Accelerator deactivate?
Re: Accelerator deactivate?
Are you still having issues with 5.1.0.66 + the Latest ENGINE (CHECK UPDATES to get it) ???
Latest engine just came out a few days ago.
As for your question (I do not know if it's possible, I guess you would need a CAPTURE CARD) and record the stream, but it's all I know about your question...
Thanks Cougar_II, always a great idea to check update first!
Have you tried a clean reinstall regarding the acceleration issue?
http://download.vso-software.fr/archive ... 1.0.66.exe
Cheers,
