Low sound problem
jeff75006
Low sound problem
Post by jeff75006 »
first of all, congrats for your great software (Blu-Ray Converter Ultimate v1.2.0.14).
I still have a little issue. The sound level of the DVDs I rip is much lower than the one of the original BD (and much lower than the one of retail DVDs), so that it is difficult to hear on my portable device (NextBase Click 9 Lite Duo Deluxe), even at maximum sound level. Moreover, the output sound level is different from one DVD rip to another. Is there any workaround to this problem?
Thanks in advance,
JF Henric
PS : i had posted in the French support, but without any response for 2 weeks, sorry then for this "crosspost".
Here is the log file!:
[code]
2011-08-28 02:11:05 ---- ******************** Log session stop 28-août 02:11:05.567 PID 6860********************
2011-08-28 01:55:34 Info WRITE SUCCESS: Disc written
2011-08-28 01:55:34 Info Finalization Time 00:00:27 - Total completion time 00:05:43
2011-08-28 01:55:07 Info Write finished in 00:05:16 - Finalization start here. Avg. burn rate 10,96
2011-08-28 01:49:58 Info Lead-in burning time (mS) 7615
2011-08-28 01:49:51 Info Write started 2130496 sectors to write
2011-08-28 01:49:51 Info Init success: DVD+R
2011-08-28 01:49:51 Info Writing speed requested x16.0, effective x16.0
2011-08-28 01:49:51 Info Available write speed: 16x ,12x ,8x
2011-08-28 01:49:51 Info Media ID: MCC-004-00
2011-08-28 01:49:51 Info Media type: DVD+R
2011-08-28 01:49:50 Info PIO Mode
2011-08-28 01:49:44 Info Scanned files #11, folder #2 - total size 4362147840 b. (4,06 Gb.)
2011-08-28 01:49:44 Info Inserted media type : DVD+R
2011-08-28 01:49:44 Info Write started
2011-08-28 01:49:44 Important ****************************************Processus de conversion : fin de session****************************************
2011-08-28 01:49:44 Info Taille totale à graver : 4160 Mo
2011-08-28 01:49:44 Info Démarrage de la gravure de la structure du DVD Video
2011-08-28 01:49:44 Info Nom du disque : NARNIA_LWW_D1_FRA
2011-08-28 01:49:44 Info Graveur utilisé pour la gravure: [E] HL-DT-ST BD-RE BH08LS20 2.00 (Ide)
2011-08-28 01:49:43 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-28 01:49:43 Info Drive has Serial ATA physical interface
2011-08-28 01:49:43 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-28 01:49:18 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-28 01:49:18 Info Drive has Serial ATA physical interface
2011-08-28 01:49:18 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-28 01:49:07 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-28 01:49:07 Info Drive has Serial ATA physical interface
2011-08-28 01:49:07 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-28 01:48:40 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-28 01:48:40 Info Drive has Serial ATA physical interface
2011-08-28 01:48:40 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-27 20:11:15 Info No disc in drive.
2011-08-27 20:11:13 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-27 20:11:13 Info Drive has Serial ATA physical interface
2011-08-27 20:11:13 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-27 20:11:13 Info Début de la gravure des fichier convertis...
2011-08-27 20:11:13 Info La conversion s'est terminée avec succès
2011-08-27 20:11:12 Info Vitesse de conversion: 1,61 x Temps réel
2011-08-27 20:11:12 Info Durée du DVD (avec menus) 02:24:49 (~ 8689 sec.) - temps de conversion 01:30:05
2011-08-27 20:11:12 Info Durée générée 8689,20 sec., attendue 8571,69 sec.
2011-08-27 20:10:40 Info P-SDT buffer Underflow 1 times, 379 bytes peak
2011-08-27 20:10:40 Info 3 trames dupliquées
2011-08-27 20:04:43 Info Le chapitre #24 démarre à 131:34.380
2011-08-27 20:00:53 Info Le chapitre #23 démarre à 125:30.020
2011-08-27 19:56:48 Info Le chapitre #22 démarre à 119:29.160
2011-08-27 19:53:55 Info Le chapitre #21 démarre à 115:0.900
2011-08-27 19:52:31 Info Le chapitre #20 démarre à 112:39.260
2011-08-27 19:50:02 Info Le chapitre #19 démarre à 109:14.040
2011-08-27 19:48:08 Info Le chapitre #18 démarre à 106:13.860
2011-08-27 19:42:49 Info Le chapitre #17 démarre à 97:41.860
2011-08-27 19:39:06 Info Le chapitre #16 démarre à 91:50.000
2011-08-27 19:34:30 Info Le chapitre #15 démarre à 84:36.580
2011-08-27 19:30:50 Info Le chapitre #14 démarre à 78:57.240
2011-08-27 19:26:34 Info Le chapitre #13 démarre à 72:16.840
2011-08-27 19:19:38 Info Le chapitre #12 démarre à 61:15.680
2011-08-27 19:16:49 Info Le chapitre #11 démarre à 56:43.400
2011-08-27 19:12:56 Info Le chapitre #10 démarre à 50:23.520
2011-08-27 19:10:41 Info Le chapitre #9 démarre à 46:51.300
2011-08-27 19:05:59 Info Le chapitre #8 démarre à 39:29.860
2011-08-27 19:03:11 Info Le chapitre #7 démarre à 34:56.100
2011-08-27 18:59:53 Info Le chapitre #6 démarre à 29:45.780
2011-08-27 18:56:38 Info Le chapitre #5 démarre à 24:34.480
2011-08-27 18:52:50 Info Le chapitre #4 démarre à 18:23.600
2011-08-27 18:48:15 Info Le chapitre #3 démarre à 11:15.180
2011-08-27 18:45:40 Info Le chapitre #2 démarre à 7:7.920
2011-08-27 18:41:08 Info Flux #3 - sync audio a 160,00 ms: 73,71 ms ajouté
2011-08-27 18:41:08 Info Paramètres audio: automatique
2011-08-27 18:41:08 Info Stream de sortie #3 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-27 18:41:08 Info Stream de sortie #2 (AUDIO) - dca,0][0] / 0x0000, 48000 Hz, 5.1, 1536 kb/s
2011-08-27 18:41:08 Info Stream de sortie #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=3-31, 1994 kb/s, pulldown: 23,976 -> 25,00 Fps
2011-08-27 18:41:08 Info Conversion MPEG-2 avec 8 threads
2011-08-27 18:41:08 Info Decodage Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9] avec 8 threads
2011-08-27 18:41:08 Info Traitement vidéo : Lanczos (VSO) redimensionement (1920*1080)->(720*576) 8 threads
2011-08-27 18:41:08 Info 3 Stream(s) trouvé(s) - durée est. 02:22:51.688, référence 02:22:51.688
2011-08-27 18:41:08 Info Ouverture du fichier "E:\BDMV\index.bdmv"
2011-08-27 18:41:07 Info Répertoire de sortie : F:\Mes Documents\VSOBlurayConverter\
2011-08-27 18:41:07 Info Taille maximum de la sortie : 4,30 Gb.
2011-08-27 18:41:07 Info Qualité vidéo sélectionnée : Qualité maximale. Filtre de redimensionnement de la vidéo : Windowed sinc Lanczos (VSO)
2011-08-27 18:41:07 Important ****************************************Processus de conversion : début de session****************************************
2011-08-27 18:41:07 Info La collection de chapitres sera importée à partir de la source
2011-08-27 18:41:07 Info Menu DVD sélectionné : Mirroir noir avec vidéo dans le 1er tiers haut du menu racine
2011-08-27 18:41:06 Info Le projet converti sera gravé en utilisant le lecteurE:
2011-08-27 18:41:06 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-27 18:41:06 Info Drive has Serial ATA physical interface
2011-08-27 18:41:06 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-27 18:41:01 Info Disc (BD-R Sequential) not empty.
2011-08-27 18:37:08 Info Disc (BD-R Sequential) not empty.
2011-08-27 18:36:36 Important ****************************************Processus de conversion : fin de session****************************************
2011-08-27 18:36:35 Info Disc (BD-R Sequential) not empty.
2011-08-27 18:36:33 Info La conversion a été annulée par l'utilisateur
2011-08-27 18:36:12 Info Stream de sortie #2 (AUDIO) - ac3, 48000 Hz, 2 channels, 192 kb/s
2011-08-27 18:36:12 Info Stream de sortie #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 8647 kb/s, pulldown: 23,976 -> 25,00 Fps
2011-08-27 18:36:12 Info Conversion MPEG-2 avec 8 threads
2011-08-27 18:36:12 Info Decodage Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9] avec 8 threads
2011-08-27 18:36:12 Info Traitement vidéo : Lanczos (VSO) redimensionement (1920*1080)->(720*576) 8 threads
2011-08-27 18:36:12 Info 2 Stream(s) trouvé(s) - durée est. 00:32:54.722, référence 00:32:54.722
2011-08-27 18:36:12 Info Ouverture du fichier "E:\BDMV\index.bdmv"
2011-08-27 18:36:12 Info Répertoire de sortie : F:\Mes Documents\VSOBlurayConverter\
2011-08-27 18:36:12 Info Taille maximum de la sortie : 4,30 Gb.
2011-08-27 18:36:12 Info Qualité vidéo sélectionnée : Qualité maximale. Filtre de redimensionnement de la vidéo : Windowed sinc Lanczos (VSO)
2011-08-27 18:36:12 Important ****************************************Processus de conversion : début de session****************************************
2011-08-27 18:36:11 Info La collection de chapitres sera importée à partir de la source
2011-08-27 18:36:11 Info Menu DVD sélectionné : Mirroir noir avec vidéo dans le 1er tiers haut du menu racine
2011-08-27 18:36:02 Info Le projet converti sera gravé en utilisant le lecteurE:
2011-08-27 18:36:02 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-27 18:36:02 Info Drive has Serial ATA physical interface
2011-08-27 18:36:02 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-27 18:35:16 Info Disc (BD-R Sequential) not empty.
2011-08-27 18:34:46 Info 9 menus chargés.
2011-08-27 18:34:46 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-27 18:34:46 Info Drive has Serial ATA physical interface
2011-08-27 18:34:46 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH08LS20 2.00 [E] (Ide)
2011-08-27 18:34:46 Info Mémoire disponible : 5946 Mb.
2011-08-27 18:34:46 Info Mémoire totale : 8172 Mb.
2011-08-27 18:34:46 Info Mémoire virtuelle étendue disponible : 0 Mb.
2011-08-27 18:34:46 Info Mémoire virtuelle disponible : 1823 Mb.
2011-08-27 18:34:46 Info Mémoire virtuelle totale : 2047 Mb.
2011-08-27 18:34:46 Info Memoire chargée : 47%
2011-08-27 18:34:46 Info Mémoire physique disponible : 2150 Mb.
2011-08-27 18:34:46 Info Mémoire physique totale : 4087 Mb.
2011-08-27 18:34:46 Info Language par défaut du système: Français (France)
2011-08-27 18:34:46 Info User default language : Français (France)
2011-08-27 18:34:46 Info Version : 1.2.0.14
2011-08-27 18:34:46 Info ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-27 18:34:46 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2011-08-27 18:34:45 Info Using Advanced SPTI interface
2011-08-27 18:34:45 ---- ******************** Log session start 27-août 18:34:45.125 PID 6860********************
[/code]
Re: Low sound problem
Problem seen - we will publish a version that should provide a solution for you. Sorry for the delay in replying.
Hi jeff75006,
This problem is due to audio channels downmix/upmix (converting a 6 channels stream to 2 channels stream for example), that's why you can't reproduce the problem for all Blu-ray discs.
Like bonuses are often encoded as stereo, but main movie as multi channels, a converted DVD Video (with Blu-ray Converter) can have the main movie audio track level lower than bonuses.
To fix this problem, I added a new setting allowing to normalise the audio track level...
You will found it in advanced settings (located on bottom of profile selector, step 2).
You can try by setting the "audio boost" level to 50%, then check the result.
You will found the download link of the new beta version (1.2.1.17) here:
Thanks!
setting is still hiden - a new version will be available where we can see this new setting
jeff75006
Post by jeff75006 »
Thank you for your reply. I will then wait for the new version, as the beta does not seem to work for me (access violation error when entering step 2).
Keep on the good work!
have you tried with 1.2.1.18?
jeff75006
Post by jeff75006 »
The 1.2.1.20 beta works perfectly now on my computer. I'll let you you if the "sound booster" works as soon as i can test it on my portable device, maybe next week.
Thank you again for this great software, and great support.
:D
