Click here to visit official Vso-Software site VSO Software Forum
CD, DVD, Blu-ray Burning Software, Video Converter, AVI to DVD, Photo Slideshow, DVD Copy
RegisterRegister  Log inLog in   ProfileProfile    MemberlistMemberlist   Log in to check your private messagesLog in to check your private messages
[Solved] How do I Stop putting start option on burned dvd's
Post new topic   Reply to topic
  Forum Index Forum Index -> ConvertXToDVD old version 2.x
View previous topic :: View next topic
Author Message
eg7
PostPosted: Thu Oct 08, 2009 11:21 am    Post subject: [Solved] How do I Stop putting start option on burned dvd's Reply with quote
when I burn my dvd,s they come out great but they will only play on my dvd player when I have to push start on the main menue, but if I play the same dvd from my PC or laptop, they play automaticly.
Please advise how I can either edit the original dvd which is in avi format or wmv, or edit the VSO convertered version before I burn it to finalised dvd; so that I do not have to play start every time i wish to play the converted/burned dvd. If I am in the car driving and the dvd is in I have to stop the car and push play for the children very annoying, how can i avoid this, thanks
Back to top
View user's profile Send private message
PostPosted: Thu Oct 08, 2009 1:20 pm    Post subject: Reply with quote
Reading manual is helpful.
There is autostart option to be set before conversion. BUT!! That can be over ridden on DVD player. Set that AND check that player is set to play automatically also.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Forum Index -> ConvertXToDVD old version 2.x All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
ConvertXtoDVD - CopyToDVD - PhotoDVD - BlindWrite - Image resizer - VSO Inspector - PhotoOnWeb
Copyright © 2008 VSO Software SARL
