VSO Software Forum CD, DVD, Blu-ray Burning Software, Video Converter, AVI to DVD, Photo Slideshow, DVD Copy
| View previous topic :: View next topic |
| Author |
Message |
BearGFR
Posted: Sat Jul 18, 2009 5:40 pm Post subject: Problem with PhotoOnWeb 0.9.1.0 |
After installing on Windows 2000/SP4+, product fails on startup with the following dialog:
The problem occurs regardless of whether photoonweb is started directly, or indirectly by opening a previous .pow project file.
Falling back to an older version (0.9.0.7), corrects the problem. |
| Back to top |
Phil VSO Team Member
Posted: Mon Jul 20, 2009 11:12 am Post subject: |
Please check your installation folder for vsorsz.dll, and delete if present. Then look for vsoscaler.dll, right-click and select Properties. On the Details tab, check the file version, which must be 1.3.0.14. _________________
| Back to top |
BearGFR
Posted: Tue Jul 21, 2009 12:52 pm Post subject: |
Reinstalled and retried, after having deleted vsorsz.dll. Problem seems to be corrected. Was this file left over from a previous installation? If so, perhaps your install process for 0.9.1.0 should check for and delete this file.
Robert |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You can attach files in this forum You can download files in this forum
