Family Movies
Family Movies
Hello, I am getting an error when the DVD plays saying it does not have the license to view the DVD. What can I do to remedy this?
Re: Family Movies
Have you set the correct region ? Unless your DVD player is multi region, you will have to set the correct region for your party ther world.
Re: Family Movies
I believe it is written through ConvertXtoDVD. It will play partial movie, and then give me a locked sign that stops the show. DVD players shouldn't be able to do anything like that though?
Re: Family Movies
It could be anything from a bad region code to a faulty DVD media.
it would be best to post the log file.
Re: Family Movies
Can you go on cinavia web site to see if the error code you get correspond to their codes?
http://www.cinavia.com/languages/englis ... sages.html
