Getting an Invalid Pointer Operation message
firestrike1
Post by firestrike1 » Sun Jun 01, 2014 3:34 pm
sorry if there's another thread for this problem, but I can't seem to find one elsewhere here... so again, my apologies if I've not looked in the right places...
been using version 4 for about 4 years now and never got this message of Invalid Pointer Operation before... what's up with this and is it solveable?... here's a log of what happened when it happened... and I'm redoing the project again... will this message pop up again?...
2014-06-01 09:35:21 ---- ******************** Log session stop 2014-06-01 09:35:21.834 PID 5312********************
2014-06-01 09:27:38 Info BURN: No disc in drive.
2014-06-01 09:27:17 ---- ***************** Encoding end **********************
2014-06-01 09:27:17 Error CANNOT BURN DVD: IFO or ISO files doesn't exist in folder "C:\Users\Paul\Documents\ConvertXToDVD\AGENT OF SHIELD DISC 2\"
2014-06-01 09:27:17 Info Total size 1157 Mb., Target size DVD5 4300 Mb., Occupation 26.92%
2014-06-01 09:27:17 Info Conversion completed in 02:50:17
2014-06-01 09:27:16 Error Exception raised in conversion Thread with message "Invalid pointer operation"
2014-06-01 09:22:20 Info Chapter #9 start at 40:0.398
2014-06-01 09:09:19 Info Chapter #8 start at 35:0.098
2014-06-01 09:00:32 Info Chapter #7 start at 30:0.298
2014-06-01 08:56:53 Info Chapter #6 start at 24:59.998
2014-06-01 08:53:31 Info Chapter #5 start at 20:0.199
2014-06-01 08:49:39 Info Chapter #4 start at 15:0.399
2014-06-01 08:46:09 Info Chapter #3 start at 10:0.099
2014-06-01 08:42:34 Info Chapter #2 start at 5:0.300
2014-06-01 08:39:12 Info Audio settings: Automatic With DTS -> AC-3 conversion
2014-06-01 08:39:12 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
2014-06-01 08:39:12 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 1023 kb/s, pulldown: 23.976 -> 29.97 Fps
2014-06-01 08:39:12 Info Encoding MPEG-2 with 2 threads
2014-06-01 08:39:12 Info Decoding Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 742 kb/s with 2 threads
2014-06-01 08:39:12 Info Video processing: Lanczos (VSO) resampler (720*404)->(720*480) 2 threads
2014-06-01 08:39:11 Info Chapter sequences require 0 b. temp space
2014-06-01 08:39:11 ---- ************ Source file #1 END DETAILS ************
2014-06-01 08:39:11 Info AUDIO Stream #2 : Audio: aac, 48000 Hz, stereo, s16, 127 kb/s
2014-06-01 08:39:11 Info VIDEO Stream #1 : Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 742 kb/s, 23.98 FPS
2014-06-01 08:39:11 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-01 08:39:11 Info Logical file: C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E15.Yes.Men.WEB-DL.x264.AAC.mp4 - 1 file(s) 269.41 Mb.
2014-06-01 08:39:11 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-01 08:39:11 Info Video bitrate 0/1023/9008 Kbps (min/avg/max)
2014-06-01 08:39:11 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-01 08:39:11 ---- ======================= TITLESET #4 =======================
2014-06-01 08:39:11 Info Generated duration 2557.90 sec., expected 2558.14 sec.
2014-06-01 08:39:11 Info 1 frames duplicated
2014-06-01 08:37:44 Info Chapter #9 start at 40:0.398
2014-06-01 08:34:26 Info Chapter #8 start at 35:0.098
2014-06-01 08:30:49 Info Chapter #7 start at 30:0.298
2014-06-01 08:27:29 Info Chapter #6 start at 24:59.998
2014-06-01 08:23:24 Info Chapter #5 start at 20:0.199
2014-06-01 08:20:09 Info Chapter #4 start at 15:0.399
2014-06-01 08:15:48 Info Chapter #3 start at 10:0.099
2014-06-01 08:09:57 Info Chapter #2 start at 5:0.300
2014-06-01 08:03:48 Info Audio settings: Automatic With DTS -> AC-3 conversion
2014-06-01 08:03:48 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
2014-06-01 08:03:48 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 1019 kb/s, pulldown: 23.976 -> 29.97 Fps
2014-06-01 08:03:48 Info Encoding MPEG-2 with 2 threads
2014-06-01 08:03:47 Info Decoding Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 674 kb/s with 2 threads
2014-06-01 08:03:47 Info Video processing: Lanczos (VSO) resampler (720*404)->(720*480) 2 threads
2014-06-01 08:03:47 Info Chapter sequences require 0 b. temp space
2014-06-01 08:03:47 ---- ************ Source file #1 END DETAILS ************
2014-06-01 08:03:47 Info AUDIO Stream #2 : Audio: aac, 48000 Hz, stereo, s16, 127 kb/s
2014-06-01 08:03:47 Info VIDEO Stream #1 : Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 674 kb/s, 23.98 FPS
2014-06-01 08:03:47 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-01 08:03:47 Info Logical file: C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E14.T.A.H.I.T.I.WEB-DL.x264.AAC.mp4 - 1 file(s) 246.00 Mb.
2014-06-01 08:03:47 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-01 08:03:47 Info Video bitrate 0/1019/9008 Kbps (min/avg/max)
2014-06-01 08:03:47 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-01 08:03:46 ---- ======================= TITLESET #3 =======================
2014-06-01 08:03:46 ---- *
2014-06-01 08:03:46 Info Generated duration 2554.93 sec., expected 2555.18 sec.
2014-06-01 08:03:46 Info 1 frames duplicated
2014-06-01 08:00:57 Info Chapter #9 start at 40:0.398
2014-06-01 07:54:41 Info Chapter #8 start at 35:0.098
2014-06-01 07:48:32 Info Chapter #7 start at 30:0.298
2014-06-01 07:41:15 Info Chapter #6 start at 24:59.998
2014-06-01 07:33:31 Info Chapter #5 start at 20:0.199
2014-06-01 07:25:06 Info Chapter #4 start at 15:0.399
2014-06-01 07:17:03 Info Chapter #3 start at 10:0.099
2014-06-01 07:10:15 Info Chapter #2 start at 5:0.300
2014-06-01 07:06:00 Info Audio settings: Automatic With DTS -> AC-3 conversion
2014-06-01 07:06:00 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
2014-06-01 07:06:00 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 1015 kb/s, pulldown: 23.976 -> 29.97 Fps
2014-06-01 07:06:00 Info Encoding MPEG-2 with 2 threads
2014-06-01 07:06:00 Info Decoding Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 938 kb/s with 2 threads
2014-06-01 07:06:00 Info Video processing: Lanczos (VSO) resampler (720*404)->(720*480) 2 threads
2014-06-01 07:06:00 Info Chapter sequences require 0 b. temp space
2014-06-01 07:06:00 ---- ************ Source file #1 END DETAILS ************
2014-06-01 07:06:00 Info AUDIO Stream #2 : Audio: aac, 48000 Hz, stereo, s16, 127 kb/s
2014-06-01 07:06:00 Info VIDEO Stream #1 : Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 938 kb/s, 23.98 FPS
2014-06-01 07:06:00 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-01 07:06:00 Info Logical file: C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E13.T.R.A.C.K.S.WEB-DL.x264.AAC.mp4 - 1 file(s) 326.01 Mb.
2014-06-01 07:06:00 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-01 07:06:00 Info Video bitrate 0/1015/9008 Kbps (min/avg/max)
2014-06-01 07:06:00 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-01 07:06:00 ---- ======================= TITLESET #2 =======================
2014-06-01 07:06:00 Info Generated duration 2583.71 sec., expected 2584.00 sec.
2014-06-01 07:05:59 Info 1 frames duplicated
2014-06-01 07:03:30 Info Chapter #9 start at 40:0.398
2014-06-01 06:59:14 Info Chapter #8 start at 35:0.098
2014-06-01 06:56:01 Info Chapter #7 start at 30:0.298
2014-06-01 06:52:48 Info Chapter #6 start at 24:59.998
2014-06-01 06:49:51 Info Chapter #5 start at 20:0.199
2014-06-01 06:46:32 Info Chapter #4 start at 15:0.399
2014-06-01 06:42:58 Info Chapter #3 start at 10:0.099
2014-06-01 06:39:59 Info Chapter #2 start at 5:0.300
2014-06-01 06:37:01 Info Audio settings: Automatic With DTS -> AC-3 conversion
2014-06-01 06:37:01 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
2014-06-01 06:37:01 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 1011 kb/s, pulldown: 23.976 -> 29.97 Fps
2014-06-01 06:37:01 Info Encoding MPEG-2 with 2 threads
2014-06-01 06:37:01 Info Decoding Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 723 kb/s with 2 threads
2014-06-01 06:37:01 Info Video processing: Lanczos (VSO) resampler (720*404)->(720*480) 2 threads
2014-06-01 06:37:01 Info Chapter sequences require 0 b. temp space
2014-06-01 06:37:01 ---- ************ Source file #1 END DETAILS ************
2014-06-01 06:37:01 Info AUDIO Stream #2 : Audio: aac, 48000 Hz, stereo, s16, 127 kb/s
2014-06-01 06:37:01 Info VIDEO Stream #1 : Video: h264 (High), yuv420p, 720x404 [PAR 1:1 DAR 180:101], 723 kb/s, 23.98 FPS
2014-06-01 06:37:01 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-01 06:37:01 Info Logical file: C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E12.Seeds.WEB-DL.x264.AAC.mp4 - 1 file(s) 263.65 Mb.
2014-06-01 06:37:01 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-01 06:37:01 Info Video bitrate 0/1011/9008 Kbps (min/avg/max)
2014-06-01 06:37:01 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-01 06:37:01 ---- ======================= TITLESET #1 =======================
2014-06-01 06:37:01 Info 2 Stream(s) found - est. duration 00:43:01.952, reference 00:43:01.952
2014-06-01 06:37:01 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E22.Beginning.of.the.End.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:01 Info 2 Stream(s) found - est. duration 00:42:59.200, reference 00:42:59.200
2014-06-01 06:37:01 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E21.Ragtag.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:01 Info 2 Stream(s) found - est. duration 00:43:02.955, reference 00:43:02.955
2014-06-01 06:37:01 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E20.Nothing.Personal.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:01 Info 2 Stream(s) found - est. duration 00:43:04.192, reference 00:43:04.192
2014-06-01 06:37:01 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E19.The.Only.Light.in.The.Darkness.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:00 Info 2 Stream(s) found - est. duration 00:43:06.368, reference 00:43:06.368
2014-06-01 06:37:00 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E18.Providence.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:00 Info 2 Stream(s) found - est. duration 00:43:04.683, reference 00:43:04.683
2014-06-01 06:37:00 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E17.Turn.Turn.Turn.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:00 Info 2 Stream(s) found - est. duration 00:41:16.140, reference 00:41:16.140
2014-06-01 06:37:00 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E16.End.of.the.Beginning.WEB-DL.x264.AAC.mp4"
2014-06-01 06:37:00 Info 2 Stream(s) found - est. duration 00:43:04.171, reference 00:43:04.171
2014-06-01 06:37:00 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E15.Yes.Men.WEB-DL.x264.AAC.mp4"
2014-06-01 06:36:59 Info 2 Stream(s) found - est. duration 00:42:38.144, reference 00:42:38.144
2014-06-01 06:36:59 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E14.T.A.H.I.T.I.WEB-DL.x264.AAC.mp4"
2014-06-01 06:36:59 Info 2 Stream(s) found - est. duration 00:42:35.179, reference 00:42:35.179
2014-06-01 06:36:59 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E13.T.R.A.C.K.S.WEB-DL.x264.AAC.mp4"
2014-06-01 06:36:59 Info 2 Stream(s) found - est. duration 00:43:04.000, reference 00:43:04.000
2014-06-01 06:36:59 Info Opening file "C:\Users\Paul\Documents\Bittorrent\Share\Agents.of.S.H.I.E.L.D.S01E01-22.WEB-DL.x264.AAC\Agents.of.S.H.I.E.L.D.S01E12.Seeds.WEB-DL.x264.AAC.mp4"
2014-06-01 06:36:59 Info [x] Multicore support in resize
2014-06-01 06:36:59 Info Project size 4.17 Gb. (658.00 Mb. audio - 3.51 Gb. video)
2014-06-01 06:36:59 Info [ ] Don't fix audio gaps
2014-06-01 06:36:59 Info [ ] Engine Log
2014-06-01 06:36:59 Info [ ] 2-pass encoding
2014-06-01 06:36:59 Info Encoding preset: LP (Long Projects)
2014-06-01 06:36:59 ---- ****************** Encoding begin *******************
2014-06-01 06:36:59 ---- **************** Menu settings end ******************
2014-06-01 06:36:59 Info [x] Don't create title menu for single video
2014-06-01 06:36:59 Info [x] Return to title menu after titleset playback
2014-06-01 06:36:59 Info [x] Skip root menu initially
2014-06-01 06:36:59 Info [x] Play titles one after the other
2014-06-01 06:36:59 Info [ ] Loop playback
2014-06-01 06:36:59 Info [ ] Auto-start playback
2014-06-01 06:36:59 Info Template: Minimal, the most simple menu, contains 1 page(s), 3 customizable element(s)
2014-06-01 06:36:59 ---- *************** Menu settings begin *****************
2014-06-01 06:36:59 ---- **************** Burn settings end ******************
2014-06-01 06:36:59 Info Default speed selected: 8x
2014-06-01 06:36:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-01 06:36:59 Info BURN: Drive has IDE-ATAPI physical interface
2014-06-01 06:36:59 Info BURN: New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GH22NP20 2.00 [E] (Ide)
2014-06-01 06:36:59 Info [ ] Delete DVD folder after burn complete
2014-06-01 06:36:59 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2014-06-01 06:36:59 Info SAO setting: Automatic
2014-06-01 06:36:59 Info [x] Burn result to DVD / as ISO file in working folder
2014-06-01 06:36:59 ---- **************** Burn settings begin ****************
2014-06-01 06:32:30 Info 36 Menu templates loaded.
2014-06-01 06:32:23 Info BURN: No disc in drive.
2014-06-01 06:32:21 Info BURN: 1 writer(s) found.
2014-06-01 06:32:21 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\4\vso_hwe.dll" [4.0.15.483]
2014-06-01 06:32:21 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-01 06:32:21 Info BURN: Drive has IDE-ATAPI physical interface
2014-06-01 06:32:21 Info BURN: New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GH22NP20 2.00 [E] (Ide)
2014-06-01 06:32:21 Info BURN: Using Advanced SPTI interface
2014-06-01 06:32:20 Info Supported instruction set: sse3
2014-06-01 06:32:20 Info Maximum number of threads detected: 2 - parallelize up to 2
2014-06-01 06:32:20 Info Tuning Performances for Intel(R) Pentium(R) 4 CPU 2.80GHz with 2 logical core(s)
2014-06-01 06:32:20 Info System default language : English (United States)
2014-06-01 06:32:20 Info User default language : English (United States)
2014-06-01 06:32:20 Info Version : 4.1.12.352
2014-06-01 06:32:20 Info ExeName : C:\Program Files\VSO\ConvertX\4\ConvertXtoDvd.exe
2014-06-01 06:32:20 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2014-06-01 06:32:08 ---- ******************** Log session start 2014-06-01 06:32:08.284 PID 5312********************
Re: Getting an Invalid Pointer Operation message
Post by JJ » Sun Jun 01, 2014 4:35 pm
Try to convert only that episode 15 - that is the one that fails.
If it fails still, then that file is damaged.
Copnm
Post by Copnm » Sun Jun 01, 2014 4:37 pm
Hello firestrike,
Please do a fresh/clean install, and install the latest version, v4.2.0.0: http://download2.vso-software.fr/vsoCon ... _setup.exe and try it again.
Don't forget to write down or copy your key somewhere beforehand.
Thanks for reading,
Neil M
firestrike1
Post by firestrike1 » Sun Jun 01, 2014 5:55 pm
am re-trying the conversion process in the same manner as earlier, in case the invalid pointer message was a fluke of some sort... will return after the conversion is completed or if the message reappears again and will let you know how it all went...
firestrike1
Post by firestrike1 » Sun Jun 01, 2014 9:05 pm
well, I successfully did a conversion on that same project and evidently for SOME reason, the invalid pointer operation message DID turn out to be a fluke message of a sort... I did nothing at all different in the operation and conversion and the project the second time around went without incident... and just to make sure, I went and replayed the finalized disc and it played just fine... so I don't know what that was all about earlier, so I can only assume that it was a case of shit happens... so thanks for your responses and just in case it happens again, I'll know what steps to follow, but I doubt if it'll happen again... thanks again, guys, and cheers... :D
Copnm
Post by Copnm » Mon Jun 02, 2014 2:05 am
Hello firestrike1,
I'm glad you were able to find a solution! :D If ever run into another issue or concern, feel free to ask! 8)
Don't forget that the latest version to ConvertXtoDVD 4 I linked you to, v4.2.0.0, has a lot of fixes.
Thanks for reading,
Neil M
firestrike1
Post by firestrike1 » Mon Jun 02, 2014 3:31 am
thank you, sir... :D
