:06 am
Frst of all thx for your feedback.
AVCHD Editor is still at the moment in a work in progress state, so not all features are implemented.
If you want to convert your HD structure to a sngle file I can recommend you VSO Blu-Ray Converters - it also works with AVCHD, the ultimate version is still at a Beta stage but has lots of different outputs.
BR,
Felicià
