not enough capacity
not enough capacity
it was working before...not is not. it's v frustrating...please help. Maybe it was answered before, i was looking for 2 hours in forum but i couldn't find an answer.
the conversions runs great. it's a mkv 45min episode. the folder created by convertxtodvd is aprox 2gb.
i insert the media (dvd+rw) a window pops'up "your disk is being parsed, please wait"
and then...another window:
wrong disk used.inserted dvd+rw doesn't have enough capacity. Available:4.38GB, required: 8.00Tb
and the disc is ejected.
here is the log:
22011-09-21 22:11:12 ---- ***************** Encoding end **********************
2011-09-21 20:58:01 Info BURN: Disc ejected by user.
2011-09-21 20:57:59 Info BURN: Writable disc DVD+RW inserted. Ready to write
2011-09-21 20:57:57 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-09-21 20:57:57 Info BURN: Drive has Serial ATA physical interface
2011-09-21 20:57:57 Info BURN: New Drive selected : 5:1:0 - ASUS DRW-24B1ST a 1.04 [G] (Ide)
2011-09-21 20:57:57 Info Burned folder: "C:\...", Min. media size 0 b.
2011-09-21 20:57:57 Info Total size 0 Mb., Target size DVD5 4300 Mb., Occupation 0.00%
2011-09-21 20:57:57 Info Conversion completed in 00:17:57
2011-09-21 20:57:57 Info Rendering rate: 2.60 x Realtime
2011-09-21 20:57:57 Info DVD duration (incl. menus) 00:46:41 (~ 2801 sec.) - rendering time 00:17:57
2011-09-21 20:57:56 Info Generated duration 2801.70 sec., expected 2794.11 sec.
2011-09-21 20:57:17 Info 875 subtitles frames encoded in subtitle stream #1
2011-09-21 20:57:17 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
2011-09-21 20:56:46 Info Chapter #10 start at 45:0.197
2011-09-21 20:54:54 Info Chapter #9 start at 40:0.398
2011-09-21 20:53:15 Info Chapter #8 start at 35:0.098
2011-09-21 20:51:29 Info Chapter #7 start at 30:0.298
2011-09-21 20:49:33 Info Chapter #6 start at 24:59.998
2011-09-21 20:47:52 Info Chapter #5 start at 20:0.199
2011-09-21 20:45:51 Info Chapter #4 start at 15:0.399
2011-09-21 20:43:34 Info Chapter #3 start at 10:0.099
2011-09-21 20:41:40 Info Chapter #2 start at 5:0.300
2011-09-21 20:39:59 Info Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2011-09-21 20:39:59 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 6 channels, 448 kb/s
2011-09-21 20:39:59 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 8409 kb/s, pulldown: 23.976 -> 29.97 Fps
2011-09-21 20:39:59 Info Chapter sequences require 201.46 Mb. temp space
2011-09-21 20:39:59 ---- ************ Source file #1 END DETAILS ************
2011-09-21 20:39:59 Info SUBTITLE Stream #3 : Subtitle: Text subtitles
2011-09-21 20:39:59 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
2011-09-21 20:39:59 Info VIDEO Stream #1 : Video: h264 (High), yuv420p, 720x480 [PAR 8:9 DAR 4:3], 23.98 FPS
2011-09-21 20:39:59 Info Audio/Video file with 3 stream(s) - Playback order:1 - Queue:0
2011-09-21 20:39:59 Info Logical file: D:\....mkv - 1 file(s) 549.90 Mb.
2011-09-21 20:39:59 ---- *********** Source file #1 BEGIN DETAILS ***********
2011-09-21 20:39:59 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2011-09-21 20:39:59 Info Video bitrate 0/8409/8760 Kbps (min/avg/max)
2011-09-21 20:39:59 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2011-09-21 20:39:59 ---- ======================= TITLESET #1 =======================
2011-09-21 20:39:59 Info 3 Stream(s) found - est. duration 00:45:30.112, reference 00:45:30.112
2011-09-21 20:39:59 Info Opening file "D:\....mkv"
2011-09-21 20:39:59 Info [ ] Multicore support in resize
2011-09-21 20:39:59 Info Project size 4.17 Gb. (148.34 Mb. audio - 4.01 Gb. video)
2011-09-21 20:39:59 Info [ ] Don't fix audio gaps
2011-09-21 20:39:59 Info [ ] Engine Log
2011-09-21 20:39:59 Info [ ] 2-pass encoding
2011-09-21 20:39:59 Info Encoding preset: SP (Short Projects)
2011-09-21 20:39:59 ---- ****************** Encoding begin *******************
2011-09-21 20:39:59 ---- **************** Menu settings end ******************
2011-09-21 20:39:59 Info [x] Don't create title menu for single video
2011-09-21 20:39:59 Info [x] Return to title menu after titleset playback
2011-09-21 20:39:59 Info [x] Skip root menu initially
2011-09-21 20:39:59 Info [ ] Play titles one after the other
2011-09-21 20:39:59 Info [ ] Loop playback
2011-09-21 20:39:59 Info [x] Auto-start playback
2011-09-21 20:39:59 Info Menu fit: Text size reduced from 14 to 13 in style "caption"
2011-09-21 20:39:59 Info Menu fit: Text size reduced from 24 to 15 in style "title"
2011-09-21 20:39:59 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2011-09-21 20:39:59 ---- *************** Menu settings begin *****************
2011-09-21 20:39:59 ---- **************** Burn settings end ******************
2011-09-21 20:39:59 Info Default speed selected: 2x
2011-09-21 20:39:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-09-21 20:39:59 Info BURN: Drive has Serial ATA physical interface
2011-09-21 20:39:59 Info BURN: New Drive selected : 5:1:0 - ASUS DRW-24B1ST a 1.04 [G] (Ide)
2011-09-21 20:39:59 Info [x] Delete DVD folder after burn complete
2011-09-21 20:39:59 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2011-09-21 20:39:59 Info SAO setting: Automatic
2011-09-21 20:39:59 Info [x] Burn result to DVD / as ISO file in working folder
2011-09-21 20:39:59 ---- **************** Burn settings begin ****************
2011-09-21 20:38:24 Info 37 Menu templates loaded.
2011-09-21 20:38:23 Info BURN: Writable disc DVD+RW inserted. Ready to write
2011-09-21 20:38:21 Info BURN: 1 writer(s) found.
2011-09-21 20:38:21 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\4\vso_hwe.dll" [4.0.17.485]
2011-09-21 20:38:21 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-09-21 20:38:21 Info BURN: Drive has Serial ATA physical interface
2011-09-21 20:38:21 Info BURN: New Drive selected : 5:1:0 - ASUS DRW-24B1ST a 1.04 [G] (Ide)
2011-09-21 20:38:21 Info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2011-09-21 20:38:01 Info Supported instruction set: sse3
2011-09-21 20:38:01 Info Maximum number of threads detected: 2 - parallelize up to 2
2011-09-21 20:38:01 Info Tuning Performances for Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz with 2 core(s) CPU
2011-09-21 20:38:01 Info System default language : English (United States)
2011-09-21 20:38:01 Info User default language : English (United States)
2011-09-21 20:38:01 Info Version : 4.1.19.365
2011-09-21 20:38:01 Info ExeName : C:\Program Files\VSO\ConvertX\4\ConvertXtoDvd.exe
2011-09-21 20:38:01 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2011-09-21 20:37:59 ---- ******************** Log session start 2011-09-21 20:37:59.535 PID 2108**********************
here is the log:
Re: not enough capacity
Your log shows something really odd;
so...what that means and how can i fix'it?
It probably means that CX2D didn't know where to write the converted files on your hard drive so wrote nothing.
Have you set a working folder on the hard drive in Settings? Did you delete the working folder? Are you using a legal copy of the program?
[quote="ckhouston"]It probably means that CX2D didn't know where to write the converted files on your hard drive so wrote nothing.
Have you set a working folder on the hard drive in Settings? Did you delete the working folder? Are you using a legal copy of the program?[/quote]
As i said... the conversion process is finalized. The software (legal copy) creates a folder on my HDD aprox 2GB (you can't see that in log because i deleted the path from the log....but it exist on my HDD "C:\folder" this is the default location, and everything else in options is default )
I'm burning a series of episodes, it was working GREAT for 20 burns....now is not. i did't change anything on the computer or in the software. I know is odd...the folder exist (2gb), the software log shows 0 gb, and the error message ask for a 8 TB disk...
Thanks for your replys
For some reason it can't figure out total size of conversion unless you edited those?
Easy way is use CMD - dir /s >d:\listfile.txt (your path to conversion folder here)
then open d:\listfile.txt and copy paste information here. (file is in D: just because C: root is not accessible on all systems)
What folders are in that conversion targt folder and what do those folders contain?2011-09-21 20:57:57 Info Total size 0 Mb., Target size DVD5 4300 Mb., Occupation 0.00%
under
users/......./my documents/convertxtodvd/
is just 1 folder...the one with the name of the movie i'm trying to burn...this folder is 2.06Gb and contains menus and files for the DVD movie...ready to be burnt.
is just 1 folder, because, CX2D is deleting all the working folders after the burn is complete. i suppose, because the burn was not complete this time...the folder still exist. I deleted that folder, and restart the process again, but the same thing happens over and over
Something is really messed up if everything is as you described and you didn't edit the log line that says the converted size is 0 MB.
Try a Fresh install as described in the Announcement topic at the top of the forum.
And I would suggest that you go to Settings>Burning and UNCHECK the option to delete folders after successful burn. You can do that manually yourself if everything works out OK.
Also, don't delete items if you edit your log - it results in timings that aren't accurate and, in some circumstances. can therefore result in an incorrect diagnosis of a problem because of the incorrect information in the log being analyzed. If you don't want' people to know the title of the movie you're converting then just edit the title, don't delete the log line. And, as this is an experieced group and we don't care about the titles or sources of your videos you don't really have to edit them at all.
JoeB
JoeB
Filenames and sizes are important, just as important as unedited log.drakoo wrote:under
If you want this resolved then you must give required information.
Thanks everybody and especially CKHOUSTON for zooming in to my problem.
Like it appeared...the problem disappeared. Suddenly i can burn, the same mkv, on the same media, with the same burner and the same options. I guess talking about a problem really helps. :)
case closed
case closed
I have tried to burn the DVD that I have burned successfully before. But now it could not be burn because it is more then 6 GB and would not fit on usual DVD.
Any advice?
2014-06-20 02:02:24 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-20 02:02:24 Info BURN: Drive has Serial ATA physical interface
2014-06-20 02:02:24 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-20 02:02:24 Info Burned folder: "C:\Users\BOSS\Documents\ConvertOld Files\Masha & the Bear", Min. media size 6.21 Gb.
2014-06-20 01:56:53 ---- ***************** Encoding end **********************
2014-06-20 01:38:40 Info BURN: Disc ejected by user.
2014-06-20 01:38:38 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-20 01:38:28 Info BURN: Parsing disc ...
2014-06-20 01:38:22 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-20 01:38:22 Info BURN: Drive has Serial ATA physical interface
2014-06-20 01:38:22 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-20 01:38:22 Info Burned folder: "C:\Users\BOSS\Documents\ConvertXToDVD\Masha & the Bear\", Min. media size 6.08 Gb.
2014-06-20 01:38:22 Warning Total size 6230 Mb., Target size DVD5 4300 Mb. (Overflow 1930 Mb.), Occupation 144.89%
2014-06-20 01:38:22 Info Conversion completed in 00:17:04
2014-06-20 01:38:22 Info Rendering rate: 7.34 x Realtime
2014-06-20 01:38:22 Info DVD duration (incl. menus) 02:05:13 (~ 7513 sec.) - rendering time 00:17:04
2014-06-20 01:38:21 Warning Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
2014-06-20 01:38:20 Info Generated duration 7513.42 sec., expected 420.22 sec.
2014-06-20 01:38:17 Info 1 frames duplicated
2014-06-20 01:35:23 Info Previous Section duration: 06:58.760
2014-06-20 01:35:23 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:34:28 Info Previous Section duration: 06:52.720
2014-06-20 01:34:28 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:33:43 Info Previous Section duration: 06:59.360
2014-06-20 01:33:43 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:32:57 Info Previous Section duration: 07:00.160
2014-06-20 01:32:57 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:32:14 Info Previous Section duration: 06:41.320
2014-06-20 01:32:14 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:31:33 Info Previous Section duration: 07:00.360
2014-06-20 01:31:33 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:30:50 Info Previous Section duration: 06:51.240
2014-06-20 01:30:50 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:30:10 Info Previous Section duration: 06:54.200
2014-06-20 01:30:10 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:29:26 Info Previous Section duration: 06:50.120
2014-06-20 01:29:26 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:28:35 Info Previous Section duration: 06:54.680
2014-06-20 01:28:35 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:27:51 Info Previous Section duration: 06:55.880
2014-06-20 01:27:51 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:27:05 Info Previous Section duration: 07:00.880
2014-06-20 01:27:05 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:26:24 Info Previous Section duration: 06:53.160
2014-06-20 01:26:24 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:25:14 Info Previous Section duration: 06:47.280
2014-06-20 01:25:14 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:23:58 Info Previous Section duration: 06:49.200
2014-06-20 01:23:58 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:23:10 Info Previous Section duration: 07:51.720
2014-06-20 01:23:10 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:22:05 Info Previous Section duration: 06:50.440
2014-06-20 01:22:05 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-20 01:21:18 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 2 channels, 192 kb/s
2014-06-20 01:21:18 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 8647 kb/s, pulldown: 25.000 -> 29.97 Fps
2014-06-20 01:21:18 Info Encoding MPEG-2 with 2 threads
2014-06-20 01:21:18 Info Video processing: Linear (VSO) resampler (352*288)->(720*480) 2 threads
2014-06-20 01:21:18 Info Chapter sequences require 25.74 Mb. temp space
2014-06-20 01:21:18 ---- ************ Source file #1 END DETAILS ************
2014-06-20 01:21:18 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
2014-06-20 01:21:18 Info VIDEO Stream #1 : Video: mpeg2video (Main), yuv420p, 352x288 [PAR 16:11 DAR 16:9], 8000 kb/s, 25.00 FPS
2014-06-20 01:21:18 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-20 01:21:18 Info Logical file: C:\Users\BOSS\Downloads\Masha & the Bear\VTS_04_1.VOB - 2 file(s) 1.06 Gb.
2014-06-20 01:21:18 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-20 01:21:18 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2014-06-20 01:21:18 Info Video bitrate 0/8647/9008 Kbps (min/avg/max)
2014-06-20 01:21:18 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-20 01:21:18 ---- ======================= TITLESET #1 =======================
2014-06-20 01:21:18 Info 2 Stream(s) found - est. duration 00:06:44.224, reference 00:06:44.224
2014-06-20 01:21:18 Info Opening file "C:\Users\BOSS\Downloads\Masha & the Bear\VTS_04_1.VOB"
2014-06-20 01:21:18 Info #2 - "VTS_04_2.VOB"
2014-06-20 01:21:18 Info #1 - "VTS_04_1.VOB"
2014-06-20 01:21:18 Info Cluster of files opened:
2014-06-20 01:21:18 Info [x] Multicore support in resize
2014-06-20 01:21:18 Info Project size 4.17 Gb. (9.41 Mb. audio - 4.15 Gb. video)
2014-06-20 01:21:17 Info [ ] Don't fix audio gaps
2014-06-20 01:21:17 Info [ ] Engine Log
2014-06-20 01:21:17 Info [ ] 2-pass encoding
2014-06-20 01:21:17 Info Encoding preset: SP (Short Projects)
2014-06-20 01:21:17 ---- ****************** Encoding begin *******************
2014-06-20 01:21:17 ---- **************** Menu settings end ******************
2014-06-20 01:21:17 Info [x] Don't create title menu for single video
2014-06-20 01:21:17 Info [x] Return to title menu after titleset playback
2014-06-20 01:21:17 Info [x] Skip root menu initially
2014-06-20 01:21:17 Info [x] Play titles one after the other
2014-06-20 01:21:17 Info [x] Loop playback
2014-06-20 01:21:17 Info [x] Auto-start playback
2014-06-20 01:21:17 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2014-06-20 01:21:17 ---- *************** Menu settings begin *****************
2014-06-20 01:21:17 ---- **************** Burn settings end ******************
2014-06-20 01:21:17 Info Default speed selected: 4x
2014-06-20 01:21:17 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-20 01:21:17 Info BURN: Drive has Serial ATA physical interface
2014-06-20 01:21:17 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-20 01:21:17 Info [ ] Delete DVD folder after burn complete
2014-06-20 01:21:17 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2014-06-20 01:21:17 Info SAO setting: Automatic
2014-06-20 01:21:17 Info [x] Burn result to DVD / as ISO file in working folder
2014-06-20 01:21:17 ---- **************** Burn settings begin ****************
2014-06-20 01:16:01 Info BURN: Disc ejected by user.
2014-06-20 01:15:59 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-20 01:15:49 Info BURN: Parsing disc ...
2014-06-20 01:15:11 Info BURN: Disc ejected by user.
2014-06-20 01:15:09 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-20 01:15:08 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-20 01:15:08 Info BURN: Drive has Serial ATA physical interface
2014-06-20 01:15:08 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-20 01:15:08 Info Burned folder: "C:\Users\BOSS\Documents\ConvertOld Files\Masha & the Bear", Min. media size 6.21 Gb.
2014-06-19 16:22:56 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-19 16:22:46 Info BURN: Parsing disc ...
2014-06-19 13:55:15 Info BURN: Disc ejected by user.
2014-06-19 13:55:13 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-19 13:55:03 Info BURN: Parsing disc ...
2014-06-19 13:54:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-19 13:54:59 Info BURN: Drive has Serial ATA physical interface
2014-06-19 13:54:58 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-19 13:54:58 Info Burned folder: "C:\Users\BOSS\Documents\ConvertOld Files\Masha & the Bear", Min. media size 6.21 Gb.
2014-06-19 13:24:06 ---- ***************** Encoding end **********************
2014-06-19 03:40:28 Info BURN: Disc ejected by user.
2014-06-19 03:40:26 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-19 03:40:24 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-19 03:40:24 Info BURN: Drive has Serial ATA physical interface
2014-06-19 03:40:24 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-19 03:40:24 Info Burned folder: "C:\Users\BOSS\Documents\ConvertXToDVD\Masha & the Bear\", Min. media size 6.08 Gb.
2014-06-19 03:40:24 Warning Total size 6230 Mb., Target size DVD5 4300 Mb. (Overflow 1930 Mb.), Occupation 144.89%
2014-06-19 03:40:24 Info Conversion completed in 00:13:20
2014-06-19 03:40:24 Info Rendering rate: 9.38 x Realtime
2014-06-19 03:40:24 Info DVD duration (incl. menus) 02:05:13 (~ 7513 sec.) - rendering time 00:13:20
2014-06-19 03:40:23 Warning Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
2014-06-19 03:40:23 Info Generated duration 7513.42 sec., expected 420.22 sec.
2014-06-19 03:40:20 Info 1 frames duplicated
2014-06-19 03:39:02 Info Previous Section duration: 06:58.760
2014-06-19 03:39:02 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:38:15 Info Previous Section duration: 06:52.720
2014-06-19 03:38:15 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:37:33 Info Previous Section duration: 06:59.360
2014-06-19 03:37:33 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:36:49 Info Previous Section duration: 07:00.160
2014-06-19 03:36:49 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:36:08 Info Previous Section duration: 06:41.320
2014-06-19 03:36:08 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:35:31 Info Previous Section duration: 07:00.360
2014-06-19 03:35:31 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:34:50 Info Previous Section duration: 06:51.240
2014-06-19 03:34:50 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:34:14 Info Previous Section duration: 06:54.200
2014-06-19 03:34:14 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:33:34 Info Previous Section duration: 06:50.120
2014-06-19 03:33:34 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:32:48 Info Previous Section duration: 06:54.680
2014-06-19 03:32:48 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:32:07 Info Previous Section duration: 06:55.880
2014-06-19 03:32:07 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:31:25 Info Previous Section duration: 07:00.880
2014-06-19 03:31:25 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:30:51 Info Previous Section duration: 06:53.160
2014-06-19 03:30:51 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:30:03 Info Previous Section duration: 06:47.280
2014-06-19 03:30:03 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:29:09 Info Previous Section duration: 06:49.200
2014-06-19 03:29:09 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:28:35 Info Previous Section duration: 07:51.720
2014-06-19 03:28:35 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:27:48 Info Previous Section duration: 06:50.440
2014-06-19 03:27:48 Info New video section added because of timestamp reset to 00:00.000 in source
2014-06-19 03:27:03 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 2 channels, 192 kb/s
2014-06-19 03:27:03 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 8647 kb/s, pulldown: 25.000 -> 29.97 Fps
2014-06-19 03:27:03 Info Encoding MPEG-2 with 2 threads
2014-06-19 03:27:03 Info Video processing: Linear (VSO) resampler (352*288)->(720*480) 2 threads
2014-06-19 03:27:03 Info Chapter sequences require 25.74 Mb. temp space
2014-06-19 03:27:03 ---- ************ Source file #1 END DETAILS ************
2014-06-19 03:27:03 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
2014-06-19 03:27:03 Info VIDEO Stream #1 : Video: mpeg2video (Main), yuv420p, 352x288 [PAR 16:11 DAR 16:9], 8000 kb/s, 25.00 FPS
2014-06-19 03:27:03 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2014-06-19 03:27:03 Info Logical file: C:\Users\BOSS\Downloads\Masha & the Bear\VTS_04_1.VOB - 2 file(s) 1.06 Gb.
2014-06-19 03:27:03 ---- *********** Source file #1 BEGIN DETAILS ***********
2014-06-19 03:27:03 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2014-06-19 03:27:03 Info Video bitrate 0/8647/9008 Kbps (min/avg/max)
2014-06-19 03:27:03 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2014-06-19 03:27:03 ---- ======================= TITLESET #1 =======================
2014-06-19 03:27:03 Info 2 Stream(s) found - est. duration 00:06:44.224, reference 00:06:44.224
2014-06-19 03:27:03 Info Opening file "C:\Users\BOSS\Downloads\Masha & the Bear\VTS_04_1.VOB"
2014-06-19 03:27:03 Info #2 - "VTS_04_2.VOB"
2014-06-19 03:27:03 Info #1 - "VTS_04_1.VOB"
2014-06-19 03:27:03 Info Cluster of files opened:
2014-06-19 03:27:03 Info [x] Multicore support in resize
2014-06-19 03:27:03 Info Project size 4.17 Gb. (9.41 Mb. audio - 4.15 Gb. video)
2014-06-19 03:27:03 Info [ ] Don't fix audio gaps
2014-06-19 03:27:03 Info [ ] Engine Log
2014-06-19 03:27:03 Info [ ] 2-pass encoding
2014-06-19 03:27:03 Info Encoding preset: SP (Short Projects)
2014-06-19 03:27:03 ---- ****************** Encoding begin *******************
2014-06-19 03:27:03 ---- **************** Menu settings end ******************
2014-06-19 03:27:03 Info [x] Don't create title menu for single video
2014-06-19 03:27:03 Info [x] Return to title menu after titleset playback
2014-06-19 03:27:03 Info [x] Skip root menu initially
2014-06-19 03:27:03 Info [x] Play titles one after the other
2014-06-19 03:27:03 Info [x] Loop playback
2014-06-19 03:27:02 Info [x] Auto-start playback
2014-06-19 03:27:02 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2014-06-19 03:27:02 ---- *************** Menu settings begin *****************
2014-06-19 03:27:02 ---- **************** Burn settings end ******************
2014-06-19 03:27:02 Info Default speed selected: 4x
2014-06-19 03:27:02 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-19 03:27:02 Info BURN: Drive has Serial ATA physical interface
2014-06-19 03:27:02 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-19 03:27:02 Info [ ] Delete DVD folder after burn complete
2014-06-19 03:27:02 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2014-06-19 03:27:02 Info SAO setting: Automatic
2014-06-19 03:27:02 Info [x] Burn result to DVD / as ISO file in working folder
2014-06-19 03:27:02 ---- **************** Burn settings begin ****************
2014-06-19 03:26:50 Warning File "VTS_04_2.VOB" ignored. It is already in the titleset.
2014-06-19 03:25:01 Info BURN: Disc ejected by user.
2014-06-19 03:24:59 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-19 03:24:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-19 03:24:59 Info BURN: Drive has Serial ATA physical interface
2014-06-19 03:24:59 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-19 03:24:59 Info Burned folder: "C:\Users\BOSS\Documents\ConvertOld Files\Masha & the Bear", Min. media size 6.21 Gb.
2014-06-19 03:24:45 Info BURN: Writable disc DVD-R inserted. Ready to write
2014-06-19 03:24:44 Info 37 Menu templates loaded.
2014-06-19 03:24:43 Info BURN: 1 writer(s) found.
2014-06-19 03:24:43 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.17.485]
2014-06-19 03:24:43 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2014-06-19 03:24:43 Info BURN: Drive has Serial ATA physical interface
2014-06-19 03:24:43 Info BURN: New Drive selected : 1:0:0 - HL-DT-ST DVDRAM GH70N UGA0 [E] (Ide)
2014-06-19 03:24:43 Info BURN: Using Advanced SPTI interface
2014-06-19 03:24:43 Info Supported instruction set: sse4
2014-06-19 03:24:43 Info Maximum number of threads detected: 4 - parallelize up to 4
2014-06-19 03:24:43 Info Tuning Performances for Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz with 4 core(s) CPU
2014-06-19 03:24:43 Info System default language : English (United States)
2014-06-19 03:24:43 Info User default language : English (United States)
2014-06-19 03:24:43 Info Version : 4.1.19.365
2014-06-19 03:24:43 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDVD.exe
2014-06-19 03:24:43 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2014-06-19 03:24:42 ---- ******************** Log session start 2014-06-19 03:24:42.832 PID 5428********************
Any advice?
Something is wrong with your source.
You can try to update to last v4 version, link is in sticky threads.
Timestamp resetting multiple times causes CxD to miscalculate.2014-06-19 03:40:23 Warning Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
