DVD-RW dsk won't copy using copy to.
Burning software suite: burn CD / DVD / Blu-Ray, data, movies, photos, audio, ISO files
orkney
Post by orkney » Sun Apr 20, 2008 12:14 am
I have 2 burners 1. Plextor 716A 2. Sony DRU-840A both will erase info on a SONY DVD-RW Disk using "Copy to DVD" but neither will burn video clips to disk. Media player 11 and Media Classic say theres nothing there. Also when I put disk into Pioneer DVD recorder 510H it shows no writing on disk. I have tried copy to dvd 4 and copy to dvd se, also roxio software disk that came with Sony 840A. Always the same. Going on 2 months now. I can get a DVD-R to copy a movie and play on Pioneer. And can get DVD-R disk to copy video clips, using "divxtodvd" but only can be seen on Media Classic Player or WMP 11, but not on Pioneer 510H. Old DVD-RW burner worked fine in old computer, but after intall of 840A problems began. Just finished building new computer. Same problems. Software? RAM? mobo (MSI K9N plat)? XP PRO conspiracy?? RAM hooked to IDE. Just ordered new LITE-ON for SATA hookup. My hard drive are SATA. Could that be it? If I buy a store bought computer would that solve the problem?? Help!! Mr Desperate
Post by Cougar_II » Sun Apr 20, 2008 11:06 pm
Provide us a burn log (Even failed one).
We can see what media you are using, firmware revision on your burner etc...
Read my quick burning guide:
http://forums.vso-software.fr/burning-p ... -t123.html
orkney
Post by orkney » Mon Apr 21, 2008 4:09 am
I look at hints. I believe I have done all. I have no problems with 1 click dvd pro. burns fine to dvd-r plays on dvd recorder. sending log for convert x to dvd and copy to dvd se. Burning seems to occur since there are writing marks on disk but nothing reads them. Using 2 different burners as previously stated.. Thanks for any help you can give me, orkney
********* CONVERT X TO DVD*******
4/20/2008 8:15:54 PM info ********** Report session closed ***********
4/20/2008 8:15:31 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 8:12:39 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 8:10:36 PM info Folder C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\ has been removed
4/20/2008 8:10:36 PM info BURN: Finalization Time 00:00:42 - Total completion time 00:03:46
4/20/2008 8:10:36 PM info BURN: WRITE SUCCESS
4/20/2008 8:09:53 PM info BURN: Write finished in 00:03:03 - Finalization start here. Avg. burn rate 2.20
4/20/2008 8:06:50 PM info BURN: Lead-in burning time (mS) 0
4/20/2008 8:06:50 PM info BURN: Write started 248112 sectors to write
4/20/2008 8:06:50 PM info BURN: Writing speed requested x2.0, effective x2.0
4/20/2008 8:06:50 PM info BURN: Format completed
4/20/2008 8:05:50 PM info BURN: Format start
4/20/2008 8:05:50 PM info BURN: Available write speed: 2x
4/20/2008 8:05:50 PM info BURN: Media ID: RITEKW01
4/20/2008 8:05:50 PM info BURN: Media type: DVD-RW Sequential
4/20/2008 8:05:50 PM info BURN: DMA Mode
4/20/2008 8:05:47 PM info BURN: Scanned files #19, folder #2 - total size 507006976 b. (484 Mb.)
4/20/2008 8:05:47 PM info BURN: Inserted media type : DVD-RW Sequential
4/20/2008 8:05:47 PM info BURN: Write started
4/20/2008 8:05:47 PM info --------------Encoding end--------------
4/20/2008 8:05:47 PM info Disc name: "My DVD"
4/20/2008 8:05:47 PM info Burned folder: "C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\"
4/20/2008 8:05:40 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 8:05:37 PM info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
4/20/2008 8:05:37 PM info BURN: New Drive selected : 1:0:0 - SONY DVD RW DRU-840A SS01 [D] (Ide)
4/20/2008 8:05:37 PM info Total size 483 Mb., Target size DVD5 4300 Mb., Occupation 11.24%
4/20/2008 8:05:37 PM info Conversion completed in 00:06:20
4/20/2008 8:05:37 PM info Rendering rate: 2.19 x Realtime
4/20/2008 8:05:37 PM info DVD duration (incl. menus) 00:13:52 (~ 832 sec.) - rendering time 00:06:20
4/20/2008 8:04:21 PM info Generated duration 208.94 sec., expected 208.87 sec.
4/20/2008 8:03:46 PM info 4 frames dropped
4/20/2008 8:02:46 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 8:02:46 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 8:02:46 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 8:02:46 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 8:02:46 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 8:02:46 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, frame compensation: 29.970 -> 29.97 Fps
4/20/2008 8:02:46 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 8:02:46 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 8:02:46 PM info ****** Source file #1 END DETAILS ******
4/20/2008 8:02:46 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 8:02:46 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 30.00 FPS
4/20/2008 8:02:46 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 8:02:46 PM info C:\JIM\Needs converting from dvx to dvd\4.flv
4/20/2008 8:02:46 PM info ******** Source file #1 DETAILS ********
4/20/2008 8:02:46 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 8:02:46 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 8:02:46 PM info ----------------Title #4----------------
4/20/2008 8:02:46 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 8:02:46 PM info Generated duration 219.42 sec., expected 219.36 sec.
4/20/2008 8:01:27 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 8:01:27 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 8:01:27 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 8:01:27 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 8:01:27 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 8:01:27 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 8:01:27 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 8:01:27 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 8:01:27 PM info ****** Source file #1 END DETAILS ******
4/20/2008 8:01:27 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 8:01:27 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 8:01:27 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 8:01:27 PM info C:\JIM\Needs converting from dvx to dvd\3.flv
4/20/2008 8:01:27 PM info ******** Source file #1 DETAILS ********
4/20/2008 8:01:27 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 8:01:27 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 8:01:27 PM info ----------------Title #3----------------
4/20/2008 8:01:27 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 8:01:27 PM info Generated duration 89.15 sec., expected 89.08 sec.
4/20/2008 8:00:39 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 8:00:39 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 8:00:39 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 8:00:39 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 8:00:39 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 8:00:39 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 8:00:39 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 8:00:39 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 8:00:39 PM info ****** Source file #1 END DETAILS ******
4/20/2008 8:00:39 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 8:00:39 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 8:00:39 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 8:00:39 PM info C:\JIM\Needs converting from dvx to dvd\2.flv
4/20/2008 8:00:39 PM info ******** Source file #1 DETAILS ********
4/20/2008 8:00:39 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 8:00:39 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 8:00:39 PM info ----------------Title #2----------------
4/20/2008 8:00:39 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 8:00:39 PM info Generated duration 254.46 sec., expected 254.40 sec.
4/20/2008 7:59:17 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 7:59:17 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 7:59:17 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 7:59:17 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 7:59:17 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 7:59:17 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 7:59:17 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 7:59:17 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:59:17 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 7:59:17 PM info ****** Source file #1 END DETAILS ******
4/20/2008 7:59:17 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 7:59:17 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 7:59:17 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 7:59:17 PM info C:\JIM\Needs converting from dvx to dvd\1.flv
4/20/2008 7:59:17 PM info ******** Source file #1 DETAILS ********
4/20/2008 7:59:17 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 7:59:17 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 7:59:17 PM info ----------------Title #1----------------
4/20/2008 7:59:17 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 7:59:17 PM info 2 Stream(s) found - est. duration 00:02:58.867, reference 00:02:58.867
4/20/2008 7:59:17 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\4.flv"
4/20/2008 7:59:17 PM info 2 Stream(s) found - est. duration 00:03:09.360, reference 00:03:09.360
4/20/2008 7:59:17 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\3.flv"
4/20/2008 7:59:17 PM info 2 Stream(s) found - est. duration 00:00:59.080, reference 00:00:59.080
4/20/2008 7:59:17 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\2.flv"
4/20/2008 7:59:17 PM info 2 Stream(s) found - est. duration 00:03:44.400, reference 00:03:44.400
4/20/2008 7:59:17 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\1.flv"
4/20/2008 7:59:17 PM info Project size 4.17 Gb. (15.2 Mb. audio - 4.14 Gb. video)
4/20/2008 7:59:17 PM info [ ] Don't fix audio gaps
4/20/2008 7:59:17 PM info [ ] Engine Log
4/20/2008 7:59:17 PM info Encoder quality: 100%
4/20/2008 7:59:17 PM info --------------Encoding begin--------------
4/20/2008 7:59:17 PM info --------------Menu settings end--------------
4/20/2008 7:59:17 PM info [X] Skip root menu
4/20/2008 7:59:17 PM info [ ] Play videos one after the other
4/20/2008 7:59:17 PM info [ ] Loop playback
4/20/2008 7:59:17 PM info [ ] Play video automatically (skip menu)
4/20/2008 7:59:17 PM info Template: Default, simple menu, contains 4 page(s), 13 customizable element(s)
4/20/2008 7:59:17 PM info --------------Menu settings begin--------------
4/20/2008 7:59:17 PM info --------------Burn settings end--------------
4/20/2008 7:59:17 PM info No default writer set
4/20/2008 7:59:17 PM info [X] Delete files after burn complete
4/20/2008 7:59:17 PM info [ ] Don't eject after burn complete
4/20/2008 7:59:17 PM info SAO setting: Automatic
4/20/2008 7:59:17 PM info [ ] Include originals
4/20/2008 7:59:17 PM info [X] Burn result to DVD
4/20/2008 7:59:17 PM info --------------Burn settings begin--------------
4/20/2008 7:59:02 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 7:59:01 PM info 30 Menu templates loaded.
4/20/2008 7:59:00 PM info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
4/20/2008 7:59:00 PM info Supported instruction set: sse3
4/20/2008 7:59:00 PM info Tuning Performances for AMD Athlon(tm) X2 Dual Core Processor BE-2300 with 2 core(s) CPU
4/20/2008 7:59:00 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:58:59 PM info User default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:58:59 PM info System default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:58:59 PM info Version 3.0.0.9
4/20/2008 7:58:59 PM info ExeName : "C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe"
4/20/2008 7:58:59 PM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
4/20/2008 7:58:58 PM info ******************** Report session started ********************
4/20/2008 7:54:45 PM info ********** Report session closed ***********
4/20/2008 7:54:19 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 7:52:42 PM info Folder C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\ has been removed
4/20/2008 7:52:42 PM info BURN: Finalization Time 00:00:39 - Total completion time 00:01:39
4/20/2008 7:52:42 PM info BURN: WRITE SUCCESS
4/20/2008 7:52:03 PM info BURN: Write finished in 00:01:00 - Finalization start here. Avg. burn rate 2.18
4/20/2008 7:51:03 PM info BURN: Lead-in burning time (mS) 1
4/20/2008 7:51:02 PM info BURN: Write started 81312 sectors to write
4/20/2008 7:51:02 PM info BURN: Writing speed requested x2.0, effective x2.0
4/20/2008 7:51:02 PM info BURN: Format completed
4/20/2008 7:50:08 PM info BURN: Format start
4/20/2008 7:50:08 PM info BURN: Available write speed: 2x
4/20/2008 7:50:08 PM info BURN: Media ID: RITEKW01
4/20/2008 7:50:08 PM info BURN: Media type: DVD-RW
4/20/2008 7:50:08 PM info BURN: DMA Mode
4/20/2008 7:50:05 PM info BURN: Scanned files #11, folder #2 - total size 165412864 b. (158 Mb.)
4/20/2008 7:50:05 PM info BURN: Inserted media type : DVD-RW
4/20/2008 7:50:05 PM info BURN: Write started
4/20/2008 7:50:05 PM info --------------Encoding end--------------
4/20/2008 7:50:05 PM info Disc name: "My DVD"
4/20/2008 7:50:05 PM info Burned folder: "C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\"
4/20/2008 7:49:21 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 7:48:01 PM info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
4/20/2008 7:48:01 PM info BURN: New Drive selected : 1:0:0 - SONY DVD RW DRU-840A SS01 [D] (Ide)
4/20/2008 7:48:01 PM info Total size 157 Mb., Target size DVD5 4300 Mb., Occupation 3.67%
4/20/2008 7:48:01 PM info Conversion completed in 00:02:45
4/20/2008 7:48:01 PM info Rendering rate: 2.26 x Realtime
4/20/2008 7:48:01 PM info DVD duration (incl. menus) 00:06:13 (~ 373 sec.) - rendering time 00:02:45
4/20/2008 7:47:24 PM info Generated duration 89.15 sec., expected 89.08 sec.
4/20/2008 7:46:38 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 7:46:38 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 7:46:38 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 7:46:38 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 7:46:38 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 7:46:38 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 7:46:38 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 7:46:38 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 7:46:38 PM info ****** Source file #1 END DETAILS ******
4/20/2008 7:46:38 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 7:46:38 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 7:46:38 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 7:46:38 PM info C:\JIM\Needs converting from dvx to dvd\2.flv
4/20/2008 7:46:38 PM info ******** Source file #1 DETAILS ********
4/20/2008 7:46:38 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 7:46:38 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 7:46:38 PM info ----------------Title #2----------------
4/20/2008 7:46:38 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 7:46:38 PM info Generated duration 254.46 sec., expected 254.40 sec.
4/20/2008 7:45:16 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 7:45:16 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 7:45:16 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 7:45:16 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 7:45:16 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 7:45:16 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 7:45:16 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 7:45:16 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:45:16 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 7:45:16 PM info ****** Source file #1 END DETAILS ******
4/20/2008 7:45:16 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 7:45:16 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 7:45:16 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 7:45:16 PM info C:\JIM\Needs converting from dvx to dvd\1.flv
4/20/2008 7:45:16 PM info ******** Source file #1 DETAILS ********
4/20/2008 7:45:16 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 7:45:16 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 7:45:16 PM info ----------------Title #1----------------
4/20/2008 7:45:16 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 7:45:16 PM info 2 Stream(s) found - est. duration 00:00:59.080, reference 00:00:59.080
4/20/2008 7:45:16 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\2.flv"
4/20/2008 7:45:16 PM info 2 Stream(s) found - est. duration 00:03:44.400, reference 00:03:44.400
4/20/2008 7:45:16 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\1.flv"
4/20/2008 7:45:16 PM info Project size 4.17 Gb. (6.6 Mb. audio - 4.15 Gb. video)
4/20/2008 7:45:16 PM info [ ] Don't fix audio gaps
4/20/2008 7:45:16 PM info [ ] Engine Log
4/20/2008 7:45:16 PM info Encoder quality: 100%
4/20/2008 7:45:16 PM info --------------Encoding begin--------------
4/20/2008 7:45:16 PM info --------------Menu settings end--------------
4/20/2008 7:45:16 PM info [X] Skip root menu
4/20/2008 7:45:16 PM info [ ] Play videos one after the other
4/20/2008 7:45:16 PM info [ ] Loop playback
4/20/2008 7:45:16 PM info [ ] Play video automatically (skip menu)
4/20/2008 7:45:16 PM info Template: Default, simple menu, contains 4 page(s), 13 customizable element(s)
4/20/2008 7:45:16 PM info --------------Menu settings begin--------------
4/20/2008 7:45:16 PM info --------------Burn settings end--------------
4/20/2008 7:45:16 PM info No default writer set
4/20/2008 7:45:16 PM info [X] Delete files after burn complete
4/20/2008 7:45:16 PM info [ ] Don't eject after burn complete
4/20/2008 7:45:16 PM info SAO setting: Automatic
4/20/2008 7:45:16 PM info [ ] Include originals
4/20/2008 7:45:16 PM info [X] Burn result to DVD
4/20/2008 7:45:16 PM info --------------Burn settings begin--------------
4/20/2008 7:44:44 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 7:44:43 PM info 30 Menu templates loaded.
4/20/2008 7:44:42 PM info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
4/20/2008 7:44:42 PM info Supported instruction set: sse3
4/20/2008 7:44:42 PM info Tuning Performances for AMD Athlon(tm) X2 Dual Core Processor BE-2300 with 2 core(s) CPU
4/20/2008 7:44:42 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:44:41 PM info User default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:44:41 PM info System default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:44:41 PM info Version 3.0.0.9
4/20/2008 7:44:41 PM info ExeName : "C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe"
4/20/2008 7:44:41 PM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
4/20/2008 7:44:41 PM info ******************** Report session started ********************
4/20/2008 7:37:09 PM info ********** Report session closed ***********
4/20/2008 7:36:57 PM info Folder C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\ has been removed
4/20/2008 7:36:57 PM info BURN: Finalization Time 00:02:51 - Total completion time 00:03:56
4/20/2008 7:36:57 PM info BURN: WRITE SUCCESS
4/20/2008 7:34:06 PM info BURN: Write finished in 00:01:05 - Finalization start here. Avg. burn rate 2.03
4/20/2008 7:33:14 PM info BURN: Lead-in burning time (mS) 13523
4/20/2008 7:33:01 PM info BURN: Write started 81312 sectors to write
4/20/2008 7:33:01 PM info BURN: Init success: DVD-R DAO
4/20/2008 7:33:01 PM info BURN: Writing speed requested x4.0, effective x4.0
4/20/2008 7:33:00 PM info BURN: Available write speed: 18x, 16x, 12x, 8x, 6x, 4x
4/20/2008 7:33:00 PM info BURN: Media ID: CMC MAG. AM3
4/20/2008 7:33:00 PM info BURN: Media type: DVD-R
4/20/2008 7:33:00 PM info BURN: DMA Mode
4/20/2008 7:32:58 PM info BURN: Scanned files #11, folder #2 - total size 165412864 b. (158 Mb.)
4/20/2008 7:32:58 PM info BURN: Inserted media type : DVD-R
4/20/2008 7:32:58 PM info BURN: Write started
4/20/2008 7:32:57 PM info --------------Encoding end--------------
4/20/2008 7:32:57 PM info Disc name: "My DVD"
4/20/2008 7:32:57 PM info Burned folder: "C:\Documents and Settings\JIM & IRENE\My Documents\ConvertXtoDVD\1\"
4/20/2008 7:32:43 PM info BURN: New media inserted. Burning layer is ready to write
4/20/2008 7:32:40 PM info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
4/20/2008 7:32:40 PM info BURN: New Drive selected : 1:0:0 - SONY DVD RW DRU-840A SS01 [D] (Ide)
4/20/2008 7:32:40 PM info Total size 157 Mb., Target size DVD5 4300 Mb., Occupation 3.67%
4/20/2008 7:32:40 PM info Conversion completed in 00:02:47
4/20/2008 7:32:40 PM info Rendering rate: 2.22 x Realtime
4/20/2008 7:32:40 PM info DVD duration (incl. menus) 00:06:13 (~ 373 sec.) - rendering time 00:02:47
4/20/2008 7:32:02 PM info Generated duration 89.15 sec., expected 89.08 sec.
4/20/2008 7:31:15 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 7:31:15 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 7:31:15 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 7:31:15 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 7:31:15 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 7:31:15 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 7:31:15 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 7:31:15 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 7:31:15 PM info ****** Source file #1 END DETAILS ******
4/20/2008 7:31:15 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 7:31:15 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 7:31:15 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 7:31:15 PM info C:\JIM\Needs converting from dvx to dvd\2.flv
4/20/2008 7:31:15 PM info ******** Source file #1 DETAILS ********
4/20/2008 7:31:15 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 7:31:15 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 7:31:15 PM info ----------------Title #2----------------
4/20/2008 7:31:15 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 7:31:15 PM info Generated duration 254.46 sec., expected 254.40 sec.
4/20/2008 7:29:52 PM info File #1 Stream #2 Sync. delay : 0.00 ms
4/20/2008 7:29:52 PM info File #1 Stream #1 Sync. delay : 0.00 ms
4/20/2008 7:29:52 PM info Starting at 00:00:00.000 (0 µS)
4/20/2008 7:29:52 PM info ********** Stream delay(s) for playback position 1 **********
4/20/2008 7:29:52 PM info Output Stream #2 (AUDIO) - ac3, 48000 Hz, mono, 192 kb/s
4/20/2008 7:29:52 PM info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 9127 kb/s, pulldown: 25.000 -> 29.97 Fps
4/20/2008 7:29:52 PM info Video processing: Fast bilinear resampler (320*240)->(720*480)
4/20/2008 7:29:52 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:29:52 PM info Chapter sequences require 40.2 Mb. temp space
4/20/2008 7:29:52 PM info ****** Source file #1 END DETAILS ******
4/20/2008 7:29:52 PM info Stream #2 (AUDIO): Audio: mp3, 22050 Hz, mono, 8 kb/s
4/20/2008 7:29:52 PM info Stream #1 (VIDEO): Video: flv, yuv420p, 320x240, 25.00 FPS
4/20/2008 7:29:52 PM info Type: Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
4/20/2008 7:29:52 PM info C:\JIM\Needs converting from dvx to dvd\1.flv
4/20/2008 7:29:52 PM info ******** Source file #1 DETAILS ********
4/20/2008 7:29:52 PM info Video bitrate 0/9127/9608 Kbps (min/avg/max)
4/20/2008 7:29:52 PM info Resolution, TV standard, TV Screen: FULL D1 [720*480], ntsc, 4:3
4/20/2008 7:29:52 PM info ----------------Title #1----------------
4/20/2008 7:29:52 PM info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
4/20/2008 7:29:52 PM info 2 Stream(s) found - est. duration 00:00:59.080, reference 00:00:59.080
4/20/2008 7:29:52 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\2.flv"
4/20/2008 7:29:52 PM info 2 Stream(s) found - est. duration 00:03:44.400, reference 00:03:44.400
4/20/2008 7:29:52 PM info Opening file "C:\JIM\Needs converting from dvx to dvd\1.flv"
4/20/2008 7:29:52 PM info Project size 4.17 Gb. (6.6 Mb. audio - 4.15 Gb. video)
4/20/2008 7:29:52 PM info [ ] Don't fix audio gaps
4/20/2008 7:29:52 PM info [ ] Engine Log
4/20/2008 7:29:52 PM info Encoder quality: 100%
4/20/2008 7:29:52 PM info --------------Encoding begin--------------
4/20/2008 7:29:52 PM info --------------Menu settings end--------------
4/20/2008 7:29:52 PM info [X] Skip root menu
4/20/2008 7:29:52 PM info [ ] Play videos one after the other
4/20/2008 7:29:52 PM info [ ] Loop playback
4/20/2008 7:29:52 PM info [ ] Play video automatically (skip menu)
4/20/2008 7:29:52 PM info Template: Default, simple menu, contains 4 page(s), 13 customizable element(s)
4/20/2008 7:29:52 PM info --------------Menu settings begin--------------
4/20/2008 7:29:52 PM info --------------Burn settings end--------------
4/20/2008 7:29:52 PM info No default writer set
4/20/2008 7:29:52 PM info [X] Delete files after burn complete
4/20/2008 7:29:52 PM info [ ] Don't eject after burn complete
4/20/2008 7:29:52 PM info SAO setting: Automatic
4/20/2008 7:29:52 PM info [ ] Include originals
4/20/2008 7:29:52 PM info [X] Burn result to DVD
4/20/2008 7:29:52 PM info --------------Burn settings begin--------------
4/20/2008 7:29:17 PM info 30 Menu templates loaded.
4/20/2008 7:29:15 PM info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
4/20/2008 7:29:15 PM info Supported instruction set: sse3
4/20/2008 7:29:15 PM info Tuning Performances for AMD Athlon(tm) X2 Dual Core Processor BE-2300 with 2 core(s) CPU
4/20/2008 7:29:15 PM warning DirectX preview interface is not available (filter obsolete, please reinstall).
4/20/2008 7:29:15 PM info User default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:29:15 PM info System default language : 1033 (0x0409h) - English (United States)
4/20/2008 7:29:15 PM info Version 3.0.0.9
4/20/2008 7:29:15 PM info ExeName : "C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe"
4/20/2008 7:29:15 PM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
4/20/2008 7:29:14 PM info ******************** Report session started ********************
******2nd COPY TO DVD LOG:
4/20/2008 8:41:12 PM info ******************** Report session closed *********************
4/20/2008 8:41:12 PM critical Process cancelled
4/20/2008 8:41:00 PM info Write completed
4/20/2008 8:41:00 PM info Average speed 1.17x Reference 1x = 1352.00 kbps
4/20/2008 8:41:00 PM info Total burning time 00:01:27.750
4/20/2008 8:40:58 PM info Sending anonymous statistics...
4/20/2008 8:39:30 PM info Lead-in burning time (mS) 94
4/20/2008 8:39:30 PM info Start Write Buffer
4/20/2008 8:39:30 PM info Start writing...
4/20/2008 8:39:30 PM info Drive Timing: DMA Mode
4/20/2008 8:39:30 PM info Buffer under-run proof enabled
4/20/2008 8:39:30 PM info Writing speed requested x2.0, effective x2.0
4/20/2008 8:38:37 PM info Writing session #1 and closing disc.
4/20/2008 8:38:37 PM info Open Image file "C:\Documents and Settings\JIM & IRENE\Application Data\CopyToDvd\COPYTODVD_04202008_203837_796.cache"
4/20/2008 8:38:37 PM info Required sector size : 60592
4/20/2008 8:38:37 PM info Available sector size : 2298496
4/20/2008 8:38:37 PM info Available write speed: 2x
4/20/2008 8:38:37 PM info Media ID: RITEKW01
4/20/2008 8:38:37 PM info Volume name: "New_Disc"
4/20/2008 8:38:37 PM info 120mm DVD
4/20/2008 8:38:37 PM info Detected media $0013 : DVD-RW
4/20/2008 8:38:37 PM warning Multisession setting ignored, DVD RW media doesn't provide support for multisession
4/20/2008 8:38:37 PM info Finished browsing files - Data size 118 Mb.
4/20/2008 8:38:37 PM info File scan complete: 5 files, 0 directories
4/20/2008 8:38:37 PM info Start Browsing file structures
4/20/2008 8:38:37 PM info IDE Controler manufacturer : (Standard IDE ATA/ATAPI controllers)
4/20/2008 8:38:37 PM info IDE Controler Description : Standard Dual Channel PCI IDE Controller
4/20/2008 8:38:37 PM info Location : PCI bus 0, device 4, function 0
4/20/2008 8:38:37 PM info Support Media : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
4/20/2008 8:38:37 PM info Writing device used : 1:0:0 - SONY DVD RW DRU-840A SS01 [D] (Ide)
4/20/2008 8:38:37 PM info Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
4/20/2008 8:38:37 PM info Using File/Directory list.
4/20/2008 8:38:37 PM info ParamStr 4 = "/writespeed=2.0"
4/20/2008 8:38:37 PM info ParamStr 3 = "/writedevice=D"
4/20/2008 8:38:37 PM info ParamStr 2 = "/volumename=New_Disc"
4/20/2008 8:38:37 PM info ParamStr 1 = "/datafl=C:\Documents and Settings\JIM & IRENE\Application Data\Vso\~c2c_fl.tmp"
4/20/2008 8:38:37 PM info ParamStr 0 = "C:\PROGRA~1\VSO\COPYTO~1\CopyToCD.exe"
4/20/2008 8:38:37 PM info User default language : 1033 (0x0409h) - English (United States)
4/20/2008 8:38:37 PM info System default language : 1033 (0x0409h) - English (United States)
4/20/2008 8:38:37 PM info Version 4.0.4.60
4/20/2008 8:38:37 PM info ExeName : "C:\PROGRA~1\VSO\COPYTO~1\CopyToCD.exe"
4/20/2008 8:38:37 PM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
4/20/2008 8:38:37 PM info 32 bits native system
4/20/2008 8:38:37 PM info ******************** Report session started ********************
4/20/2008 8:31:33 PM info ******************** Report session closed *********************
4/20/2008 8:31:33 PM critical Process cancelled
4/20/2008 8:31:12 PM info Write completed
4/20/2008 8:31:12 PM info Average speed 0.17x Reference 1x = 1352.00 kbps
4/20/2008 8:31:12 PM info Total burning time 00:01:19.047
4/20/2008 8:31:02 PM info Sending anonymous statistics...
4/20/2008 8:29:57 PM info Lead-in burning time (mS) 13568
4/20/2008 8:29:43 PM info Start Write Buffer
4/20/2008 8:29:43 PM info Start writing...
4/20/2008 8:29:43 PM info Drive Timing: DMA Mode
4/20/2008 8:29:43 PM info Buffer under-run proof enabled
4/20/2008 8:29:43 PM info Init success: DVD-R packet writing
4/20/2008 8:29:43 PM info Writing speed requested x8.0, effective x8.0
4/20/2008 8:29:43 PM info Writing session #1 and keeping disc writable.
4/20/2008 8:29:43 PM info Open Image file "C:\Documents and Settings\JIM & IRENE\Application Data\CopyToDvd\COPYTODVD_04202008_202943_328.cache"
4/20/2008 8:29:43 PM info Required sector size : 12752
4/20/2008 8:29:43 PM info Available sector size : 2297888
4/20/2008 8:29:43 PM info Available write speed: 16x, 12x, 8x, 6x, 4x
4/20/2008 8:29:43 PM info Media ID: MJC M005
4/20/2008 8:29:43 PM info Multisession is enabled in filesystem
4/20/2008 8:29:43 PM info Volume name: "New_Disc"
4/20/2008 8:29:43 PM info 120mm DVD
4/20/2008 8:29:43 PM info Detected media $0011 : DVD-R
4/20/2008 8:29:43 PM info Finished browsing files - Data size 24.5 Mb.
4/20/2008 8:29:43 PM info File scan complete: 2 files, 0 directories
4/20/2008 8:29:43 PM info Start Browsing file structures
4/20/2008 8:29:43 PM info IDE Controler manufacturer : (Standard IDE ATA/ATAPI controllers)
4/20/2008 8:29:43 PM info IDE Controler Description : Standard Dual Channel PCI IDE Controller
4/20/2008 8:29:43 PM info Location : PCI bus 0, device 4, function 0
4/20/2008 8:29:43 PM info Support Media : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
4/20/2008 8:29:43 PM info Writing device used : 1:0:0 - SONY DVD RW DRU-840A SS01 [D] (Ide)
4/20/2008 8:29:43 PM info Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
4/20/2008 8:29:43 PM info Using File/Directory list.
4/20/2008 8:29:43 PM info ParamStr 4 = "/writespeed=8.0"
4/20/2008 8:29:43 PM info ParamStr 3 = "/writedevice=D"
4/20/2008 8:29:43 PM info ParamStr 2 = "/volumename=New_Disc"
4/20/2008 8:29:43 PM info ParamStr 1 = "/datafl=C:\Documents and Settings\JIM & IRENE\Application Data\Vso\~c2c_fl.tmp"
4/20/2008 8:29:43 PM info ParamStr 0 = "C:\PROGRA~1\VSO\COPYTO~1\CopyToCD.exe"
4/20/2008 8:29:43 PM info User default language : 1033 (0x0409h) - English (United States)
4/20/2008 8:29:43 PM info System default language : 1033 (0x0409h) - English (United States)
4/20/2008 8:29:43 PM info Version 4.0.4.60
4/20/2008 8:29:43 PM info ExeName : "C:\PROGRA~1\VSO\COPYTO~1\CopyToCD.exe"
4/20/2008 8:29:43 PM info OS : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
4/20/2008 8:29:43 PM info 32 bits native system
4/20/2008 8:29:43 PM info ******************** Report session started ********************
