PreRelease v4.1.17.362: Text-Profiles-Window still "Cut Off"
mue.mat
Post by mue.mat » Fri Apr 22, 2011 8:25 am
Hello again
I'm using the latest version ConvertXtoDVD Pre-Release v4.1.17.362
This version still has the problem with the Text-Profiles-Editor. While opening the text-profiles-window (= writing-styles-window) the lower part of this opening window is cut-off; the window shows properly about a little more than 2/3 and then you get a grey rectangle that covers the "OK"-button. You are unable to change anything in the menu. Oder versions (until v4.1.12.352) are working properly with text profiles.
Should be nice and helpful fixing this bug soon.
Mue
Slickinator
Re: PreRelease v4.1.17.362: Text-Profiles-Window still "Cut
Post by Slickinator » Fri Apr 22, 2011 11:02 am
make sure with all these new releases to use cleanvso and do fresh installs as i notice if you don't it will hold some of the settinsg from previous versions even if the fix is done...as a note
JoeB
Post by JoeB » Fri Apr 22, 2011 5:00 pm
Claire has said that this particular bug has not yet been fixed, and she isn't aware of when it will be. If you had read the version history that is posted with the new releases you would see that this bug fix is not shown as having been fixed. You will just have to read the version history that is posted with each new build until you see one that shows this bug fix, then download and install that version.
JoeB
Post by Claire » Tue Apr 26, 2011 12:52 pm
Please try this new version and confirm that the subtitle editor problem has been fixed
Version 4.1.18.363
http://download.vso-software.fr/vsoConv ... elease.exe
You might need to clean the cache of your browser to get the right download file.
Ametista
Post by Ametista » Tue Apr 26, 2011 6:17 pm
Many thanks
its ok, now!
http://i54.tinypic.com/2zrlxmo.jpg
mue.mat
Post by mue.mat » Wed Apr 27, 2011 6:03 am
That's right, now everything's working fine.
The bug is fixed and with new Pre-Release-Version v4.1.18.363 the text-profiles-editor is working perfectly again.
Thanks a lot for working hard.
Mue
Post by Claire » Wed Apr 27, 2011 7:39 am
ok, thanks very much for confirming.
