Convert x to dvd slow conversion and burn
Uptown03
Post by Uptown03 » Tue May 12, 2015 3:44 pm
Why is my burning taking over 2 hours to burn it used to take 15-20 mins on my old computer I have a newer model and it moves like shit now when I convert and burn Please help
Re: Convert x to dvd slow conversion and burn
Post by JJ » Tue May 12, 2015 3:55 pm
Please read "Forum rules" above.
Uptown03
Post by Uptown03 » Tue May 12, 2015 4:13 pm
This is the log and I am doing nothing on the computer while it is burning or converting
2015-05-12 10:01:51 Info 37 Menu templates loaded.
2015-05-12 10:01:48 Warning BURN: No writer found. Only ISO image destination is available
2015-05-12 10:01:48 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.17.485]
2015-05-12 10:01:48 Warning BURN: Drive 0:0:0 - TSSTcorp CDDVDW SU-208FB TF01 [D] (Scsi) not listed because it appear to be used by ConvertXtoDvd.exe_004480
2015-05-12 10:01:48 Info BURN: Using Advanced SPTI interface
2015-05-12 10:01:48 Info Supported instruction set: sse4
2015-05-12 10:01:48 Info Maximum number of threads detected: 4 - parallelize up to 4
2015-05-12 10:01:48 Info Tuning Performances for AMD A4-6210 APU with AMD Radeon R3 Graphics with 4 core(s) CPU
2015-05-12 10:01:48 Info System default language : English (United States)
2015-05-12 10:01:48 Info User default language : English (United States)
2015-05-12 10:01:48 Info Version : 4.1.19.365
2015-05-12 10:01:48 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2015-05-12 10:01:48 Info OS : Home Edition (Build 9200)
2015-05-12 10:01:45 ---- ******************** Log session start 2015-05-12 10:01:45.763 PID 7100********************
2015-05-12 05:43:09 ---- ******************** Log session stop 2015-05-12 05:43:09.473 PID 3284********************
2015-05-12 05:42:57 Info Burned folder: "C:\Users\rholloway2221\Documents\ConvertXToDVD\Fast.and.Furious.7.2015.HC.HDRip.XViD.AC3-ETRG", Min. media size 3.30 Gb.
2015-05-12 05:41:51 Info Burned folder: "C:\Users\rholloway2221\Documents\ConvertXToDVD\Avengers Age of Ultron {2015} ENG CAM XVID AC3 MURD3R", Min. media size 2.86 Gb.
2015-05-12 05:41:29 Info Burned folder: "C:\Users\rholloway2221\Documents\ConvertXToDVD\Avengers Age of Ultron {2015} ENG CAM XVID AC3 MURD3R", Min. media size 2.86 Gb.
2015-05-12 05:41:05 ---- ***************** Encoding end **********************
2015-05-12 01:11:40 Info Burned folder: "C:\Users\rholloway2221\Documents\ConvertXToDVD\Avengers Age of Ultron {2015} ENG CAM XVID AC3 MURD3R\", Min. media size 2.86 Gb.
2015-05-12 01:11:40 Info Total size 2924 Mb., Target size DVD5 4300 Mb., Occupation 68.00%
2015-05-12 01:11:40 Info Conversion completed in 01:34:57
2015-05-12 01:11:40 Info Rendering rate: 1.42 x Realtime
2015-05-12 01:11:40 Info DVD duration (incl. menus) 02:14:23 (~ 8063 sec.) - rendering time 01:34:57
2015-05-12 01:11:40 Info Generated duration 8063.16 sec., expected 8051.46 sec.
2015-05-12 01:09:35 Info 7 frames duplicated
2015-05-12 01:06:02 Info Chapter #27 start at 130:0.292
2015-05-12 01:03:30 Info Chapter #26 start at 124:59.992
2015-05-12 01:00:36 Info Chapter #25 start at 120:0.193
2015-05-12 00:55:38 Info Chapter #24 start at 115:0.393
2015-05-12 00:53:37 Info Number of CD/DVD devices changed. Now 1
2015-05-12 00:53:36 Warning BURN: Drive 0:0:0 - TSSTcorp CDDVDW SU-208FB TF01 [D] (Scsi) not listed because it appear to be used by ConvertXtoDvd.exe_001824
2015-05-12 00:52:23 Info Chapter #23 start at 110:0.093
2015-05-12 00:49:03 Info Chapter #22 start at 105:0.294
2015-05-12 00:44:05 Info Chapter #21 start at 99:59.994
2015-05-12 00:41:03 Info Chapter #20 start at 95:0.194
2015-05-12 00:37:50 Info Chapter #19 start at 90:0.395
2015-05-12 00:34:25 Info Chapter #18 start at 85:0.095
2015-05-12 00:30:22 Info Chapter #17 start at 80:0.295
2015-05-12 00:27:02 Info Chapter #16 start at 74:59.995
2015-05-12 00:23:50 Info Chapter #15 start at 70:0.196
2015-05-12 00:20:26 Info Chapter #14 start at 65:0.396
2015-05-12 00:16:59 Info Chapter #13 start at 60:0.096
2015-05-12 00:12:11 Info Chapter #12 start at 55:0.297
2015-05-12 00:08:30 Info Chapter #11 start at 49:59.997
2015-05-12 00:05:07 Info Chapter #10 start at 45:0.197
2015-05-12 00:01:48 Info Chapter #9 start at 40:0.398
Uptown03
Post by Uptown03 » Tue May 12, 2015 4:21 pm
Is this log good enough for you to tell what is going on with my conversion and burning.
Uptown03
Post by Uptown03 » Thu May 14, 2015 4:44 pm
What is the problem I have no response
Post by JJ » Sat May 16, 2015 8:48 am
log is not full, and you have older version of cxd4.
Laurice
Post by Laurice » Thu May 21, 2015 10:33 pm
I am no expert, by any means. But, it looks like CXD4 does not recognize your optical drive (Burner).
Have you tried uninstalling your optical drive(s) and then rebooting?
(I have a gold membership but prefer CXD4 over CXD5, as well. Mostly due to the wonderful templates created by Tattoo.)
Seems to me that I had this problem several years ago and it was caused by some strange software conflict that changed my optical drives' properties in the registry. Uninstalling them and letting Windows reinstall them did the trick.
Also, have you checked to make sure that you are not in PIO mode?
Code: Select all
http://forums.vso-software.fr/burning-problem-burning-is-slow-t13679.html
(or)https://www.ifixit.com/Wiki/Enabling_DMA_Mode_Transfers
