ConvertXtoDVD7 and multiple video converting
Freddie
Post by Freddie »
When loading multiple videoes to convert how do I stop them all merging together so I can watch each one individually without having to start from the beginning of the first video and scrolling through each time please.
Re: ConvertXtoDVD7 and multiple video converting
I'm not entirely sure what you're asking for, so let me ask you a question. Are you creating a main menu or just making a DVD where the video plays straight through when you insert/play it? If you're not creating a main menu, I would think you may want to. That way, you can jump to a particular title from the menu and play it.
Maybe try reinstall and use clean option to remove any settings that cause your issue.
I use default settings, and if select say 5 videos files, they convert and appear in menu as five videos. They do not merge.
The only option I have seen to merge videos is when in advanced settings for a video, where there is option to add additional videos to it.
