Hello everyone,,
1. Launch to System Tray
snaptube.cam/ syncnet.onl/telegram-web/ 9apps
2. On Start Up, start detection or stop detection enabled.
I would like to have VSO downloader in my Tray when the computer is booted with Stop Detection pre set. This way I can Start Detection when desired.
Suggestions for Future Update
Re: Suggestions for Future Update
In the general settings, you can enable
[X] launch application minimized
The application launches, then poof gets minimized.
Then add Downloader to your STARTUP windows settings, this could work for request #1.
https://support.microsoft.com/en-us/hel ... artup-apps (Windows 10 to add a Startup App)
But I am trying to find a way to configure how to start downloader with Auto Detect OFF on start, will advise if I find something...
Been reported as requested feature Cougar_II:
https://bugs.vso-software.fr/view.php?id=13819
Thanks!
Thanks!
