burn avi to dvd.. no sound?? and pixelated
old version of ConvertXtoDVD questions and problems (but most solved by using version 3)
Moderators: Cougar_II, ckhouston, JJ, Claire, Forum admin
Postby nitram79 » Fri Nov 21, 2008 1:14 am
Hi peeps,
I'm only new to this and am getting a massive headache from it, cause nothing i do is working properly. Iv been trying to burn avi file movies to dvd with little success. iv been reading forum after forum to no avail.
i burned an avi to dvd and it played but there was no sound at all, i did the conversion very slow but the picture quality was still effected, a little better than other attempts but still pretty pixelated. i'm using convertx 2.2, i was using express burn before but that turned out even worse if it worked at all ha ha please help me as im spending hours and hours on this and getting no where
nitram79
Re: burn avi to dvd.. no sound?? and pixelated
Postby JoeB » Fri Nov 21, 2008 1:34 am
nitram79 wrote:Hi peeps,
You may have been reading forum after forum but you certainly haven't read this forum sufficiently. If you had, you'd have seen many replies that start by telling people to please post your log file so that people can analyse your problem.
So please post it. You'll find it in Help>Open log file.
JoeB
JoeB
Postby nitram79 » Fri Nov 21, 2008 8:58 am
well i did see the stuff about the logs but i didnt know where to find them... anyways here it is, i think theres is 2 logs there because i tried it twice and the fist time it only burned the menu and no movie and no sound , i got rid of the menu and chapters and stuff and tried again and it did burn the movie but still no sound.............
here it is:
21/11/2008 7:52:05 PM info Newer version (3.0.0.1) is available on internet
21/11/2008 7:51:47 PM info User default language : 3081 (0x0C09h) - English (Australian)
21/11/2008 7:51:47 PM info System default language : 3081 (0x0C09h) - English (Australian)
21/11/2008 7:51:47 PM info Version 2.2.3.258
21/11/2008 7:51:47 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
21/11/2008 7:51:47 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
21/11/2008 7:51:46 PM info ******************** Report session started ********************
20/11/2008 11:38:56 PM info ********** Report session closed ***********
20/11/2008 11:38:50 PM info Media removed. Burning layer not ready to write
20/11/2008 11:38:36 PM error Write error at 1983024 (16) - Code 06 29 00 [Unit attention, Power On or Bus device reset occured]
20/11/2008 10:46:04 PM info Lead-in burning time (mS) 0
20/11/2008 10:44:53 PM info Write started 2096144 sectors to write
20/11/2008 10:44:53 PM info Init success: DVD-R SAO
20/11/2008 10:44:53 PM info Writing speed requested x2.0, effective x2.4
20/11/2008 10:44:53 PM info Available write speed: 8x, 6x, 4x, 2x
20/11/2008 10:44:53 PM info Media ID: TYG02
20/11/2008 10:44:53 PM info Media type: DVD-R
20/11/2008 10:44:53 PM info Ultra DMA mode 2 (ATA33)
20/11/2008 10:44:53 PM info Scanned files #8, folder #2 - total size 4291786752 b. (4 Gb.)
20/11/2008 10:44:53 PM info Inserted media type : DVD-R
20/11/2008 10:44:52 PM info --------------Encoding end--------------
20/11/2008 10:44:52 PM info Media name: "My DVD"
20/11/2008 10:44:52 PM info Burned folder: "C:\Users\Martin\Documents\ConvertXtoDVD\mir.rors\"
20/11/2008 10:44:37 PM info New media inserted. Burning layer is ready to write
20/11/2008 10:44:35 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
20/11/2008 10:44:35 PM info New Drive selected : 1:0:0 - Optiarc DVD+-RW AD-5540A 102C [E] (Ide)
20/11/2008 10:44:35 PM info Total size in built folder 4092 Mb., Target size DVD5 4400 Mb., Occupation 93.02%
20/11/2008 10:44:35 PM info Conversion completed in 00:50:37
20/11/2008 10:44:34 PM info Generated duration 6397.72 sec., expected 6397.80 sec.
20/11/2008 10:44:34 PM info 22 frames duplicated
20/11/2008 10:44:34 PM warning Stream #1 has produced NO data (empty). Result may miss some stream(s).
20/11/2008 9:53:58 PM info Stream #1 Sync. delay : 0.00 ms
20/11/2008 9:53:58 PM info Stream #0 Sync. delay : 0.00 ms
20/11/2008 9:53:58 PM info Output Stream#1 - Audio: ac3, 48000 Hz, mono, 192 kb/s, Automatic gain control 18.0 dB
20/11/2008 9:53:58 PM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 5451 kb/s
20/11/2008 9:53:58 PM info Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
20/11/2008 9:53:58 PM info Image processing: Fast bilinear resampler (656*272)->(720*432)
20/11/2008 9:53:58 PM info Image processing: Pad (Left:0 - Top:72 - Right:0 - Bottom:72)
20/11/2008 9:53:58 PM info Image processing: Deinterleave (656*272)
20/11/2008 9:53:58 PM info No pulldown: Frame duplication/removal will be used.
20/11/2008 9:53:58 PM info Video source original frame rate: 25.00
20/11/2008 9:53:58 PM info Output resolution: FULL D1 [720*576]
20/11/2008 9:53:58 PM info PAL 25 FPS output format set by user
20/11/2008 9:53:58 PM info Widescreen (16:9) set automatically
20/11/2008 9:53:58 PM info Video bitrate 0/5451/8808 Kbps (min/avg/max)
20/11/2008 9:53:58 PM info Converting "C:\Users\Martin\Videos\mir.rors.wmv"
20/11/2008 9:53:58 PM info ----------------Title #1----------------
20/11/2008 9:53:58 PM info Project size 4.3 Gb. (149 Mb. audio - 4.14 Gb. video)
20/11/2008 9:53:58 PM info Stream #1 - Audio: mp3, 8000 Hz, mono, 4 kb/s
20/11/2008 9:53:58 PM info Stream #0 - Video: wmv3, yuv420p, 656x272, 2048 kb/s
20/11/2008 9:53:58 PM info 2 Stream(s) found - est. duration 01:46:37.800
20/11/2008 9:53:58 PM info Opening file "C:\Users\Martin\Videos\mir.rors.wmv"
20/11/2008 9:53:58 PM info [ ] Don't fix audio gaps
20/11/2008 9:53:58 PM info [ ] Engine Log
20/11/2008 9:53:58 PM info Encoder quality: 100%
20/11/2008 9:53:58 PM info --------------Encoding begin--------------
20/11/2008 9:53:58 PM info --------------Menu settings end--------------
20/11/2008 9:53:58 PM info [ ] Menu
20/11/2008 9:53:58 PM info --------------Menu settings begin--------------
20/11/2008 9:53:58 PM info --------------Default burn settings end--------------
20/11/2008 9:53:58 PM info Default speed selected: 2x
20/11/2008 9:53:58 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
20/11/2008 9:53:57 PM info New Drive selected : 1:0:0 - Optiarc DVD+-RW AD-5540A 102C [E] (Ide)
20/11/2008 9:53:57 PM info [X] Delete files after burn complete
20/11/2008 9:53:57 PM info [ ] Don't eject after burn complete
20/11/2008 9:53:57 PM info [X] Prefer SAO for DVD-R
20/11/2008 9:53:57 PM info [ ] Include originals
20/11/2008 9:53:57 PM info [X] Burn result to DVD
20/11/2008 9:53:57 PM info --------------Default burn settings begin--------------
20/11/2008 9:50:30 PM info New media inserted. Burning layer is ready to write
20/11/2008 9:49:09 PM info User default language : 3081 (0x0C09h) - English (Australian)
20/11/2008 9:49:09 PM info System default language : 3081 (0x0C09h) - English (Australian)
20/11/2008 9:49:09 PM info Version 2.2.3.258
20/11/2008 9:49:09 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
20/11/2008 9:49:09 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
20/11/2008 9:49:08 PM info ******************** Report session started ********************
20/11/2008 9:33:21 PM info ********** Report session closed ***********
20/11/2008 9:33:09 PM info Folder C:\Users\Martin\Documents\ConvertXtoDVD\mir.rors\ has been removed
20/11/2008 9:33:09 PM info Finalization Time 00:06:25 - Total completion time 00:07:38
20/11/2008 9:26:44 PM info Write finished in 00:01:12 - Finalization start here. Avg. burn rate 0.21
20/11/2008 9:26:36 PM info Lead-in burning time (mS) 0
20/11/2008 9:25:31 PM info Write started 9536 sectors to write
20/11/2008 9:25:31 PM info Init success: DVD-R SAO
20/11/2008 9:25:31 PM info Writing speed requested x4.0, effective x2.4
20/11/2008 9:25:30 PM info Available write speed: 8x, 6x, 4x, 2x
20/11/2008 9:25:30 PM info Media ID: TYG02
20/11/2008 9:25:30 PM info Media type: DVD-R
20/11/2008 9:25:30 PM info Ultra DMA mode 2 (ATA33)
20/11/2008 9:25:30 PM info Scanned files #6, folder #2 - total size 18421760 b. (17.6 Mb.)
20/11/2008 9:25:30 PM info Inserted media type : DVD-R
20/11/2008 9:25:29 PM info Write started
20/11/2008 9:25:29 PM info --------------Encoding end--------------
20/11/2008 9:25:29 PM info Media name: "My DVD"
20/11/2008 9:25:29 PM info Burned folder: "C:\Users\Martin\Documents\ConvertXtoDVD\mir.rors\"
20/11/2008 9:25:25 PM info New media inserted. Burning layer is ready to write
20/11/2008 9:25:23 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
20/11/2008 9:25:23 PM info New Drive selected : 1:0:0 - Optiarc DVD+-RW AD-5540A 102C [E] (Ide)
20/11/2008 9:25:23 PM info Total size in built folder 17 Mb., Target size DVD5 4400 Mb., Occupation 0.40%
20/11/2008 9:25:23 PM info Conversion completed in 00:00:15
20/11/2008 9:25:19 PM info ------------Converting Menu--------------
20/11/2008 9:25:19 PM warning Estimated Duration of the video was inaccurate. Output size may greatly differ from target size.
20/11/2008 9:25:19 PM info Generated duration 0.04 sec., expected 6397.80 sec.
20/11/2008 9:25:19 PM warning Stream #1 has produced NO data (empty). Result may miss some stream(s).
20/11/2008 9:25:19 PM info Project size 4.3 Gb. (298 Mb. audio - 3.99 Gb. video)
20/11/2008 9:25:19 PM info Stream #1 - Audio: mp3, 8000 Hz, mono, 4 kb/s
20/11/2008 9:25:19 PM info Stream #0 - Video: wmv3, yuv420p, 656x272, 2048 kb/s
20/11/2008 9:25:19 PM info 2 Stream(s) found - est. duration 01:46:37.800
20/11/2008 9:25:19 PM info Opening file "C:\Users\Martin\Videos\mir.rors.wmv"
20/11/2008 9:25:08 PM info Stream #1 Sync. delay : 0.00 ms
20/11/2008 9:25:08 PM info Stream #0 Sync. delay : 0.00 ms
20/11/2008 9:25:08 PM info Output Stream#1 - Audio: ac3, 48000 Hz, mono, 192 kb/s, no automatic gain control
20/11/2008 9:25:08 PM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 5451 kb/s
20/11/2008 9:25:08 PM info [ ] Don't fix audio gaps
20/11/2008 9:25:08 PM info [ ] Engine Log
20/11/2008 9:25:08 PM info Encoder quality: 100%
20/11/2008 9:25:08 PM info --------------Encoding begin--------------
20/11/2008 9:25:08 PM info --------------Menu settings end--------------
20/11/2008 9:25:08 PM info [ ] Sequential playback
20/11/2008 9:25:08 PM info [ ] Loop playback
20/11/2008 9:25:08 PM info [ ] Auto start playback
20/11/2008 9:25:08 PM info [X] Menu
20/11/2008 9:25:08 PM info --------------Menu settings begin--------------
20/11/2008 9:25:08 PM info --------------Default burn settings end--------------
20/11/2008 9:25:08 PM info Default speed selected: 4x
20/11/2008 9:25:08 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
20/11/2008 9:25:07 PM info Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
20/11/2008 9:25:07 PM info Image processing: Fast bilinear resampler (656*272)->(720*432)
20/11/2008 9:25:07 PM info Image processing: Pad (Left:0 - Top:72 - Right:0 - Bottom:72)
20/11/2008 9:25:07 PM info Image processing: Deinterleave (656*272)
20/11/2008 9:25:07 PM info No pulldown: Frame duplication/removal will be used.
20/11/2008 9:25:07 PM info Video source original frame rate: 25.00
20/11/2008 9:25:07 PM info Output resolution: FULL D1 [720*576]
20/11/2008 9:25:07 PM info PAL 25 FPS output format set by user
20/11/2008 9:25:07 PM info Widescreen (16:9) set automatically
20/11/2008 9:25:07 PM info Video bitrate 0/5451/8808 Kbps (min/avg/max)
20/11/2008 9:25:07 PM info Converting "C:\Users\Martin\Videos\mir.rors.wmv"
20/11/2008 9:25:07 PM info ----------------Title #1----------------
20/11/2008 9:25:07 PM info Project size 4.3 Gb. (149 Mb. audio - 4.14 Gb. video)
20/11/2008 9:25:07 PM info Stream #1 - Audio: mp3, 8000 Hz, mono, 4 kb/s
20/11/2008 9:25:07 PM info Stream #0 - Video: wmv3, yuv420p, 656x272, 2048 kb/s
20/11/2008 9:25:07 PM info 2 Stream(s) found - est. duration 01:46:37.800
20/11/2008 9:25:07 PM info Opening file "C:\Users\Martin\Videos\mir.rors.wmv"
20/11/2008 9:25:07 PM info [ ] Don't fix audio gaps
20/11/2008 9:25:07 PM info [ ] Engine Log
20/11/2008 9:25:07 PM info Encoder quality: 100%
20/11/2008 9:25:07 PM info --------------Encoding begin--------------
20/11/2008 9:25:07 PM info --------------Menu settings end--------------
20/11/2008 9:25:07 PM info [ ] Sequential playback
20/11/2008 9:25:07 PM info [ ] Loop playback
20/11/2008 9:25:07 PM info [ ] Auto start playback
20/11/2008 9:25:07 PM info [X] Menu
20/11/2008 9:25:07 PM info --------------Menu settings begin--------------
20/11/2008 9:25:07 PM info --------------Default burn settings end--------------
20/11/2008 9:25:07 PM info Default speed selected: 4x
20/11/2008 9:25:07 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
20/11/2008 9:25:07 PM info New media inserted. Burning layer is ready to write
20/11/2008 9:25:06 PM info New Drive selected : 1:0:0 - Optiarc DVD+-RW AD-5540A 102C [E] (Ide)
20/11/2008 9:25:06 PM info [X] Delete files after burn complete
20/11/2008 9:25:06 PM info [ ] Don't eject after burn complete
20/11/2008 9:25:06 PM info [ ] Prefer SAO for DVD-R
20/11/2008 9:25:06 PM info [ ] Include originals
20/11/2008 9:25:06 PM info [X] Burn result to DVD
20/11/2008 9:25:06 PM info --------------Default burn settings begin--------------
20/11/2008 9:24:57 PM info New Drive selected : 1:0:0 - Optiarc DVD+-RW AD-5540A 102C [E] (Ide)
20/11/2008 9:24:57 PM info [X] Delete files after burn complete
20/11/2008 9:24:57 PM info [ ] Don't eject after burn complete
20/11/2008 9:24:57 PM info [ ] Prefer SAO for DVD-R
20/11/2008 9:24:57 PM info [ ] Include originals
20/11/2008 9:24:57 PM info [X] Burn result to DVD
20/11/2008 9:24:57 PM info --------------Default burn settings begin--------------
20/11/2008 9:24:50 PM info Media removed. Burning layer not ready to write
20/11/2008 9:22:21 PM info New media inserted. Burning layer is ready to write
20/11/2008 9:22:19 PM info User default language : 3081 (0x0C09h) - English (Australian)
20/11/2008 9:22:19 PM info System default language : 3081 (0x0C09h) - English (Australian)
20/11/2008 9:22:19 PM info Version 2.2.3.258
20/11/2008 9:22:19 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
20/11/2008 9:22:19 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
20/11/2008 9:22:18 PM info ******************** Report session started ********************
19/11/2008 10:31:37 PM info ********** Report session closed ***********
19/11/2008 10:30:34 PM info --------------Encoding end--------------
19/11/2008 10:30:31 PM info Conversion failed after 00:00:14
19/11/2008 10:30:31 PM info User cancellation requested
19/11/2008 10:30:17 PM info Stream #1 Sync. delay : 0.00 ms
19/11/2008 10:30:17 PM info Stream #0 Sync. delay : 0.00 ms
19/11/2008 10:30:17 PM info Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, no automatic gain control
19/11/2008 10:30:17 PM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 6105 kb/s
19/11/2008 10:30:17 PM info Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
19/11/2008 10:30:17 PM info Image processing: Fast bilinear resampler (656*272)->(720*432)
19/11/2008 10:30:17 PM info Image processing: Pad (Left:0 - Top:72 - Right:0 - Bottom:72)
19/11/2008 10:30:17 PM info Image processing: Deinterleave (656*272)
19/11/2008 10:30:17 PM info No pulldown: Frame duplication/removal will be used.
19/11/2008 10:30:17 PM info Video source original frame rate: 25.00
19/11/2008 10:30:17 PM info Output resolution: FULL D1 [720*576]
19/11/2008 10:30:17 PM info PAL 25 FPS output format set by user
19/11/2008 10:30:17 PM info Widescreen (16:9) set automatically
19/11/2008 10:30:17 PM info Video bitrate 0/6105/8808 Kbps (min/avg/max)
19/11/2008 10:30:17 PM info Converting "C:\Users\Martin\Desktop\Max.Payne.R5.LINE.XviD-By.Deejam\opt-maxpayne-r5.avi"
19/11/2008 10:30:17 PM info ----------------Title #1----------------
19/11/2008 10:30:17 PM info Project size 4.3 Gb. (134 Mb. audio - 4.15 Gb. video)
19/11/2008 10:30:17 PM info Stream #1 - Audio: mp3, 48000 Hz, stereo, 124 kb/s
19/11/2008 10:30:17 PM info Stream #0 - Video: mpeg4, yuv420p, 656x272
19/11/2008 10:30:17 PM info 2 Stream(s) found - est. duration 01:35:36.720
19/11/2008 10:30:17 PM info Opening file "C:\Users\Martin\Desktop\Max.Payne.R5.LINE.XviD-By.Deejam\opt-maxpayne-r5.avi"
19/11/2008 10:30:16 PM info [ ] Don't fix audio gaps
19/11/2008 10:30:16 PM info [ ] Engine Log
19/11/2008 10:30:16 PM info Encoder quality: 100%
19/11/2008 10:30:16 PM info --------------Encoding begin--------------
19/11/2008 10:30:16 PM info --------------Menu settings end--------------
19/11/2008 10:30:16 PM info [ ] Sequential playback
19/11/2008 10:30:16 PM info [ ] Loop playback
19/11/2008 10:30:16 PM info [ ] Auto start playback
19/11/2008 10:30:16 PM info [X] Menu
19/11/2008 10:30:16 PM info --------------Menu settings begin--------------
19/11/2008 10:30:16 PM info --------------Default burn settings end--------------
19/11/2008 10:30:16 PM info No default writer set
19/11/2008 10:30:16 PM info [X] Delete files after burn complete
19/11/2008 10:30:16 PM info [ ] Don't eject after burn complete
19/11/2008 10:30:16 PM info [ ] Prefer SAO for DVD-R
19/11/2008 10:30:16 PM info [ ] Include originals
19/11/2008 10:30:16 PM info [X] Burn result to DVD
19/11/2008 10:30:16 PM info --------------Default burn settings begin--------------
19/11/2008 10:29:45 PM info New media inserted. Burning layer is ready to write
19/11/2008 10:29:42 PM info User default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:29:42 PM info System default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:29:42 PM info Version 2.2.3.258
19/11/2008 10:29:42 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
19/11/2008 10:29:42 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
19/11/2008 10:29:42 PM info ******************** Report session started ********************
19/11/2008 10:29:34 PM info ********** Report session closed ***********
19/11/2008 10:28:05 PM info Newer version (3.0.0.1) is available on internet
19/11/2008 10:27:59 PM info New media inserted. Burning layer is ready to write
19/11/2008 10:27:57 PM info User default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:27:57 PM info System default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:27:57 PM info Version 2.2.3.258
19/11/2008 10:27:57 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
19/11/2008 10:27:57 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
19/11/2008 10:27:56 PM info ******************** Report session started ********************
19/11/2008 10:27:53 PM info ********** Report session closed ***********
19/11/2008 10:25:33 PM info Newer version (3.0.0.1) is available on internet
19/11/2008 10:24:50 PM info New media inserted. Burning layer is ready to write
19/11/2008 10:24:48 PM info User default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:24:48 PM info System default language : 3081 (0x0C09h) - English (Australian)
19/11/2008 10:24:48 PM info Version 2.2.3.258
19/11/2008 10:24:48 PM info ExeName : "C:\Program Files\VSO\ConvertXtoDVD\ConvertXtoDvd.exe"
19/11/2008 10:24:48 PM info OS : Microsoft Vista Professional Service Pack 1 (Build 6001)
19/11/2008 10:24:47 PM info ******************** Report session started ********************
ÿþ1
nitram79
solved
Postby nitram79 » Fri Nov 21, 2008 11:15 am
Hi joeb, or any1 that reads this,
i tried again, this time at x1 burn speed, and it worked :):):) really well too.. i actually didnt think it burned anything cause when i put it in the first time it didnt work, but the secont time it did. so i dont know if the burn speed made a diff, but i also made sure there was an audio output this time, i didnt check that stuff before, so anyway, i have to say convertx works well..... if u know what ur doing ha
also i saw that u can put solved in front of the post dont know how to do it if someone could tell me that would be great... thanks
nitram79
Re: solved
Postby divisionbella » Fri Jan 22, 2010 12:39 am
nitram79 wrote:Hi joeb, or any1 that reads this,
yes that should do it, most people want a quick burn and dont realize that a slower bur is much more reliable, but thena gain it all matters what kind of burner you have, the more expensive ones now days will do it all at high speeds
divisionbella
a converter software
Postby emily2011 » Sun Dec 19, 2010 1:56 pm
hi guy. the problem is you need a converter software . In fact you can search in the forum first and you can get the answer. there are many kindful guys sugget it such as . in my opinion I would like the dawnark video converter ones .you can get the link
emily2011
Re: a converter software
Postby JoeB » Mon Dec 20, 2010 12:10 am
emily2011 wrote:hi guy. the problem is you need a converter software . In fact you can search in the forum first and you can get the answer. there are many kindful guys sugget it such as . in my opinion I would like the [SPAM ATTEMPT] video converter ones .you can get the link[SPAM LINK]
What you need is some manners and to stop SPAMMING forums.
JoeB
JoeB
Return to ConvertXToDVD old version 2.x
  • Related topics
    Replies
    Views
    Last post
Who is online
Users browsing this forum: No registered users and 2 guests
