An error occured while converting. Need Help
srabich42
Post by srabich42 »
I'm french, sorry for my English
I bought for two days DVD converter to convert some dvd to avi format ant iphone 3GS
When the convertion arrive at 11%, it stop and it's written : Error while encoding file.
It's the same when i do a convertion direct from the DVD disc-reader or when i use an image iso of the DVD.
And also for all differents format of output (DVD, AVI Xvid, Iphone)
I need your help fast, i have to use it before next week.
Thanks for your answer
Srabich 42
Re: An error occured while converting. Need Help
Bonsoir srabich42,
Utilisez-vous un programme décrypteur en arrière plan (comme AnyDVD ou DVD decrypter)?
Si non, installez en un...
Si oui, pouvez-vous me donner le nom des films que vous voulez convertir?
Merci et bonne soirée.
