ConvertXToDVD 4 Burn process
Ramjet
Post by Ramjet » Sat Jan 20, 2018 5:05 pm
I have been using this version for quite some time with good results. A short while ago I had to re-install all my programs following a Windows 10 corruption issue.
Once I re-installed ConvertXToDVD 4 I tried it to see if all was working OK. Since then, I have had an issue with the BURN process. The log clearly indicate that the program identified 3 writer(s) were found. However, a couple of lines later, it shows this line < BURN: No disc in drive >
I have tried all three drives I have but the program doesn't recognize that a blank DVD is in the drive even tho' it clearly states that it has found 3 writers on the log.
Any idea on what would cause this?
Thanks in advance for any assistance you may provide
Ramjet
Re: ConvertXToDVD 4 Burn process
Post by JJ » Sun Jan 21, 2018 3:46 pm
It says that it uses USB connected burner.
Those are not recommended, as USB is still not that reliable.
