Burned DVD will not play in a DVD player
Bwjone
Post by Bwjone » Tue Nov 03, 2015 5:26 pm
I have successfully converted and burned several DVDs that will play on a computer, but will not play in a DVD player. I have tried to play the DVDs in multiple DVD player and I am getting either a "disc error" or "no DVD" message on the DVD players. I am using Verbatim DVD+R RW blank DVDs. Here is one of my most recent log files:
2015-11-01 08:42:19 ---- ******************** Log session stop 2015-11-01 08:42:19.552 PID 5428********************
2015-11-01 08:42:17 Info BURN: 2 writer(s) found.
2015-11-01 08:42:17 Info BURN: Loaded DLL "I:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.13.476]
2015-11-01 08:42:17 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:42:17 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:42:17 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:42:17 Info BURN: Using Advanced SPTI interface
2015-11-01 08:42:17 Info Supported instruction set: sse3
2015-11-01 08:42:17 Info Maximum number of threads detected: 2 - parallelize up to 2
2015-11-01 08:42:17 Info Tuning Performances for Intel(R) Pentium(R) D CPU 3.40GHz with 2 core(s) CPU
2015-11-01 08:42:17 Info System default language : English (United States)
2015-11-01 08:42:17 Info User default language : English (United States)
2015-11-01 08:42:17 Info Version : 4.1.10.348
2015-11-01 08:42:17 Info ExeName : I:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-11-01 08:42:17 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2015-11-01 08:42:15 ---- ******************** Log session start 2015-11-01 08:42:15.275 PID 5428********************
2015-11-01 08:42:08 ---- ******************** Log session stop 2015-11-01 08:42:08.824 PID 3060********************
2015-11-01 08:40:13 Info 36 Menu templates loaded.
2015-11-01 08:40:13 Info BURN: Disc (DVD+R) not empty.
2015-11-01 08:40:11 Info BURN: 2 writer(s) found.
2015-11-01 08:40:11 Info BURN: Loaded DLL "I:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.13.476]
2015-11-01 08:40:11 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:40:11 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:40:11 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:40:11 Info BURN: Using Advanced SPTI interface
2015-11-01 08:40:11 Info Supported instruction set: sse3
2015-11-01 08:40:11 Info Maximum number of threads detected: 2 - parallelize up to 2
2015-11-01 08:40:11 Info Tuning Performances for Intel(R) Pentium(R) D CPU 3.40GHz with 2 core(s) CPU
2015-11-01 08:40:11 Info System default language : English (United States)
2015-11-01 08:40:11 Info User default language : English (United States)
2015-11-01 08:40:11 Info Version : 4.1.10.348
2015-11-01 08:40:11 Info ExeName : I:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-11-01 08:40:11 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2015-11-01 08:40:09 ---- ******************** Log session start 2015-11-01 08:40:09.450 PID 3060********************
2015-11-01 08:40:05 ---- ******************** Log session stop 2015-11-01 08:40:05.926 PID 476********************
2015-11-01 08:37:40 Info BURN: Disc (DVD+R) not empty.
2015-11-01 08:37:15 Info Folder C:\Users\RFMI\Documents\ConvertXToDVD\Let Your Fan Out_ Boo-yah\ has been removed
2015-11-01 08:37:15 Info BURN: WRITE SUCCESS: Disc written
2015-11-01 08:37:15 Info BURN: Finalization Time 00:00:29 - Total completion time 00:01:12
2015-11-01 08:36:45 Info BURN: Write finished in 00:00:42 - Finalization start here. Avg. burn rate 0.43
2015-11-01 08:36:41 Info BURN: Lead-in burning time (mS) 37657
2015-11-01 08:36:03 Info BURN: Write started 11088 sectors to write
2015-11-01 08:36:03 Info BURN: Init success: DVD+R
2015-11-01 08:36:03 Info BURN: Writing speed requested x2.4, effective x2.4
2015-11-01 08:36:03 Info BURN: Available write speed: 8x ,6x ,4x ,2.4x
2015-11-01 08:36:03 Info BURN: Media ID: RITEK-F16-01
2015-11-01 08:36:03 Info BURN: Media type: DVD+R
2015-11-01 08:36:02 Info BURN: Scanned files #7, folder #2 - total size 21606400 b. (20.61 Mb.)
2015-11-01 08:36:02 Info BURN: Inserted media type : DVD+R
2015-11-01 08:36:02 Info BURN: Write started
2015-11-01 08:36:01 ---- ***************** Encoding end **********************
2015-11-01 08:36:01 Info Disc name: "My DVD"
2015-11-01 08:35:53 Info BURN: Writable disc DVD+R inserted. Ready to write
2015-11-01 08:35:50 Info BURN: Parsing disc ...
2015-11-01 08:35:32 Info BURN: No disc in drive.
2015-11-01 08:35:30 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:35:30 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:35:30 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:35:30 Info Burned folder: "C:\Users\RFMI\Documents\ConvertXToDVD\Let Your Fan Out_ Boo-yah\", Min. media size 20.61 Mb.
2015-11-01 08:35:30 Info Total size 20 Mb., Target size DVD5 4300 Mb., Occupation 0.48%
2015-11-01 08:35:30 Info Conversion completed in 00:01:10
2015-11-01 08:35:30 Info Rendering rate: 0.65 x Realtime
2015-11-01 08:35:30 Info DVD duration (incl. menus) 00:00:46 (~ 46 sec.) - rendering time 00:01:10
2015-11-01 08:35:30 Info Generated duration 46.05 sec., expected 46.09 sec.
2015-11-01 08:34:51 Info Encoding English, AC3, 2 ch. with 2 threads
2015-11-01 08:34:51 Info Encoding MPEG-2 with 2 threads
2015-11-01 08:34:51 Info Decoding Audio: aac, 44100 Hz, stereo, s16, 125 kb/s with 2 threads
2015-11-01 08:34:51 Info Decoding Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 1934 kb/s with 2 threads
2015-11-01 08:34:51 Info Video processing: Linear (VSO) resampler (1920*1080)->(720*480) 2 threads
2015-11-01 08:34:20 Info Audio settings: Automatic With DTS -> AC-3 conversion
2015-11-01 08:34:20 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, 192 kb/s
2015-11-01 08:34:20 Info Encoding English, AC3, 2 ch. with 2 threads
2015-11-01 08:34:20 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, pass 1, 8647 kb/s, frame compensation: 30.000 -> 29.97 Fps
2015-11-01 08:34:20 Info Encoding MPEG-2 with 2 threads
2015-11-01 08:34:20 Info Decoding Audio: aac, 44100 Hz, stereo, s16, 125 kb/s with 2 threads
2015-11-01 08:34:20 Info Decoding Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 1934 kb/s with 2 threads
2015-11-01 08:34:20 Info Video processing: Linear (VSO) resampler (1920*1080)->(720*480) 2 threads
2015-11-01 08:34:20 Info Chapter sequences require 25.74 Mb. temp space
2015-11-01 08:34:20 ---- ************ Source file #1 END DETAILS ************
2015-11-01 08:34:20 Info AUDIO Stream #2 : Audio: aac, 44100 Hz, stereo, s16, 125 kb/s
2015-11-01 08:34:20 Info VIDEO Stream #1 : Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 1934 kb/s, 30.00 FPS
2015-11-01 08:34:20 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2015-11-01 08:34:20 Info Logical file: C:\Users\RFMI\Desktop\YouTube\Let Your Fan Out_ Boo-yah.mp4 - 1 file(s) 7.41 Mb.
2015-11-01 08:34:20 ---- *********** Source file #1 BEGIN DETAILS ***********
2015-11-01 08:34:20 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2015-11-01 08:34:20 Info Video bitrate 0/8647/9008 Kbps (min/avg/max)
2015-11-01 08:34:20 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2015-11-01 08:34:20 ---- ======================= TITLESET #1 =======================
2015-11-01 08:34:20 Info 2 Stream(s) found - est. duration 00:00:30.093, reference 00:00:30.093
2015-11-01 08:34:20 Info Opening file "C:\Users\RFMI\Desktop\YouTube\Let Your Fan Out_ Boo-yah.mp4"
2015-11-01 08:34:20 Info [x] Multicore support in resize
2015-11-01 08:34:20 Info Project size 4.17 Gb. (717.57 Kb. audio - 4.16 Gb. video)
2015-11-01 08:34:20 Info [ ] Don't fix audio gaps
2015-11-01 08:34:20 Info [ ] Engine Log
2015-11-01 08:34:20 Info [x] 2-pass encoding
2015-11-01 08:34:20 Info Encoding preset: SP (Short Projects)
2015-11-01 08:34:20 ---- ****************** Encoding begin *******************
2015-11-01 08:34:20 ---- **************** Menu settings end ******************
2015-11-01 08:34:20 Info [x] Don't create title menu for single video
2015-11-01 08:34:20 Info [x] Return to title menu after titleset playback
2015-11-01 08:34:20 Info [x] Skip root menu initially
2015-11-01 08:34:20 Info [ ] Play titles one after the other
2015-11-01 08:34:20 Info [ ] Loop playback
2015-11-01 08:34:20 Info [ ] Auto-start playback
2015-11-01 08:34:20 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2015-11-01 08:34:19 ---- *************** Menu settings begin *****************
2015-11-01 08:34:19 ---- **************** Burn settings end ******************
2015-11-01 08:34:19 Info Default speed selected: 2x
2015-11-01 08:34:19 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:34:19 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:34:19 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:34:19 Info [x] Delete DVD folder after burn complete
2015-11-01 08:34:19 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2015-11-01 08:34:19 Info SAO setting: Automatic
2015-11-01 08:34:19 Info [x] Burn result to DVD / as ISO file in working folder
2015-11-01 08:34:19 ---- **************** Burn settings begin ****************
2015-11-01 08:33:48 Info 36 Menu templates loaded.
2015-11-01 08:33:48 Info BURN: No disc in drive.
2015-11-01 08:33:46 Info BURN: 2 writer(s) found.
2015-11-01 08:33:46 Info BURN: Loaded DLL "I:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.13.476]
2015-11-01 08:33:46 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:33:46 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:33:46 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:33:46 Info BURN: Using Advanced SPTI interface
2015-11-01 08:33:46 Info Supported instruction set: sse3
2015-11-01 08:33:46 Info Maximum number of threads detected: 2 - parallelize up to 2
2015-11-01 08:33:46 Info Tuning Performances for Intel(R) Pentium(R) D CPU 3.40GHz with 2 core(s) CPU
2015-11-01 08:33:46 Info System default language : English (United States)
2015-11-01 08:33:46 Info User default language : English (United States)
2015-11-01 08:33:46 Info Version : 4.1.10.348
2015-11-01 08:33:46 Info ExeName : I:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-11-01 08:33:46 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2015-11-01 08:33:44 ---- ******************** Log session start 2015-11-01 08:33:44.407 PID 476********************
2015-11-01 08:33:26 ---- ******************** Log session stop 2015-11-01 08:33:26.638 PID 6092********************
2015-11-01 08:33:10 Info 36 Menu templates loaded.
2015-11-01 08:33:08 Info BURN: No disc in drive.
2015-11-01 08:33:06 Info BURN: 2 writer(s) found.
2015-11-01 08:33:06 Info BURN: Loaded DLL "I:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.13.476]
2015-11-01 08:33:06 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 08:33:06 Info BURN: Drive has USB (1.1 or 2.0) physical interface
2015-11-01 08:33:06 Info BURN: New Drive selected : 0:0:0 - TSSTcorp CDDVDW SE-208DB TS01 [E] (Usb)
2015-11-01 08:33:06 Info BURN: Using Advanced SPTI interface
2015-11-01 08:33:05 Info Supported instruction set: sse3
2015-11-01 08:33:05 Info Maximum number of threads detected: 2 - parallelize up to 2
2015-11-01 08:33:05 Info Tuning Performances for Intel(R) Pentium(R) D CPU 3.40GHz with 2 core(s) CPU
2015-11-01 08:33:05 Info System default language : English (United States)
2015-11-01 08:33:05 Info User default language : English (United States)
2015-11-01 08:33:05 Info Version : 4.1.10.348
2015-11-01 08:33:05 Info ExeName : I:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-11-01 08:33:05 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2015-11-01 08:33:01 ---- ******************** Log session start 2015-11-01 08:33:01.775 PID 6092********************
2015-11-01 07:19:17 ---- ******************** Log session stop 2015-11-01 07:19:17.331 PID 1476********************
2015-11-01 07:02:49 Info 37 Menu templates loaded.
2015-11-01 07:02:46 Info BURN: No disc in drive.
2015-11-01 07:02:45 Info BURN: 2 writer(s) found.
2015-11-01 07:02:45 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\4\vso_hwe.dll" [4.0.17.485]
2015-11-01 07:02:45 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2015-11-01 07:02:45 Info BURN: Drive has IDE-ATAPI physical interface
2015-11-01 07:02:44 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVD+-RW GSA-T21N A100 [D] (Ide)
2015-11-01 07:02:44 Info BURN: Using Advanced SPTI interface
2015-11-01 07:02:43 Info Supported instruction set: sse3
2015-11-01 07:02:43 Info Maximum number of threads detected: 2 - parallelize up to 2
2015-11-01 07:02:43 Info Tuning Performances for Intel(R) Pentium(R) D CPU 3.40GHz with 2 core(s) CPU
2015-11-01 07:02:43 Info System default language : English (United States)
2015-11-01 07:02:43 Info User default language : English (United States)
2015-11-01 07:02:43 Info Version : 4.2.0.0
2015-11-01 07:02:43 Info ExeName : C:\Program Files\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-11-01 07:02:43 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2015-11-01 07:02:39 ---- ******************** Log session start 2015-11-01 07:02:39.836 PID 1476********************
Re: Burned DVD will not play in a DVD player
Post by JJ » Tue Nov 03, 2015 6:17 pm
Most DVD players require disc to have at least 1Gb size.
Your example is only 21Mb so DVD players refuse to play it, computer plays it because it has no such restrictions.
Bwjone
Post by Bwjone » Tue Nov 17, 2015 10:29 am
My problem ended up being ... small file sized burn ... plus using "RW" DVDs. This issue can be marked "Solved" now. Thanks!
