Downloader issues when using my VPN
Hello everyone,
I don’t consider this a software bug, why I am posting it here.
I have upgraded to the latest version, and wanted to download a YouTube video, but all I had were download issues.
I had an idea and turned off my VPN (PIA / Private Internet Access) and poof it worked like a charge.
Anyone else experiencing issues with Downloader and a VPN ?
Re: Downloader issues when using my VPN
Hi there,
The .65? Did you get same result with .64?
Let me know
Cheers,
Good morning,
YES, when I had the issue, I have reinstalled .64 and to my big surprise, I had the same issue.
So reinstalled .65 on top of it all, stopped VPN and it worked.
One thing I have NOT tried is connect to a different country or VPN site, see if the issue comes from my IP location/connection.
I was fine in the past.
I run a few tests, it is working for us with HMA VPN.
Which one are you using? If it's a free one I could try it out from there.
Let me know!
No worries, I will keep on testing WITH VPN on, and change location :)
https://www.privateinternetaccess.com
PIA is what I use and 99% of the time connect to Toronto, CANADA.
I wanted to look at the logs and sent them, but could NOT find my logs :(
I use the Report Tool this morning (From work) to report .log files issues for me !
Hello Maggie,
I wanted to retest downloader with my VPN and it told me there was an engine update.
WHAT ? didn't this get done when I installed .65 ?
Anyway, connect in EUROPE, worked.
Reconnected to Toronto, Canada, well.... WORKED !
So maybe my original issue was OLD engine.
This is why I have a request somewhere on the bug site to all ENGINE version in the HELP about and/or in the logs etc... :) :) :)
You know, the LOG I can't find HAHAHA yes another bug report :)
That's a good news! ;)
I've seen your email about the logs, I'll answer asap.
Thanks for your multiple efforts, without them, we would not have been able to solve that! haha
Cheers,
