not on screen
create AVCHD stucture
bagio
not on screen
Post by bagio »
the software wont show on screen.
when i start it its shows on my quick launch bar but is not visible on screen.
when i click to view it , it then tries to go on screen but shoots out to the side of the screen and isnt visible
thanks for your comment. We are looking into your problem. Felicia will get back to your shortly.
felicia
Post by felicia »
You can download a new version fixing the bug here
bagio
Post by bagio »
cheers guys - works a treat now :D
