Any ideas on where to look for problem?
Moderators: ckhouston, JJ, Claire, Phil, Forum admin
Postby guy-cynical » Mon Aug 06, 2012 4:42 pm
Either I don't know what phrase to search for or this is going to some sort of user error I don't understand but any clues would be appreciated. Also, I know I'm not a paid user of convertxtodvd so if that is a requirement just delete this and I'll keep looking on my own. I am pretty new to this video stuff so probably user error.
My problem concerns color hue when converting to dvd (such as source xxx.flv, xxx.mpg - mpg-2 files) As example using a clip taken from a public broadcast system .flv video of good quality - in unaltered state colors look good on both computer monitor and tv. Run it through convertx and the output colors are off. The caucasian people suddenly all have sun burns and the sunlit backgrounds have what I call blown out highlights (brighter than original and many details missing) . It is like the colors have been 'punched up' too far.
I have tried various resize filters as well as using vsoclean and reintalling. I have also tried some other settings changes with no change in output. I've read and searched everywhere I can think of with no results. My video card drivers are current and the output looks the same when burned to a dvd and played on a tv (which indicates to me it's not a computer video driver problem). I just do not know where to look or what phrase to search for and would appreciate any ideas or suggestions even if this is normal behavior for the convertx trial version so I know to quit messing with it. I am including the log file from a little video clip I've been using to test this issue and if any other information will help I'd be happy to do so.
Thank you in advance for your help.
2012-08-05 16:20:58 ---- ***************** Encoding end **********************
2012-08-05 16:20:57 Info BURN: No disc in drive.
2012-08-05 16:20:55 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-08-05 16:20:55 Info BURN: Drive has Serial ATA physical interface
2012-08-05 16:20:55 Info BURN: New Drive selected : 0:1:0 - hp CDDVDW TS-L633N 0300 [F] (Ide)
2012-08-05 16:20:55 Info Burned folder: "C:\Users\bobd\Documents\ConvertXToDVD\test\", Min. media size 40.01 Mb.
2012-08-05 16:20:55 Info Total size 40 Mb., Target size DVD5 4300 Mb., Occupation 0.93%
2012-08-05 16:20:55 Info Conversion completed in 00:00:21
2012-08-05 16:20:55 Info Rendering rate: 3.10 x Realtime
2012-08-05 16:20:55 Info DVD duration (incl. menus) 00:01:05 (~ 65 sec.) - rendering time 00:00:21
2012-08-05 16:20:55 Info Generated duration 65.60 sec., expected 63.62 sec.
2012-08-05 16:20:34 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 2 channels, 224 kb/s
2012-08-05 16:20:34 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 8616 kb/s, frame compensation: 29.970 -> 29.97 Fps
2012-08-05 16:20:34 Info Encoding MPEG-2 with 2 threads
2012-08-05 16:20:34 Info Video processing: deinterlace (width: 720 - height: 480)
2012-08-05 16:20:34 Info Chapter sequences require 25.74 Mb. temp space
2012-08-05 16:20:34 ---- ************ Source file #1 END DETAILS ************
2012-08-05 16:20:34 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
2012-08-05 16:20:34 Info VIDEO Stream #1 : Video: mpeg2video (Main), yuv420p, 720x480 [PAR 32:27 DAR 16:9], 9200 kb/s, 29.97 FPS
2012-08-05 16:20:34 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2012-08-05 16:20:34 Info Logical file: C:\Users\bobd\Desktop\test.mpg - 1 file(s) 36.91 Mb.
2012-08-05 16:20:34 ---- *********** Source file #1 BEGIN DETAILS ***********
2012-08-05 16:20:34 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2012-08-05 16:20:34 Info Video bitrate 0/8616/8976 Kbps (min/avg/max)
2012-08-05 16:20:34 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2012-08-05 16:20:34 ---- ======================= TITLESET #1 =======================
2012-08-05 16:20:34 Info 2 Stream(s) found - est. duration 00:00:47.616, reference 00:00:47.616
2012-08-05 16:20:34 Info Opening file "C:\Users\bobd\Desktop\test.mpg"
2012-08-05 16:20:34 Info [x] Multicore support in resize
2012-08-05 16:20:34 Info Project size 4.17 Gb. (1.29 Mb. audio - 4.15 Gb. video)
2012-08-05 16:20:33 Info BURN: No disc in drive.
2012-08-05 16:20:32 Info [ ] Don't fix audio gaps
2012-08-05 16:20:32 Info [ ] Engine Log
2012-08-05 16:20:32 Info [ ] 2-pass encoding
2012-08-05 16:20:32 Info Encoding preset: SP (Short Projects)
2012-08-05 16:20:32 ---- ****************** Encoding begin *******************
2012-08-05 16:20:32 ---- **************** Menu settings end ******************
2012-08-05 16:20:32 Info [x] Don't create title menu for single video
2012-08-05 16:20:32 Info [x] Return to title menu after titleset playback
2012-08-05 16:20:32 Info [x] Skip root menu initially
2012-08-05 16:20:32 Info [ ] Play titles one after the other
2012-08-05 16:20:32 Info [ ] Loop playback
2012-08-05 16:20:32 Info [ ] Auto-start playback
2012-08-05 16:20:32 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2012-08-05 16:20:32 ---- *************** Menu settings begin *****************
2012-08-05 16:20:32 ---- **************** Burn settings end ******************
2012-08-05 16:20:32 Info Default speed selected: 4x
2012-08-05 16:20:32 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-08-05 16:20:32 Info BURN: Drive has Serial ATA physical interface
2012-08-05 16:20:32 Info BURN: New Drive selected : 0:1:0 - hp CDDVDW TS-L633N 0300 [F] (Ide)
2012-08-05 16:20:32 Info [x] Delete DVD folder after burn complete
2012-08-05 16:20:32 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2012-08-05 16:20:32 Info SAO setting: Automatic
2012-08-05 16:20:32 Info [x] Burn result to DVD / as ISO file in working folder
2012-08-05 16:20:32 ---- **************** Burn settings begin ****************
2012-08-05 16:19:31 Info BURN: No disc in drive.
2012-08-05 16:19:29 Info BURN: 1 writer(s) found.
2012-08-05 16:19:29 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\4\vso_hwe.dll" [4.0.17.485]
2012-08-05 16:19:29 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-08-05 16:19:29 Info BURN: Drive has Serial ATA physical interface
2012-08-05 16:19:29 Info BURN: New Drive selected : 0:1:0 - hp CDDVDW TS-L633N 0300 [F] (Ide)
2012-08-05 16:19:29 Info BURN: Using Advanced SPTI interface
2012-08-05 16:19:29 Info Trial version
2012-08-05 16:19:28 Info 37 Menu templates loaded.
2012-08-05 16:19:26 Info Supported instruction set: sse4
2012-08-05 16:19:26 Info Maximum number of threads detected: 4 - parallelize up to 4
2012-08-05 16:19:26 Info Tuning Performances for Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz with 4 core(s) CPU
2012-08-05 16:19:26 Info System default language : English (United States)
2012-08-05 16:19:26 Info User default language : English (United States)
2012-08-05 16:19:26 Info Version : 4.1.19.365
2012-08-05 16:19:26 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\4\ConvertXtoDvd.exe
2012-08-05 16:19:26 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-08-05 16:19:25 ---- ******************** Log session start 2012-08-05 16:19:25.836 PID 4768********************
guy-cynical
Re: Any ideas on where to look for problem?
Postby JJ » Mon Aug 06, 2012 5:54 pm
I have had no such problems with full version.
Actually trial converted fine too, but it adds watermark.
Return to ConvertXtoDVD version 4.x
  • Related topics
    Replies
    Views
    Last post
Who is online
