The infamous "audio format changed in stream #1" p
CenaIsGod
Post by CenaIsGod » Fri Apr 02, 2010 3:46 pm
So I've been getting this a lot lately, and even though I have "do not fix audio discontinuities" box ticked, it seems to still be doing just that, as towards the end of each DVD I've burned, they'll go like a second or so out of sync. :? What's happening?
2010-04-02 04:02:38 ---- ******************** Log session stop 2010-04-02 04:02:38.636 PID 3676********************
2010-04-02 04:02:28 ---- ***************** Encoding end **********************
2010-04-02 04:02:28 Info BURN: No disc in drive.
2010-04-02 04:02:26 Info Conversion failed after 01:32:58
2010-04-02 04:02:25 Info User requested cancellation
2010-04-02 03:59:57 Info Chapter #10 start at 45:0.160
2010-04-02 03:58:22 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:58:22 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:56:55 Info Chapter #9 start at 40:0.280
2010-04-02 03:55:22 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:55:22 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:54:09 Info Chapter #8 start at 35:0.280
2010-04-02 03:51:26 Info Chapter #7 start at 30:0.360
2010-04-02 03:48:33 Info Chapter #6 start at 25:0.320
2010-04-02 03:47:24 Info Audio format changed in stream #1: was "8.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:47:24 Info Audio format changed in stream #1: was "11.0 khz, 1 Ch., S16 samples" -> now "8.0 khz, 2 Ch., S16 samples"
2010-04-02 03:47:24 Info Audio format changed in stream #1: was "11.0 khz, 2 Ch., S16 samples" -> now "11.0 khz, 1 Ch., S16 samples"
2010-04-02 03:47:24 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "11.0 khz, 2 Ch., S16 samples"
2010-04-02 03:45:43 Info Chapter #5 start at 20:0.320
2010-04-02 03:41:40 Info Chapter #4 start at 15:0.320
2010-04-02 03:40:40 Info Audio format changed in stream #1: was "48.0 khz, 1 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:40:40 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 1 Ch., S16 samples"
2010-04-02 03:40:40 Info Audio format changed in stream #1: was "16.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:40:40 Info Audio format changed in stream #1: was "44.1 khz, 2 Ch., S16 samples" -> now "16.0 khz, 2 Ch., S16 samples"
2010-04-02 03:40:40 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "44.1 khz, 2 Ch., S16 samples"
2010-04-02 03:38:15 Info Chapter #3 start at 10:0.320
2010-04-02 03:34:59 Info Chapter #2 start at 5:0.280
2010-04-02 03:32:06 Info Audio settings: Automatic With DTS -> AC-3 conversion
2010-04-02 03:32:06 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2010-04-02 03:32:06 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], q=3-31, 2803 kb/s, frame compensation: 29.970 -> 25.00 Fps
2010-04-02 03:32:06 Info Video processing: Linear (VSO) resampler (352*240)->(720*576)
2010-04-02 03:32:06 Info Chapter sequences require 315 Mb. temp space
2010-04-02 03:32:06 ---- ************ Source file #1 END DETAILS ************
2010-04-02 03:32:06 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
2010-04-02 03:32:06 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 352x240 [PAR 1:1 DAR 22:15], 29.97 FPS
2010-04-02 03:32:06 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2010-04-02 03:32:06 Info Logical file: C:\Users\Dan\Videos\RAW 2006\RAW - July 17th, 2006.avi - 1 file(s) 568 Mb.
2010-04-02 03:32:06 ---- *********** Source file #1 BEGIN DETAILS ***********
2010-04-02 03:32:06 Info Video bitrate 0/2803/9608 Kbps (min/avg/max)
2010-04-02 03:32:06 Info OUTPUT ==> Resolution: FULL D1 [720*576], Format: PAL, Aspect ratio: 4:3
2010-04-02 03:32:06 ---- ======================= TITLESET #2 =======================
2010-04-02 03:32:06 Info Generated duration 5996.00 sec., expected 5989.60 sec.
2010-04-02 03:31:00 Info 29343 frames dropped
2010-04-02 03:31:00 Info 2 frames duplicated
2010-04-02 03:26:38 Info Chapter #20 start at 95:0.120
2010-04-02 03:23:36 Info Chapter #19 start at 90:0.360
2010-04-02 03:20:23 Info Chapter #18 start at 85:0.040
2010-04-02 03:19:48 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:19:48 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:17:19 Info Chapter #17 start at 80:0.040
2010-04-02 03:16:17 Info Audio format changed in stream #1: was "44.1 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:16:16 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "44.1 khz, 2 Ch., S16 samples"
2010-04-02 03:16:16 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:16:16 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:16:14 Info Audio format changed in stream #1: was "24.0 khz, 1 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:16:14 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "24.0 khz, 1 Ch., S16 samples"
2010-04-02 03:13:55 Info Chapter #16 start at 75:0.200
2010-04-02 03:11:01 Info Chapter #15 start at 70:0.160
2010-04-02 03:10:29 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 03:10:29 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 03:07:25 Info Chapter #14 start at 65:0.000
2010-04-02 03:04:07 Info Chapter #13 start at 60:0.280
2010-04-02 03:00:41 Info Chapter #12 start at 55:0.320
2010-04-02 02:57:14 Info Chapter #11 start at 50:0.120
2010-04-02 02:54:03 Info Chapter #10 start at 45:0.120
2010-04-02 02:50:13 Info Chapter #9 start at 40:0.280
2010-04-02 02:46:54 Info Chapter #8 start at 35:0.040
2010-04-02 02:44:37 Info Chapter #7 start at 30:0.440
2010-04-02 02:41:47 Info Chapter #6 start at 25:0.000
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "48.0 khz, 1 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "32.0 khz, 2 Ch., S16 samples" -> now "48.0 khz, 1 Ch., S16 samples"
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "44.1 khz, 2 Ch., S16 samples" -> now "32.0 khz, 2 Ch., S16 samples"
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "32.0 khz, 1 Ch., S16 samples" -> now "44.1 khz, 2 Ch., S16 samples"
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "44.1 khz, 1 Ch., S16 samples" -> now "32.0 khz, 1 Ch., S16 samples"
2010-04-02 02:40:39 Info Audio format changed in stream #1: was "48.0 khz, 2 Ch., S16 samples" -> now "44.1 khz, 1 Ch., S16 samples"
2010-04-02 02:38:59 Info Chapter #5 start at 20:0.240
2010-04-02 02:36:55 Info Chapter #4 start at 15:0.000
2010-04-02 02:34:29 Info Chapter #3 start at 10:0.360
2010-04-02 02:31:43 Info Chapter #2 start at 5:0.280
2010-04-02 02:29:28 Info Audio format changed in stream #1: was "32.0 khz, 1 Ch., S16 samples" -> now "48.0 khz, 2 Ch., S16 samples"
2010-04-02 02:29:28 Info Audio format changed in stream #1: was "44.1 khz, 1 Ch., S16 samples" -> now "32.0 khz, 1 Ch., S16 samples"
2010-04-02 02:29:27 Info Audio settings: Automatic With DTS -> AC-3 conversion
2010-04-02 02:29:27 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2010-04-02 02:29:27 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], q=3-31, 2750 kb/s, frame compensation: 29.970 -> 25.00 Fps
2010-04-02 02:29:27 Info Video processing: Linear (VSO) resampler (352*240)->(720*576)
2010-04-02 02:29:27 Info Chapter sequences require 331 Mb. temp space
2010-04-02 02:29:27 ---- ************ Source file #1 END DETAILS ************
2010-04-02 02:29:27 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
2010-04-02 02:29:27 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 352x240 [PAR 1:1 DAR 22:15], 29.97 FPS
2010-04-02 02:29:27 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2010-04-02 02:29:27 Info Logical file: C:\Users\Dan\Videos\RAW 2006\RAW - July 10th, 2006.avi - 1 file(s) 591 Mb.
2010-04-02 02:29:27 ---- *********** Source file #1 BEGIN DETAILS ***********
2010-04-02 02:29:27 Info Video bitrate 0/2750/9608 Kbps (min/avg/max)
2010-04-02 02:29:27 Info OUTPUT ==> Resolution: FULL D1 [720*576], Format: PAL, Aspect ratio: 4:3
2010-04-02 02:29:27 ---- ======================= TITLESET #1 =======================
2010-04-02 02:29:27 Info 2 Stream(s) found - est. duration 01:34:29.153, reference 01:34:29.153
2010-04-02 02:29:27 Info Opening file "C:\Users\Dan\Videos\RAW 2006\RAW - July 17th, 2006.avi"
2010-04-02 02:29:27 Info 2 Stream(s) found - est. duration 01:38:29.596, reference 01:38:29.596
2010-04-02 02:29:27 Info Opening file "C:\Users\Dan\Videos\RAW 2006\RAW - July 10th, 2006.avi"
2010-04-02 02:29:26 Info [ ] Multicore support in resize
2010-04-02 02:29:26 Info Project size 4.17 Gb. (270 Mb. audio - 3.89 Gb. video)
2010-04-02 02:29:26 Info [x] Don't fix audio gaps
2010-04-02 02:29:26 Info [ ] Engine Log
2010-04-02 02:29:26 Info [ ] 2-pass encoding
2010-04-02 02:29:26 Info Encoding preset: LP - Large project
2010-04-02 02:29:26 ---- ****************** Encoding begin *******************
2010-04-02 02:29:26 ---- **************** Menu settings end ******************
2010-04-02 02:29:26 Info [x] Don't create title menu for single video
2010-04-02 02:29:26 Info [x] Return to title menu after titleset playback
2010-04-02 02:29:26 Info [x] Skip root menu initially
2010-04-02 02:29:26 Info [ ] Play titles one after the other
2010-04-02 02:29:26 Info [ ] Loop playback
2010-04-02 02:29:26 Info [ ] Auto-start playback
2010-04-02 02:29:26 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2010-04-02 02:29:26 ---- *************** Menu settings begin *****************
2010-04-02 02:29:26 ---- **************** Burn settings end ******************
2010-04-02 02:29:26 Info Default speed selected: 4x
2010-04-02 02:29:26 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-04-02 02:29:26 Info BURN: Drive has IDE-ATAPI physical interface
2010-04-02 02:29:26 Info BURN: New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ-861H 1.50 [D] (Ide)
2010-04-02 02:29:26 Info [x] Delete DVD folder after burn complete
2010-04-02 02:29:26 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2010-04-02 02:29:26 Info SAO setting: Automatic
2010-04-02 02:29:26 Info [ ] Add original files to DVD (if possible)
2010-04-02 02:29:26 Info [x] Burn result to DVD
2010-04-02 02:29:26 ---- **************** Burn settings begin ****************
2010-04-02 02:28:16 Info 36 Menu templates loaded.
2010-04-02 02:28:14 Info BURN: No disc in drive.
2010-04-02 02:28:12 Info BURN: 1 writer(s) found.
2010-04-02 02:28:12 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\4\vso_hwe.dll" [4.0.5.464]
2010-04-02 02:28:12 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-04-02 02:28:12 Info BURN: Drive has IDE-ATAPI physical interface
2010-04-02 02:28:12 Info BURN: New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ-861H 1.50 [D] (Ide)
2010-04-02 02:28:12 Info BURN: Using Advanced SPTI interface
2010-04-02 02:28:12 Info Supported instruction set: sse3
2010-04-02 02:28:12 Info Maximum number of threads detected: 1
2010-04-02 02:28:12 Info Tuning Performances for Intel(R) Celeron(R) CPU 550 @ 2.00GHz with 1 core(s) CPU
2010-04-02 02:28:12 Info System default language : English (United Kingdom)
2010-04-02 02:28:12 Info User default language : English (United Kingdom)
2010-04-02 02:28:12 Info Version : 4.0.4.313
2010-04-02 02:28:12 Info ExeName : C:\Program Files\VSO\ConvertX\4\ConvertXtoDvd.exe
2010-04-02 02:28:12 Info OS : Microsoft Windows Vista Home Basic (Build 6002: Service Pack 2)
2010-04-02 02:28:08 ---- ******************** Log session start 2010-04-02 02:28:08.538 PID 3676********************
Post by JJ » Fri Apr 02, 2010 5:19 pm
Update to latest version and try again.
If still no luck, try other files.
Audioformat should not change that much.
eldinv
Post by eldinv » Fri Apr 02, 2010 11:24 pm
i thought u should have the "dont fix audio gaps" uncheck... and then if there are gaps, its your sources.
or like previously said, try updating to new version, though i dont think thats going to help
rohn
Re: The infamous "audio format changed in stream #1" p
Post by rohn » Sat May 03, 2014 6:40 pm
This happens each time a new version has come out. A wave of Audio format errors floods the countries. Why fix the problem when we can get a few more euro's.
I have never complained about the VSO, but there are quite a few issues that they are just plain lazy about. i.e. Changing the title, you have to close the program and reopen or your DVD will have the last movie's name on it. Small, and stupid yes, but a pain for a world class software program. Subtitles, I have asked many times why even free software can show the real position of subtitles, when your adjusting them. But it is too difficult for our favorite company.
This audio issue is one more reason to go with watching streaming scaled up from laptop to big screen. The DVD/subtitling era is going the way. It is still hard to criticize VSO for wanting me to upgrade and give them what is given to the collection plate each Sat or Sunday. Because over the last ten years, I have filled all the drawers in my house with foreign films that I would have never watched without the internet, subtitlers and ConvertX. I just would like the company, I mean their programming dept to be as responsive as say the front office taking our call's and emails. To them I say "no european summers, fix the issues"; and they'll "wait till the next version". Thats the VSO way,
Post by JJ » Sat May 03, 2014 6:53 pm
4 years after last post and few years since last v4 version came out and you are complaining
Ok, you can complain.
But - this issue has been covered many times and v5 is much more reliable in these situations.
And to make it absolutely clear; this problem has nothing to do with VSO.
This is caused by those who encode movies with incompatible streams.
