Hello
I've just converted a mkv-hd-720p-video-file into BluRay 720p.
Unfortunately converted file is slightly out of synch, that means audio goes slightly ahead of video (original mkv-file is totally synch).
So I installed v2.0.0.47 (--> still works best for me up to v2.0.0.51) and converted file is perfectly synch, so the bug is in v2.0.0.51.
Thanks for keep an eye on audio conversion.
mue.mat
Audio-Bug in v2.0.0.51: BluRay-Audio out of synch
Re: Audio-Bug in v2.0.0.51: BluRay-Audio out of synch
Thanks for the note that .47 works the best. I no longer have time for the "find the new bug" game.
... so Beta-version 51 turns to "regular" version 51?
It doesn't seem that were made any changes, so still out of sync!?
Did you seen this line:
- 0012301: [Bug] Some files result with bad audio/video sync on output (cedric) - resolved.
Please, retry with the official version then let us know...
Hello
Yes, I saw, but 51-Beta-Version had already the same line:
ConvertXtoVideo - 2.0.0.51 (Released 2016-12-08) [ View Issues ]
So, I guess official version is the same as beta-version 51 because no other bug-fix is mentioned.
If there are unmentioned bug-fixes in official version, please let me know before I try out.
mue.mat
mue.mat
ThanksPlease, retry with the official version then let us know...
Official version 51 works with the same setup file as beta version 51. I'v just tried out. So again: out of audio synch.
Remember:
So I installed v2.0.0.47 (--> still works best for me up to v2.0.0.51) and converted file is perfectly synch, so the bug is even in official v2.0.0.51.
mue.mat
Remember:
mue.mat
Well done, new beta v2.0.0.52 has fixed audio error.
mue.mat
mue.mat
