Need help figuring out problem is...Log File attached
movieholic1977
Post by movieholic1977 » Mon Jun 16, 2014 12:26 pm
To whom this concerns,
I am sure this is an easy fix, but i cannot see any way to fix this. So whats the problem?
I also have crappy blank dvd's which i will upgrade to Verbatim when i get my new SSi an SSDi next month
There is no firmware update for my ASUS DVD Burner, i checked and none was available, i also downloaded it to desktop and tried to update it and got the same response.
I read the common problems but nothing seems to make sense, i guess because this stuff is hard to figure out
Thanks in advance for your help,
The Lyons Family
Samantha and Michael
Here is the Log File:
2014-06-16 08:09:47 Error BURN: INIT ERROR: Writing device initialization failed - sense: Code 05 26 00 [Illegal request, Invalid field in Parameter list]
2014-06-16 08:09:47 Error BURN: Init DVD+R: can't set write parameters mode page. Code 05 26 00 [Illegal request, Invalid field in Parameter list]
2014-06-16 08:09:46 Info BURN: Available write speed: 16x ,12x ,8x ,6x
2014-06-16 08:09:46 Info BURN: Media ID: CMC MAG-M01-00
2014-06-16 08:09:46 Info BURN: Media type: DVD+R
2014-06-16 08:09:46 Info BURN: Ultra DMA mode 5 (ATA100)
2014-06-16 08:09:46 Info BURN: Scanned files #20, folder #2 - total size 3265264463 b. (3.04 Gb.)
2014-06-16 08:09:46 Info BURN: Inserted media type : DVD+R
2014-06-16 08:09:46 Info BURN: Write started
2014-06-16 08:09:44 Info Disc name: "White.Collar.S04E01.HDTV.x264-AS"
2014-06-16 08:09:30 Info BURN: Writable disc DVD+R inserted. Ready to write
2014-06-16 08:09:22 Info BURN: Parsing disc ...
2014-06-16 08:09:10 Info BURN: Incompatible disc.
2014-06-16 08:09:04 Info BURN: Disc ejected by user while parsing.
2014-06-16 08:09:00 Info BURN: Parsing disc ...
2014-06-16 08:09:00 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-16 08:09:00 Info BURN: Drive has Serial ATA physical interface
2014-06-16 08:09:00 Info BURN: New Drive selected : 1:0:0 - ASUS DRW-24B1ST c 1.05 [E] (Ide)
2014-06-16 08:09:00 Info Burned folder: "C:\Users\Samantha\Documents\ConvertXToDVD\White.Collar.S04E01.HDTV.x264-ASAP", Min. media size 3.04 Gb.
2014-06-16 08:08:56 Info BURN: Parsing disc ...
2014-06-16 08:08:55 Info 36 Menu templates loaded.
2014-06-16 08:08:54 Info BURN: 1 writer(s) found.
2014-06-16 08:08:54 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.11.473]
2014-06-16 08:08:54 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-16 08:08:54 Info BURN: Drive has Serial ATA physical interface
2014-06-16 08:08:54 Info BURN: New Drive selected : 1:0:0 - ASUS DRW-24B1ST c 1.05 [E] (Ide)
2014-06-16 08:08:54 Info BURN: Using Advanced SPTI interface
2014-06-16 08:08:54 Info Supported instruction set: sse4
2014-06-16 08:08:54 Info Maximum number of threads detected: 4 - parallelize up to 4
2014-06-16 08:08:54 Info Tuning Performances for Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz with 4 core(s) CPU
2014-06-16 08:08:54 Info System default language : English (United States)
2014-06-16 08:08:54 Info User default language : English (United States)
2014-06-16 08:08:54 Info Version : 4.1.2.336
2014-06-16 08:08:54 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2014-06-16 08:08:54 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
2014-06-16 08:08:52 ---- ******************** Log session start 2014-06-16 08:08:52.603 PID 536********************
Re: Need help figuring out problem is...Log File attached
Post by JJ » Mon Jun 16, 2014 3:43 pm
You should update to last v4 version, link is in sticky topics.
Then, your problem is those crappy blanks. Burner tries to cope with them but can't and fails.
You might be able to burn indirectly. First convert, check that result is good, then "burn already converted project" from CxD menu or use another program like ImgBurn to burn it.
