BatchXtoDVD - software to do batch conversions with ConvertX
cmsoft
Post by cmsoft » Mon Feb 15, 2010 10:57 am
BatchXtoDVD is available for download from http://beta.cmsoft.co.uk
It works in very much the same way as ConvertXBatch, and it has been designed to look the same too for the sake of familiarity.
However, there are some differences. First of all, if you have more than one version of ConvertXtoDVD installed, BatchXtoDVD will by default select Version the newest - BUT you can choose to use an earlier version if you wish.
BatchXtoDVD will work quite happily with FileLists on Vista regardless of whether or not UAC is enabled (ConvertXBatch would not save filelists on Vista if UAC was enabled).
BatchXtoDVD uses the ConvertXtoDVD registry settings. If you choose between using V2, V3 and V4, the correct settings are loaded for that version.
I would be very grateful for any feedback, comments, suggestions etc. Bug reports can be filed at http://bugs.cmsoft.co.uk
AND if anyone would like to take on the task of writing the help file, then I would be a very happy person :-)
eldinv
Post by eldinv » Sun Mar 28, 2010 2:09 am
im looking into this now... i have several AVI ready to be converted, but i dont have time to do these one at a time, lol...
the settings on this application under encoding section dont appear to work with this new version.
under the encoding quality, says low, med, and high and in new version of convertx there are not the same. so i hope it works right...
dlsmd
Post by dlsmd » Sun May 30, 2010 11:20 pm
if you build the project with cx2dvd first the load the saved files it will work without the settings needing to be changed in batchx2dvd
eskro
Post by eskro » Fri Jun 18, 2010 7:59 pm
is this project dead? :(
dlsmd
Post by dlsmd » Thu Aug 05, 2010 3:39 am
no
eskro
Post by eskro » Thu Aug 05, 2010 3:49 am
dlsmd wrote:no
yes it is
farrukhalvi
Post by farrukhalvi » Sun Oct 31, 2010 9:07 am
the file is corrupt. and plzz give a fresh link for batchxtodvd here.
eskro
Re: BatchXtoDVD - software to do batch conversions with Conv
Post by eskro » Fri Mar 04, 2011 3:04 am
project dead
urie
Post by urie » Wed Mar 09, 2011 12:17 pm
eskro wrote:project dead
no project is not dead check out this thread.http://forums.vso-software.fr/batch2dvd-t13674.html
otiz
Post by otiz » Wed Jul 06, 2011 1:36 pm
I want to convert movie files to DVD using a batch file. created with command line parameters can I set the text title to dvd?
scarmullet
Post by scarmullet » Thu Jul 14, 2011 8:29 am
here is a small command line script that can be used, just drop the project files you want done into the same folder as these and click "Convert Saved Projects" if you are on a 32 bit OS, you may have to go into the "encode" object and change where ConvertXtoDVD.exe is located (the install directory).
http://www.box.net/shared/q3v09bzkrql9x34z7xd3
crunkmunky2
Post by crunkmunky2 » Fri Sep 02, 2011 7:14 am
check out my website...
no im not spamming yall
My way of batch converting is really simple, its stupid simple actually.
[url]http://www.swagna.com/2011/09/02/batch- ... ertxtodvd/[/url]
there r no downloads, viruses or drive by downloads, just usefull info on how to Batch Convert without that [b]BS script![/b]
Any q's?
hit me up on my website!
Post by JJ » Fri Sep 02, 2011 7:35 am
crunkmunky2: this method has been used way before BatchX - it has also been discussed numerous times.
Your instructions are good except for one thing; using timecritical can make your system unresponsive, unstable and actually slow down total conversion.
peter7769
Post by peter7769 » Thu Mar 08, 2012 3:14 pm
Can anyone help on using this program :?
Pete
peter7769
Post by peter7769 » Mon Mar 19, 2012 9:23 pm
Anyone watching this thread??
Pete :(
urie
Post by urie » Tue Mar 20, 2012 2:54 pm
peter7769 wrote:Anyone watching this thread??
Pete :(
What is your problem with BatchXtoDVD ?
peter7769
Post by peter7769 » Tue Mar 20, 2012 7:33 pm
Well from what i can see its this... i make my DVD project using convertx then i save this as a project, but it seems that when i then open BatchXtoDVD and then click on Add pre-made project it seems that no matter what template and settings i have used in making the original project using convertx they seem to get over written with the settings in BatchX, like the Default Menu Template & the Encoding quality!
Is this by design or am i doing something wrong??
Pete
urie
Post by urie » Thu Mar 22, 2012 11:28 am
When you load in a pre made project and go to setting page menu template is blank do not click on it or it will change remember and to save settings.
peter7769
Post by peter7769 » Fri Mar 23, 2012 6:39 pm
Thanks very much, i will give it a try.
Pete
nashboy
Post by nashboy » Mon Mar 26, 2012 12:49 pm
hi
im having the same problem as peter7769 of the batch software not loading the saved project as was saved in convertxtodvd;the titles i typed in the original get overwritten. kud u clearly repeate how to go abt it
