Convertxtodvd WRITE ERROR
weeteentybean84
Post by weeteentybean84 » Mon Feb 13, 2012 7:37 pm
Hello all, I am brand new to these forums so please be gentle and nice :P
I am using convertxtodvd version 4.. And i used to use 3 but i updated it. I am trying to burn discs (dvds) but there seems to be some issue recently when there wasnt before :/
I will post my log file but before i do so i'd like to say which discs i am using
Maxwell DVD+R
Asda DVD-R
Kodak DVD + R RW
Here is the log report
**************** Burn settings end ******************
2012-02-13 19:25:33 Info Default speed selected: 4x
2012-02-13 19:25:33 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-02-13 19:25:33 Info BURN: Drive has Serial ATA physical interface
2012-02-13 19:25:33 Info BURN: New Drive selected : 0:1:0 - Slimtype DVD A DS8A4SH CA11 [D] (Ide)
2012-02-13 19:25:33 Info [x] Delete DVD folder after burn complete
2012-02-13 19:25:33 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2012-02-13 19:25:33 Info SAO setting: Automatic
2012-02-13 19:25:33 Info [ ] Add original files to DVD (if possible)
2012-02-13 19:25:33 Info [x] Burn result to DVD / as ISO file in working folder
2012-02-13 19:25:33 ---- **************** Burn settings begin ****************
2012-02-13 19:20:27 Error BURN: WRITE FAILED: Can't find write strategy at sector 16
2012-02-13 19:20:20 Error BURN: Write error at 0 (16) - Code 03 73 03 [Medium error, Power calibration fail (CD-burner is dirty)]
2012-02-13 19:20:00 Info BURN: Write started 1238208 sectors to write
2012-02-13 19:20:00 Info BURN: Init success: DVD+R
2012-02-13 19:20:00 Info BURN: Writing speed requested x4.0, effective x4.0
2012-02-13 19:20:00 Info BURN: Available write speed: 8x ,6x ,4x ,2.4x
2012-02-13 19:20:00 Info BURN: Media ID: AML-003-00
2012-02-13 19:20:00 Info BURN: Media type: DVD+R
2012-02-13 19:20:00 Info BURN: PIO Mode
2012-02-13 19:20:00 Info BURN: Scanned files #9, folder #2 - total size 2534746112 b. (2.36 Gb.)
2012-02-13 19:20:00 Info BURN: Inserted media type : DVD+R
2012-02-13 19:20:00 ---- ***************** Encoding end **********************
2012-02-13 19:20:00 Info Disc name: "My DVD"
2012-02-13 19:19:52 Info BURN: Writable disc DVD+R inserted. Ready to write
2012-02-13 19:19:46 Info BURN: Parsing disc ...
2012-02-13 19:17:19 Info BURN: No disc in drive.
2012-02-13 19:17:17 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-02-13 19:17:17 Info BURN: Drive has Serial ATA physical interface
2012-02-13 19:17:17 Info BURN: New Drive selected : 0:1:0 - Slimtype DVD A DS8A4SH CA11 [D] (Ide)
2012-02-13 19:17:17 Info Burned folder: "C:\Users\Buttontoes\Documents\ConvertXToDVD\kti.xvid\", Min. media size 2.36 Gb.
2012-02-13 19:17:17 Info Total size 2417 Mb., Target size DVD5 4300 Mb., Occupation 56.22%
2012-02-13 19:17:17 Info Conversion completed in 00:34:24
2012-02-13 19:17:17 Info Rendering rate: 3.01 x Realtime
2012-02-13 19:17:17 Info DVD duration (incl. menus) 01:43:41 (~ 6221 sec.) - rendering time 00:34:24
2012-02-13 19:17:17 Info Generated duration 6221.28 sec., expected 6214.92 sec.
2012-02-13 19:16:24 Info P-SDT buffer Underflow 1 times, 285 bytes peak
2012-02-13 19:16:24 Info 7 frames duplicated
2012-02-13 19:14:34 Info Chapter #21 start at 100:0.280
2012-02-13 19:13:31 Info Chapter #20 start at 95:0.240
2012-02-13 19:12:03 Info Chapter #19 start at 90:0.200
2012-02-13 19:10:37 Info Chapter #18 start at 85:0.160
2012-02-13 19:09:09 Info Chapter #17 start at 80:0.120
2012-02-13 19:07:50 Info Chapter #16 start at 75:0.080
2012-02-13 19:06:19 Info Chapter #15 start at 70:0.040
2012-02-13 19:04:56 Info Chapter #14 start at 65:0.000
2012-02-13 19:03:26 Info Chapter #13 start at 60:0.480
2012-02-13 19:01:42 Info Chapter #12 start at 55:0.440
2012-02-13 18:59:58 Info Chapter #11 start at 50:0.400
2012-02-13 18:58:17 Info Chapter #10 start at 45:0.360
2012-02-13 18:56:51 Info Chapter #9 start at 40:0.320
2012-02-13 18:55:25 Info Chapter #8 start at 35:0.280
2012-02-13 18:53:45 Info Chapter #7 start at 30:0.240
2012-02-13 18:52:13 Info Chapter #6 start at 25:0.200
2012-02-13 18:50:21 Info Chapter #5 start at 20:0.160
2012-02-13 18:48:18 Info Chapter #4 start at 15:0.120
2012-02-13 18:46:29 Info Chapter #3 start at 10:0.080
2012-02-13 18:45:00 Info Chapter #2 start at 5:0.040
2012-02-13 18:42:53 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, s16, 448 kb/s
2012-02-13 18:42:53 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=2-31, 5134 kb/s, frame compensation: 25.000 -> 25.00 Fps
2012-02-13 18:42:53 Info Video processing: Pad (Left:0 - Top:8 - Right:0 - Bottom:8)
2012-02-13 18:42:53 Info Video processing: Linear (VSO) resampler (704*384)->(720*560) 2 threads
2012-02-13 18:42:53 Info Chapter sequences require 347 Mb. temp space
2012-02-13 18:42:53 ---- ************ Source file #1 END DETAILS ************
2012-02-13 18:42:53 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
2012-02-13 18:42:53 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 704x384 [PAR 1:1 DAR 11:6], 25.00 FPS
2012-02-13 18:42:53 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2012-02-13 18:42:53 Info Logical file: G:\Kill.the.Irishman.2011.DVDRip.AC3.XviD-CM8\kti.xvid.avi - 1 file(s) 1.36 Gb.
2012-02-13 18:42:53 ---- *********** Source file #1 BEGIN DETAILS ***********
2012-02-13 18:42:53 Info Video bitrate 0/5134/9352 Kbps (min/avg/max)
2012-02-13 18:42:53 Info OUTPUT ==> Resolution: FULL D1 [720*576], Format: PAL, Aspect ratio: 16:9
2012-02-13 18:42:53 ---- ======================= TITLESET #1 =======================
2012-02-13 18:42:53 Info 2 Stream(s) found - est. duration 01:42:14.920, reference 01:42:14.920
2012-02-13 18:42:53 Info Opening file "G:\Kill.the.Irishman.2011.DVDRip.AC3.XviD-CM8\kti.xvid.avi"
2012-02-13 18:42:53 Info [x] Multicore support in resize
2012-02-13 18:42:53 Info Project size 4.17 Gb. (333 Mb. audio - 3.83 Gb. video)
2012-02-13 18:42:53 Info [ ] Don't fix audio gaps
2012-02-13 18:42:53 Info [ ] Engine Log
2012-02-13 18:42:53 Info [ ] 2-pass encoding
2012-02-13 18:42:53 Info Encoding preset: MP (Medium Projects)
2012-02-13 18:42:53 ---- ****************** Encoding begin *******************
2012-02-13 18:42:53 ---- **************** Menu settings end ******************
2012-02-13 18:42:53 Info [x] Don't create title menu for single video
2012-02-13 18:42:53 Info [x] Return to title menu after titleset playback
2012-02-13 18:42:53 Info [x] Skip root menu initially
2012-02-13 18:42:53 Info [ ] Play titles one after the other
2012-02-13 18:42:53 Info [ ] Loop playback
2012-02-13 18:42:53 Info [ ] Auto-start playback
2012-02-13 18:42:53 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2012-02-13 18:42:53 ---- *************** Menu settings begin *****************
2012-02-13 18:42:53 ---- **************** Burn settings end ******************
2012-02-13 18:42:53 Info Default speed selected: 4x
2012-02-13 18:42:53 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-02-13 18:42:53 Info BURN: Drive has Serial ATA physical interface
2012-02-13 18:42:53 Info BURN: New Drive selected : 0:1:0 - Slimtype DVD A DS8A4SH CA11 [D] (Ide)
2012-02-13 18:42:53 Info [x] Delete DVD folder after burn complete
2012-02-13 18:42:53 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2012-02-13 18:42:53 Info SAO setting: Automatic
2012-02-13 18:42:53 Info [ ] Add original files to DVD (if possible)
2012-02-13 18:42:53 Info [x] Burn result to DVD / as ISO file in working folder
2012-02-13 18:42:53 ---- **************** Burn settings begin ****************
2012-02-13 18:42:04 Info 36 Menu templates loaded.
2012-02-13 18:42:04 Info BURN: No disc in drive.
2012-02-13 18:42:02 Info BURN: 1 writer(s) found.
2012-02-13 18:42:02 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.7.466]
2012-02-13 18:42:02 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-02-13 18:42:02 Info BURN: Drive has Serial ATA physical interface
2012-02-13 18:42:02 Info BURN: New Drive selected : 0:1:0 - Slimtype DVD A DS8A4SH CA11 [D] (Ide)
2012-02-13 18:42:02 Info BURN: Using Advanced SPTI interface
2012-02-13 18:42:02 Info Supported instruction set: sse3
2012-02-13 18:42:02 Info Maximum number of threads detected: 2
2012-02-13 18:42:02 Info Tuning Performances for Celeron(R) Dual-Core CPU T3100 @ 1.90GHz with 2 core(s) CPU
2012-02-13 18:42:02 Info System default language : English (United Kingdom)
2012-02-13 18:42:02 Info User default language : English (United Kingdom)
2012-02-13 18:42:02 Info Version : 4.0.9.322
2012-02-13 18:42:02 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2012-02-13 18:42:02 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-02-13 18:42:00 ---- ******************** Log session start 2012-02-13 18:42:00.318 PID 1452
