problem "burning an already converted project"
discussions about ConvertXtoDVD latest versions, avi to dvd video converter software, burns videos from your PC to watch on your DVD with menus and subtitles.
Moderators: Cougar_II, ckhouston, JJ, Claire, Forum admin
Postby psychomajic666 » Fri Sep 04, 2009 9:24 pm
This happened before. I uninstalled, reinstalled about 5 times & it started working (after messing up about 10 disks).
Now out of nowhere it's done it again. The burner sounds like it's starting up then stopping over & over.
Nothing was changed, all my settings are exactly the way I've had them.
My drivers are updated & the burner is working, as I tested burning a disk using other software.
Why is my ConvertXToDVD doing this? It was working last night & as I said - nothing was changed.
2009-08-31 22:17:51 ---- ******************** Log session stop 2009-08-31 22:17:51.378 PID 3832********************
2009-08-31 18:27:53 Info BURN: Media removed. Burning layer not ready to write
2009-08-31 18:20:03 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 18:18:57 Info BURN: Media removed. Burning layer not ready to write
2009-08-31 18:10:15 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 18:10:12 Info BURN: Parsing new media
2009-08-31 18:08:44 Info BURN: Media removed. Burning layer not ready to write
2009-08-31 18:03:56 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 18:01:43 Info BURN: Media removed. Burning layer not ready to write
2009-08-31 18:00:33 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 17:59:36 Error BURN: WRITE FAILED: Write aborted by user
2009-08-31 17:57:33 Info BURN: Lead-in burning time (mS) 0
2009-08-31 17:57:07 Info BURN: Write started 1083440 sectors to write
2009-08-31 17:57:07 Info BURN: Init success: DVD+R
2009-08-31 17:57:07 Info BURN: Writing speed requested x6.0, effective x6.0
2009-08-31 17:57:07 Info BURN: Available write speed: 16x, 12x, 8x, 6x
2009-08-31 17:57:07 Info BURN: Media ID: SONY-D21-00
2009-08-31 17:57:07 Info BURN: Media type: DVD+R
2009-08-31 17:57:07 Info BURN: Scanned files #12, folder #2 - total size 2217777152 b. (2.07 Gb.)
2009-08-31 17:57:07 Info BURN: Inserted media type : DVD+R
2009-08-31 17:57:06 Info Disc name: "Drag Me To Hell - I Sell The Dea"
2009-08-31 17:57:06 Info Burned folder: "C:\Users\Belial De Sade\Videos\ConvertXtoDVD\Drag Me To Hell - I Sell The Dead\VIDEO_TS"
2009-08-31 17:57:02 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 17:56:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2009-08-31 17:56:59 Info BURN: Drive has Serial ATA physical interface
2009-08-31 17:56:59 Info BURN: New Drive selected : 1:1:0 - ATAPI DVD A DH16A6L-C ZHCG [E] (Scsi)
2009-08-31 17:56:39 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 17:56:39 Info 36 Menu templates loaded.
2009-08-31 17:56:37 Info BURN: 1 writer(s) found.
2009-08-31 17:56:37 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\3\vso_hwe.dll" [4.0.0.424]
2009-08-31 17:56:37 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2009-08-31 17:56:37 Info BURN: Drive has Serial ATA physical interface
2009-08-31 17:56:37 Info BURN: New Drive selected : 1:1:0 - ATAPI DVD A DH16A6L-C ZHCG [E] (Scsi)
2009-08-31 17:56:37 Info BURN: Using Advanced SPTI interface
2009-08-31 17:56:36 Info Supported instruction set: sse4
2009-08-31 17:56:36 Info Number of allocatable threads: 4
2009-08-31 17:56:36 Info Tuning Performances for AMD Phenom(tm) 9550 Quad-Core Processor with 4 core(s) CPU
2009-08-31 17:56:36 Info System default language : English (United States)
2009-08-31 17:56:36 Info User default language : English (United States)
2009-08-31 17:56:36 Info Version : 3.8.0.193
2009-08-31 17:56:36 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\3\ConvertXtoDVD.exe
2009-08-31 17:56:36 Info OS : Microsoft Windows Vista Home Premium (Build 6001: Service Pack 1)
2009-08-31 17:56:34 ---- ******************** Log session start 2009-08-31 17:56:34.294 PID 3832********************
hope this helps.
Again, I put in a blank DVD, chose "burn already converted project", & the progress bar wouldn't move & the drive sounded like it was starting up & stopping continuously.
I thought I'd ad this one because it might shed some light as to what's going on.
I noticed it noted a "minor warning" (whatever that could be)....
2009-08-31 01:40:34 ---- ******************** Log session stop 2009-08-31 01:40:34.436 PID 6092********************
2009-08-31 01:12:59 Info BURN: WRITE SUCCESS: Burn process successful with minor warning
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:54]: Finalisation complete
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:54]: Close disc - Completed with warning "Code 00 00 00 [No sense information.]"
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:37]: Closing disc
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:37]: Close track - Completed with success
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:33]: Closing track
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:33]: Flush device cache - Completed with success
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:24]: Flushing device cache
2009-08-31 01:12:59 Info BURN: FINALISATION [ 1:12:24]: finalisation started
2009-08-31 01:12:59 Warning BURN: Finalization Time 00:00:35 - Total completion time 00:08:46 - finalisation report follow
2009-08-31 01:12:24 Info BURN: Write finished in 00:08:11 - Finalization start here. Avg. burn rate 6.33
2009-08-31 01:04:32 Info BURN: Lead-in burning time (mS) 0
2009-08-31 01:04:12 Info BURN: Write started 1916944 sectors to write
2009-08-31 01:04:12 Info BURN: Init success: DVD+R
2009-08-31 01:04:12 Info BURN: Writing speed requested x6.0, effective x6.0
2009-08-31 01:04:12 Info BURN: Available write speed: 16x, 12x, 8x, 6x
2009-08-31 01:04:12 Info BURN: Media ID: SONY-D21-00
2009-08-31 01:04:12 Info BURN: Media type: DVD+R
2009-08-31 01:04:11 Info BURN: Scanned files #14, folder #2 - total size 3924774912 b. (3.66 Gb.)
2009-08-31 01:04:11 Info BURN: Inserted media type : DVD+R
2009-08-31 01:04:11 Info BURN: Write started
2009-08-31 01:04:11 Info Disc name: "Dog Eat Dog - Taken In Broad Day"
2009-08-31 01:04:11 Info Burned folder: "C:\Users\Belial De Sade\Videos\ConvertXtoDVD\Dog Eat Dog - Taken In Broad Daylight\VIDEO_TS"
2009-08-31 01:04:11 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 01:04:08 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2009-08-31 01:04:08 Info BURN: Drive has Serial ATA physical interface
2009-08-31 01:04:08 Info BURN: New Drive selected : 1:1:0 - ATAPI DVD A DH16A6L-C ZHCG [E] (Scsi)
2009-08-31 01:03:51 Info 36 Menu templates loaded.
2009-08-31 01:03:48 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
2009-08-31 01:03:46 Info BURN: 1 writer(s) found.
2009-08-31 01:03:46 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\3\vso_hwe.dll" [4.0.0.424]
2009-08-31 01:03:46 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2009-08-31 01:03:46 Info BURN: Drive has Serial ATA physical interface
2009-08-31 01:03:46 Info BURN: New Drive selected : 1:1:0 - ATAPI DVD A DH16A6L-C ZHCG [E] (Scsi)
2009-08-31 01:03:46 Info BURN: Using Advanced SPTI interface
2009-08-31 01:03:45 Info Supported instruction set: sse4
2009-08-31 01:03:45 Info Number of allocatable threads: 4
2009-08-31 01:03:45 Info Tuning Performances for AMD Phenom(tm) 9550 Quad-Core Processor with 4 core(s) CPU
2009-08-31 01:03:44 Info System default language : English (United States)
2009-08-31 01:03:44 Info User default language : English (United States)
2009-08-31 01:03:44 Info Version : 3.8.0.193
2009-08-31 01:03:44 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\3\ConvertXtoDvd.exe
2009-08-31 01:03:44 Info OS : Microsoft Windows Vista Home Premium (Build 6001: Service Pack 1)
2009-08-31 01:03:41 ---- ******************** Log session start 2009-08-31 01:03:41.940 PID 6092********************
psychomajic666
Postby JoeB » Fri Sep 04, 2009 10:05 pm
You're posting today, Sept. 4, but your log is for attempts back on August 31.
JoeB
JoeB
Postby psychomajic666 » Sat Sep 05, 2009 1:36 am
Exactly. Noone answered my question then so I reposted it today.
So back to my question.
What could be preventing my software from recognising my burner?
psychomajic666
Postby JoeB » Sat Sep 05, 2009 2:38 am
psychomajic666 wrote:Exactly. Noone answered my question then so I reposted it today.
First, you don't have to repost the same issue. Just add another post to your existing thread to "bump" it up.
Second, your software does recognize your burner, as shown from your log:
My first thought would be that it has problems working with a SCSI drive, but I can't say that for a fact.
My first suggestion is to download the free ImgBurn and try to burn the converted video with it. If that works, it will at least show that the issue is with the ConvertX burning engine.
If ImgBurn works, my next suggestion would be to completely remove ConvertX using the VSO Clean tool available on their site (and I believe a link to it is in one of the Stickies), download the latest version of ConvertX, reinstall, and try again. I don't think you have the latest updated version (I use v.2 so can't confirm).
Please report back once you've tried these options.
JoeB
JoeB
Postby psychomajic666 » Sat Sep 05, 2009 2:49 am
I've been using Cyberlink DVD Suite to burn after ConvertXToDVD would not burn anymore. So I'm certain by burner works, it's just CXTDVD.
My burner used to say (Raid) where it now says (Scsi). I don't know why this changed or how to set it back to whatever had it working before.
You're using v.2? The version I'm using is 3.8.0.193
psychomajic666
Postby JoeB » Sat Sep 05, 2009 3:28 am
psychomajic666 wrote:I've been using Cyberlink DVD Suite to burn after ConvertXToDVD would not burn anymore. So I'm certain by burner works, it's just CXTDVD.
I can't say why your burner would show a change in identification, but maybe somebody else can help you there.
Yes, I use v.2.2.3.258, which is the latest v.2. I don't need fancy menu stuff. I put one video on one DVD-5, and I create my own background image for the menu image, which is usually created from the DVD cover so already has the film Title, to which I often add the names of the main actors - all done in a graphic editor. So all I need to show on the Menu image with ConvertX is the word "Play" - unless I add extras, in which case I do two menu items, the second saying "Extras". So I've never bothered upgrading because it doesn't give me anything else I need :-)
By the way, I've never had burner issues, DVD playback issues, or any other issues with my ConvertX version and using Taiyo Yuden DVD-5 media :-)
JoeB
JoeB
Postby psychomajic666 » Sat Sep 05, 2009 6:24 am
Well, thanks for the help anyway.
I might check out some older versions & try my luck on those.
psychomajic666
Return to ConvertXtoDVD old version 3.x
  • Related topics
    Replies
    Views
    Last post
Who is online
Users browsing this forum: Google [Bot] and 4 guests
