25th Audio discontinuity HELP!!!
discussions about ConvertXtoDVD latest versions, avi to dvd video converter software, burns videos from your PC to watch on your DVD with menus and subtitles.
Moderators: Cougar_II, ckhouston, JJ, Claire, Forum admin
Postby Ninja88 » Fri Feb 20, 2009 10:33 pm
I'm currently converting some stuff...
But each episode is giving me an error message
Error This is the 25th audio discontinuity, turning off report of audio discontinuities
It shows up on each episode!! (o_O)
What effect does this have on the final result? and can it be fixed?
Please help!!
Log below as of now:
2009-02-20 22:28:38 Info Chapter #4 start at 15:0.816
2009-02-20 22:26:17 Info Chapter #3 start at 10:0.016
2009-02-20 22:23:45 Info Chapter #2 start at 5:0.216
2009-02-20 22:23:35 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 22:23:35 Info Stream #2 - Audio sync at 278506.67 ms: 64.00 ms added
2009-02-20 22:23:34 Info Stream #2 - Audio sync at 277717.33 ms: 64.00 ms added
2009-02-20 22:23:34 Info Stream #2 - Audio sync at 277034.67 ms: 64.00 ms added
2009-02-20 22:23:34 Info Stream #2 - Audio sync at 276309.33 ms: 64.00 ms added
2009-02-20 22:23:33 Info Stream #2 - Audio sync at 275562.67 ms: 64.00 ms added
2009-02-20 22:23:33 Info Stream #2 - Audio sync at 274730.67 ms: 64.00 ms added
2009-02-20 22:23:33 Info Stream #2 - Audio sync at 273962.67 ms: 64.00 ms added
2009-02-20 22:23:14 Info Stream #2 - Audio sync at 234901.33 ms: 64.00 ms added
2009-02-20 22:23:14 Info Stream #2 - Audio sync at 234517.33 ms: 64.00 ms added
2009-02-20 22:23:14 Info Stream #2 - Audio sync at 233664.00 ms: 64.00 ms added
2009-02-20 22:23:14 Info Stream #2 - Audio sync at 233365.33 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 233024.00 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 232725.33 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 232384.00 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 232128.00 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 231701.33 ms: 64.00 ms added
2009-02-20 22:23:13 Info Stream #2 - Audio sync at 230912.00 ms: 64.00 ms added
2009-02-20 22:23:12 Info Stream #2 - Audio sync at 230613.33 ms: 64.00 ms added
2009-02-20 22:23:12 Info Stream #2 - Audio sync at 229738.67 ms: 64.00 ms added
2009-02-20 22:23:12 Info Stream #2 - Audio sync at 229333.33 ms: 64.00 ms added
2009-02-20 22:23:12 Info Stream #2 - Audio sync at 228928.00 ms: 64.00 ms added
2009-02-20 22:23:11 Info Stream #2 - Audio sync at 228416.00 ms: 64.00 ms added
2009-02-20 22:23:11 Info Stream #2 - Audio sync at 227562.67 ms: 64.00 ms added
2009-02-20 22:23:10 Info Stream #2 - Audio sync at 225493.33 ms: 64.00 ms added
2009-02-20 22:23:10 Info Stream #2 - Audio sync at 225130.67 ms: 64.00 ms added
2009-02-20 22:23:10 Info Stream #2 - Audio sync at 224832.00 ms: 64.00 ms added
2009-02-20 22:21:11 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 22:21:11 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 22:21:11 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1586 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 22:21:11 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 22:21:11 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 22:21:11 ---- ************ Source file #1 END DETAILS ************
2009-02-20 22:21:11 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 127 kb/s
2009-02-20 22:21:10 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 22:21:10 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 22:21:10 Info E:\Anime\Anime to Burn\Full Metal Panic\06 Still Alive.avi
2009-02-20 22:21:10 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 22:21:10 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 22:21:10 Info Video bitrate 0/1586/9608 Kbps (min/avg/max)
2009-02-20 22:21:10 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 22:21:10 ---- ======================= TITLESET #6 =======================
2009-02-20 22:21:10 Info Generated duration 1468.19 sec., expected 1469.67 sec.
2009-02-20 22:18:37 Info 297 frames duplicated
2009-02-20 22:17:24 Info Chapter #5 start at 19:59.998
2009-02-20 22:15:14 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 22:15:14 Info Stream #2 - Audio sync at 917184.00 ms: 64.00 ms added
2009-02-20 22:15:13 Info Stream #2 - Audio sync at 914261.33 ms: 64.00 ms added
2009-02-20 22:15:10 Info Stream #2 - Audio sync at 906709.33 ms: 64.00 ms added
2009-02-20 22:15:07 Info Chapter #4 start at 15:0.199
2009-02-20 22:12:43 Info Chapter #3 start at 10:0.266
2009-02-20 22:10:42 Info Stream #2 - Audio sync at 316096.00 ms: 64.00 ms added
2009-02-20 22:10:34 Info Chapter #2 start at 5:0.216
2009-02-20 22:10:08 Info Stream #2 - Audio sync at 237824.00 ms: 64.00 ms added
2009-02-20 22:10:08 Info Stream #2 - Audio sync at 237376.00 ms: 85.33 ms added
2009-02-20 22:10:07 Info Stream #2 - Audio sync at 237077.33 ms: 64.00 ms added
2009-02-20 22:10:07 Info Stream #2 - Audio sync at 236800.00 ms: 64.00 ms added
2009-02-20 22:10:07 Info Stream #2 - Audio sync at 236650.67 ms: 64.00 ms added
2009-02-20 22:10:06 Info Stream #2 - Audio sync at 234730.67 ms: 64.00 ms added
2009-02-20 22:10:05 Info Stream #2 - Audio sync at 232298.67 ms: 64.00 ms added
2009-02-20 22:10:04 Info Stream #2 - Audio sync at 230229.33 ms: 64.00 ms added
2009-02-20 22:10:04 Info Stream #2 - Audio sync at 229909.33 ms: 64.00 ms added
2009-02-20 22:10:04 Info Stream #2 - Audio sync at 229568.00 ms: 64.00 ms added
2009-02-20 22:10:04 Info Stream #2 - Audio sync at 229098.67 ms: 64.00 ms added
2009-02-20 22:10:01 Info Stream #2 - Audio sync at 222080.00 ms: 64.00 ms added
2009-02-20 22:10:00 Info Stream #2 - Audio sync at 220458.67 ms: 64.00 ms added
2009-02-20 22:10:00 Info Stream #2 - Audio sync at 220096.00 ms: 64.00 ms added
2009-02-20 22:09:58 Info Stream #2 - Audio sync at 215018.67 ms: 64.00 ms added
2009-02-20 22:09:57 Info Stream #2 - Audio sync at 212224.00 ms: 64.00 ms added
2009-02-20 22:09:52 Info Stream #2 - Audio sync at 200938.67 ms: 64.00 ms added
2009-02-20 22:09:52 Info Stream #2 - Audio sync at 200576.00 ms: 64.00 ms added
2009-02-20 22:09:52 Info Stream #2 - Audio sync at 200149.33 ms: 64.00 ms added
2009-02-20 22:09:52 Info Stream #2 - Audio sync at 199786.67 ms: 64.00 ms added
2009-02-20 22:09:52 Info Stream #2 - Audio sync at 199402.67 ms: 64.00 ms added
2009-02-20 22:09:51 Info Stream #2 - Audio sync at 199040.00 ms: 64.00 ms added
2009-02-20 22:08:14 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 22:08:14 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 22:08:14 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1583 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 22:08:14 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 22:08:14 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 22:08:14 ---- ************ Source file #1 END DETAILS ************
2009-02-20 22:08:14 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 126 kb/s
2009-02-20 22:08:14 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 22:08:14 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 22:08:14 Info E:\Anime\Anime to Burn\Full Metal Panic\05 Whispered.avi
2009-02-20 22:08:14 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 22:08:14 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 22:08:14 Info Video bitrate 0/1583/9608 Kbps (min/avg/max)
2009-02-20 22:08:14 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 22:08:14 ---- ======================= TITLESET #5 =======================
2009-02-20 22:08:14 Info Generated duration 1523.57 sec., expected 1529.06 sec.
2009-02-20 22:05:50 Info 1570 frames duplicated
2009-02-20 22:04:28 Info Chapter #5 start at 20:0.249
2009-02-20 22:04:24 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 22:04:24 Info Stream #2 - Audio sync at 1187818.67 ms: 64.00 ms added
2009-02-20 22:04:23 Info Stream #2 - Audio sync at 1185941.33 ms: 64.00 ms added
2009-02-20 22:04:23 Info Stream #2 - Audio sync at 1185621.33 ms: 64.00 ms added
2009-02-20 22:04:22 Info Stream #2 - Audio sync at 1185280.00 ms: 64.00 ms added
2009-02-20 22:04:22 Info Stream #2 - Audio sync at 1184917.33 ms: 64.00 ms added
2009-02-20 22:04:22 Info Stream #2 - Audio sync at 1184597.33 ms: 64.00 ms added
2009-02-20 22:04:22 Info Stream #2 - Audio sync at 1184234.67 ms: 64.00 ms added
2009-02-20 22:04:21 Info Stream #2 - Audio sync at 1182101.33 ms: 64.00 ms added
2009-02-20 22:04:21 Info Stream #2 - Audio sync at 1181802.67 ms: 64.00 ms added
2009-02-20 22:04:21 Info Stream #2 - Audio sync at 1181418.67 ms: 64.00 ms added
2009-02-20 22:04:20 Info Stream #2 - Audio sync at 1180864.00 ms: 64.00 ms added
2009-02-20 22:04:20 Info Stream #2 - Audio sync at 1180480.00 ms: 64.00 ms added
2009-02-20 22:04:20 Info Stream #2 - Audio sync at 1180160.00 ms: 64.00 ms added
2009-02-20 22:04:20 Info Stream #2 - Audio sync at 1179861.33 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1178645.33 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1177792.00 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1177493.33 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1177152.00 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1176789.33 ms: 64.00 ms added
2009-02-20 22:04:19 Info Stream #2 - Audio sync at 1176469.33 ms: 64.00 ms added
2009-02-20 22:04:18 Info Stream #2 - Audio sync at 1175424.00 ms: 64.00 ms added
2009-02-20 22:04:18 Info Stream #2 - Audio sync at 1175125.33 ms: 64.00 ms added
2009-02-20 22:04:18 Info Stream #2 - Audio sync at 1174805.33 ms: 64.00 ms added
2009-02-20 22:04:18 Info Stream #2 - Audio sync at 1174314.67 ms: 64.00 ms added
2009-02-20 22:04:17 Info Stream #2 - Audio sync at 1173504.00 ms: 64.00 ms added
2009-02-20 22:04:17 Info Stream #2 - Audio sync at 1173226.67 ms: 64.00 ms added
2009-02-20 22:02:18 Info Chapter #4 start at 15:0.316
2009-02-20 22:00:12 Info Chapter #3 start at 10:0.399
2009-02-20 21:58:03 Info Chapter #2 start at 5:0.099
2009-02-20 21:55:36 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 21:55:36 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 21:55:36 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1575 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 21:55:36 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 21:55:36 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 21:55:36 ---- ************ Source file #1 END DETAILS ************
2009-02-20 21:55:36 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 125 kb/s
2009-02-20 21:55:36 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 21:55:36 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 21:55:36 Info E:\Anime\Anime to Burn\Full Metal Panic\04 Kidnap.avi
2009-02-20 21:55:36 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 21:55:36 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 21:55:36 Info Video bitrate 0/1575/9608 Kbps (min/avg/max)
2009-02-20 21:55:36 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 21:55:36 ---- ======================= TITLESET #4 =======================
2009-02-20 21:55:36 Info Generated duration 1484.14 sec., expected 1484.77 sec.
2009-02-20 21:53:15 Info 626 frames duplicated
2009-02-20 21:52:02 Info Chapter #5 start at 19:59.998
2009-02-20 21:49:55 Info Chapter #4 start at 15:0.449
2009-02-20 21:47:51 Info Chapter #3 start at 10:0.149
2009-02-20 21:45:36 Info Chapter #2 start at 4:59.966
2009-02-20 21:43:36 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 21:43:36 Info Stream #2 - Audio sync at 42837.33 ms: 64.00 ms added
2009-02-20 21:43:36 Info Stream #2 - Audio sync at 42282.67 ms: 64.00 ms added
2009-02-20 21:43:36 Info Stream #2 - Audio sync at 41962.67 ms: 64.00 ms added
2009-02-20 21:43:36 Info Stream #2 - Audio sync at 41621.33 ms: 64.00 ms added
2009-02-20 21:43:36 Info Stream #2 - Audio sync at 41152.00 ms: 64.00 ms added
2009-02-20 21:43:35 Info Stream #2 - Audio sync at 39594.67 ms: 64.00 ms added
2009-02-20 21:43:34 Info Stream #2 - Audio sync at 38229.33 ms: 64.00 ms added
2009-02-20 21:43:34 Info Stream #2 - Audio sync at 37674.67 ms: 64.00 ms added
2009-02-20 21:43:33 Info Stream #2 - Audio sync at 36693.33 ms: 64.00 ms added
2009-02-20 21:43:33 Info Stream #2 - Audio sync at 36096.00 ms: 85.34 ms added
2009-02-20 21:43:32 Info Stream #2 - Audio sync at 35242.67 ms: 64.00 ms added
2009-02-20 21:43:32 Info Stream #2 - Audio sync at 34624.00 ms: 64.00 ms added
2009-02-20 21:43:32 Info Stream #2 - Audio sync at 34517.33 ms: 64.00 ms added
2009-02-20 21:43:32 Info Stream #2 - Audio sync at 33749.33 ms: 85.33 ms added
2009-02-20 21:43:31 Info Stream #2 - Audio sync at 32533.33 ms: 64.00 ms added
2009-02-20 21:43:30 Info Stream #2 - Audio sync at 31936.00 ms: 64.00 ms added
2009-02-20 21:43:30 Info Stream #2 - Audio sync at 31765.33 ms: 64.00 ms added
2009-02-20 21:43:30 Info Stream #2 - Audio sync at 31338.67 ms: 85.33 ms added
2009-02-20 21:43:28 Info Stream #2 - Audio sync at 28010.67 ms: 64.00 ms added
2009-02-20 21:43:26 Info Stream #2 - Audio sync at 24234.67 ms: 64.00 ms added
2009-02-20 21:43:26 Info Stream #2 - Audio sync at 23637.33 ms: 64.00 ms added
2009-02-20 21:43:26 Info Stream #2 - Audio sync at 23360.00 ms: 64.00 ms added
2009-02-20 21:43:22 Info Stream #2 - Audio sync at 16533.33 ms: 64.00 ms added
2009-02-20 21:43:22 Info Stream #2 - Audio sync at 16384.00 ms: 64.00 ms added
2009-02-20 21:43:20 Info Stream #2 - Audio sync at 12288.00 ms: 64.00 ms added
2009-02-20 21:43:18 Info Stream #2 - Audio sync at 8362.67 ms: 64.00 ms added
2009-02-20 21:43:15 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 21:43:15 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 21:43:15 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1572 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 21:43:15 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 21:43:15 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 21:43:15 ---- ************ Source file #1 END DETAILS ************
2009-02-20 21:43:15 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 118 kb/s
2009-02-20 21:43:15 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 21:43:15 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 21:43:15 Info E:\Anime\Anime to Burn\Full Metal Panic\03 Lingerie Panic.avi
2009-02-20 21:43:15 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 21:43:15 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 21:43:15 Info Video bitrate 0/1572/9608 Kbps (min/avg/max)
2009-02-20 21:43:15 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 21:43:15 ---- ======================= TITLESET #3 =======================
2009-02-20 21:43:14 Info Generated duration 1515.57 sec., expected 1517.55 sec.
2009-02-20 21:40:51 Info 1372 frames duplicated
2009-02-20 21:39:28 Info Chapter #5 start at 20:0.365
2009-02-20 21:37:20 Info Chapter #4 start at 15:0.316
2009-02-20 21:34:56 Info Chapter #3 start at 10:0.399
2009-02-20 21:32:45 Info Chapter #2 start at 5:0.350
2009-02-20 21:30:58 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 21:30:58 Info Stream #2 - Audio sync at 76074.67 ms: 64.00 ms added
2009-02-20 21:30:51 Info Stream #2 - Audio sync at 64277.33 ms: 64.00 ms added
2009-02-20 21:30:51 Info Stream #2 - Audio sync at 63957.33 ms: 64.00 ms added
2009-02-20 21:30:47 Info Stream #2 - Audio sync at 56682.67 ms: 64.00 ms added
2009-02-20 21:30:47 Info Stream #2 - Audio sync at 56426.67 ms: 64.00 ms added
2009-02-20 21:30:43 Info Stream #2 - Audio sync at 49514.67 ms: 64.00 ms added
2009-02-20 21:30:43 Info Stream #2 - Audio sync at 49194.67 ms: 85.33 ms added
2009-02-20 21:30:43 Info Stream #2 - Audio sync at 48682.67 ms: 64.00 ms added
2009-02-20 21:30:42 Info Stream #2 - Audio sync at 47722.67 ms: 64.00 ms added
2009-02-20 21:30:41 Info Stream #2 - Audio sync at 44672.00 ms: 64.00 ms added
2009-02-20 21:30:40 Info Stream #2 - Audio sync at 43797.33 ms: 85.33 ms added
2009-02-20 21:30:40 Info Stream #2 - Audio sync at 43242.67 ms: 64.00 ms added
2009-02-20 21:30:40 Info Stream #2 - Audio sync at 42474.67 ms: 64.00 ms added
2009-02-20 21:30:39 Info Stream #2 - Audio sync at 41493.33 ms: 64.00 ms added
2009-02-20 21:30:39 Info Stream #2 - Audio sync at 41173.33 ms: 64.00 ms added
2009-02-20 21:30:39 Info Stream #2 - Audio sync at 40853.33 ms: 64.00 ms added
2009-02-20 21:30:39 Info Stream #2 - Audio sync at 40362.67 ms: 64.00 ms added
2009-02-20 21:30:38 Info Stream #2 - Audio sync at 38421.33 ms: 64.00 ms added
2009-02-20 21:30:37 Info Stream #2 - Audio sync at 36949.33 ms: 64.00 ms added
2009-02-20 21:30:36 Info Stream #2 - Audio sync at 35690.67 ms: 64.00 ms added
2009-02-20 21:30:36 Info Stream #2 - Audio sync at 34474.67 ms: 64.00 ms added
2009-02-20 21:30:35 Info Stream #2 - Audio sync at 33920.00 ms: 64.00 ms added
2009-02-20 21:30:35 Info Stream #2 - Audio sync at 32469.33 ms: 64.00 ms added
2009-02-20 21:30:34 Info Stream #2 - Audio sync at 31402.67 ms: 85.33 ms added
2009-02-20 21:30:34 Info Stream #2 - Audio sync at 31146.67 ms: 64.00 ms added
2009-02-20 21:30:34 Info Stream #2 - Audio sync at 30848.00 ms: 64.00 ms added
2009-02-20 21:30:18 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 21:30:18 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 21:30:18 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1568 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 21:30:18 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 21:30:18 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 21:30:18 ---- ************ Source file #1 END DETAILS ************
2009-02-20 21:30:18 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 121 kb/s
2009-02-20 21:30:18 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 21:30:18 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 21:30:18 Info E:\Anime\Anime to Burn\Full Metal Panic\02 I Want to Protect You.avi
2009-02-20 21:30:18 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 21:30:18 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 21:30:18 Info Video bitrate 0/1568/9608 Kbps (min/avg/max)
2009-02-20 21:30:18 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 21:30:18 ---- ======================= TITLESET #2 =======================
2009-02-20 21:30:18 Info Generated duration 1518.07 sec., expected 1518.26 sec.
2009-02-20 21:27:56 Info 1430 frames duplicated
2009-02-20 21:26:34 Info Chapter #5 start at 20:0.365
2009-02-20 21:24:25 Info Chapter #4 start at 15:0.065
2009-02-20 21:22:06 Info Chapter #3 start at 10:0.149
2009-02-20 21:19:54 Info Chapter #2 start at 5:0.216
2009-02-20 21:19:21 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
2009-02-20 21:19:21 Info Stream #2 - Audio sync at 239808.00 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 239573.33 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 239232.00 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 238912.00 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 238634.67 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 238378.67 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 238080.00 ms: 64.00 ms added
2009-02-20 21:19:20 Info Stream #2 - Audio sync at 237781.33 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 237461.33 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 237141.33 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 236864.00 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 236565.33 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 236309.33 ms: 64.00 ms added
2009-02-20 21:19:19 Info Stream #2 - Audio sync at 236010.67 ms: 64.00 ms added
2009-02-20 21:19:18 Info Stream #2 - Audio sync at 235690.67 ms: 64.00 ms added
2009-02-20 21:19:18 Info Stream #2 - Audio sync at 235392.00 ms: 64.00 ms added
2009-02-20 21:17:39 Info Stream #2 - Audio sync at 48512.00 ms: 85.33 ms added
2009-02-20 21:17:39 Info Stream #2 - Audio sync at 47978.67 ms: 64.00 ms added
2009-02-20 21:17:37 Info Stream #2 - Audio sync at 43946.67 ms: 64.00 ms added
2009-02-20 21:17:36 Info Stream #2 - Audio sync at 42965.33 ms: 64.00 ms added
2009-02-20 21:17:36 Info Stream #2 - Audio sync at 42389.33 ms: 64.00 ms added
2009-02-20 21:17:36 Info Stream #2 - Audio sync at 41152.00 ms: 64.00 ms added
2009-02-20 21:17:35 Info Stream #2 - Audio sync at 40640.00 ms: 64.00 ms added
2009-02-20 21:17:35 Info Stream #2 - Audio sync at 40320.00 ms: 64.00 ms added
2009-02-20 21:17:16 Info Stream #2 - Audio sync at 874.67 ms: 64.00 ms added
2009-02-20 21:17:16 Info Stream #2 - Audio sync at 384.00 ms: 64.00 ms added
2009-02-20 21:17:15 Info Audio settings: Automatic With DTS -> AC-3 conversion
2009-02-20 21:17:15 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
2009-02-20 21:17:15 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 1001/24000, q=2-31, 1565 kb/s, pulldown: 23.976 -> 29.97 Fps
2009-02-20 21:17:15 Info Video processing: Fast bilinear resampler (640*480)->(720*480)
2009-02-20 21:17:15 Info Chapter sequences require 46.4 Mb. temp space
2009-02-20 21:17:15 ---- ************ Source file #1 END DETAILS ************
2009-02-20 21:17:15 Info AUDIO Stream #2 : Audio: AAC, 48000 Hz, stereo, s16, 124 kb/s
2009-02-20 21:17:15 Info VIDEO Stream #1 : Video: wmv3, yuv420p, 640x480, 417083/10000000, 23.98 FPS
2009-02-20 21:17:15 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2009-02-20 21:17:15 Info E:\Anime\Anime to Burn\Full Metal Panic\01 The Guy I Kinda Like is a Sergeant.avi
2009-02-20 21:17:15 ---- *********** Source file #1 BEGIN DETAILS ***********
2009-02-20 21:17:15 Info Video bitrate has been set to maximum possible value for DVD specifications. Target size may not be reached.
2009-02-20 21:17:15 Info Video bitrate 0/1565/9608 Kbps (min/avg/max)
2009-02-20 21:17:15 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
2009-02-20 21:17:15 ---- ======================= TITLESET #1 =======================
2009-02-20 21:17:15 Info 2 Stream(s) found - est. duration 00:22:48.661, reference 00:22:48.661
2009-02-20 21:17:15 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\24 Into the Blue.avi"
2009-02-20 21:17:08 Info 2 Stream(s) found - est. duration 00:24:21.120, reference 00:24:21.120
2009-02-20 21:17:08 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\23 Field of Giants.avi"
2009-02-20 21:17:01 Info 2 Stream(s) found - est. duration 00:22:49.242, reference 00:22:49.242
2009-02-20 21:17:01 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\22 Jack in the Box.avi"
2009-02-20 21:16:54 Info 2 Stream(s) found - est. duration 00:22:49.409, reference 00:22:49.409
2009-02-20 21:16:54 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\21 Deep Trap.avi"
2009-02-20 21:16:47 Info 2 Stream(s) found - est. duration 00:22:49.283, reference 00:22:49.283
2009-02-20 21:16:47 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\20 Venom's Flame.avi"
2009-02-20 21:16:41 Info 2 Stream(s) found - est. duration 00:24:17.493, reference 00:24:17.493
2009-02-20 21:16:41 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\19 Engaging Six and Seven.avi"
2009-02-20 21:16:34 Info 2 Stream(s) found - est. duration 00:22:49.242, reference 00:22:49.242
2009-02-20 21:16:34 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\18 Deep Sea Party.avi"
2009-02-20 21:16:27 Info 2 Stream(s) found - est. duration 00:22:49.409, reference 00:22:49.409
2009-02-20 21:16:27 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\17 The Rising Wind In The Homeland, Part 3.avi"
2009-02-20 21:16:20 Info 2 Stream(s) found - est. duration 00:24:19.755, reference 00:24:19.755
2009-02-20 21:16:20 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\16 The Rising Wind In The Homeland, Part 2.avi"
2009-02-20 21:16:14 Info 2 Stream(s) found - est. duration 00:24:17.749, reference 00:24:17.749
2009-02-20 21:16:14 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\15 The Rising Wind In The Homeland, Part 1.avi"
2009-02-20 21:16:06 Info 2 Stream(s) found - est. duration 00:24:17.557, reference 00:24:17.557
2009-02-20 21:16:06 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\14 Is Narashino Burning.avi"
2009-02-20 21:16:00 Info 2 Stream(s) found - est. duration 00:22:49.242, reference 00:22:49.242
2009-02-20 21:16:00 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\13 A Cat and a Kitten's Rock & Roll.avi"
2009-02-20 21:15:55 Info 2 Stream(s) found - est. duration 00:22:49.242, reference 00:22:49.242
2009-02-20 21:15:55 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\12 One Night Stand.avi"
2009-02-20 21:15:50 Info 2 Stream(s) found - est. duration 00:24:21.803, reference 00:24:21.803
2009-02-20 21:15:50 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\11 Behemoth Awakening.avi"
2009-02-20 21:15:45 Info 2 Stream(s) found - est. duration 00:24:21.205, reference 00:24:21.205
2009-02-20 21:15:45 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\10 Run Running Run.avi"
2009-02-20 21:15:40 Info 2 Stream(s) found - est. duration 00:22:49.242, reference 00:22:49.242
2009-02-20 21:15:40 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\09 Dangerous Safe House.avi"
2009-02-20 21:15:34 Info 2 Stream(s) found - est. duration 00:21:54.729, reference 00:21:54.729
2009-02-20 21:15:34 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\08 Part-Time Steady.avi"
2009-02-20 21:15:29 Info 2 Stream(s) found - est. duration 00:23:22.900, reference 00:23:22.900
2009-02-20 21:15:29 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\07 Boy Meets Girl.avi"
2009-02-20 21:15:24 Info 2 Stream(s) found - est. duration 00:23:33.578, reference 00:23:33.578
2009-02-20 21:15:24 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\06 Still Alive.avi"
2009-02-20 21:15:19 Info 2 Stream(s) found - est. duration 00:22:59.669, reference 00:22:59.669
2009-02-20 21:15:19 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\05 Whispered.avi"
2009-02-20 21:15:14 Info 2 Stream(s) found - est. duration 00:23:59.061, reference 00:23:59.061
2009-02-20 21:15:14 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\04 Kidnap.avi"
2009-02-20 21:15:09 Info 2 Stream(s) found - est. duration 00:23:14.767, reference 00:23:14.767
2009-02-20 21:15:09 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\03 Lingerie Panic.avi"
2009-02-20 21:15:03 Info 2 Stream(s) found - est. duration 00:23:47.550, reference 00:23:47.550
2009-02-20 21:15:03 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\02 I Want to Protect You.avi"
2009-02-20 21:14:58 Info 2 Stream(s) found - est. duration 00:23:48.259, reference 00:23:48.259
2009-02-20 21:14:58 Info Opening file "E:\Anime\Anime to Burn\Full Metal Panic\01 The Guy I Kinda Like is a Sergeant.avi"
2009-02-20 21:14:53 Info Project size 7.69 Gb. (786 Mb. audio - 6.9 Gb. video)
2009-02-20 21:14:53 Info [ ] Don't fix audio gaps
2009-02-20 21:14:53 Info [ ] Engine Log
2009-02-20 21:14:53 Info Encoding quality: Medium
2009-02-20 21:14:53 ---- ****************** Encoding begin *******************
2009-02-20 21:14:53 ---- **************** Menu settings end ******************
2009-02-20 21:14:53 Info [x] Don't create title menu for single video
2009-02-20 21:14:53 Info [x] Return to title menu after titleset playback
2009-02-20 21:14:53 Info [x] Skip root menu initially
2009-02-20 21:14:53 Info [ ] Play titles one after the other
2009-02-20 21:14:53 Info [ ] Loop playback
2009-02-20 21:14:53 Info [ ] Auto-start playback
2009-02-20 21:14:53 Info Template: VSO glossy template, clear background, up to 4 episodes/titles per page, contains 4 page(s), 17 customizable element(s)
2009-02-20 21:14:53 ---- *************** Menu settings begin *****************
2009-02-20 21:14:53 ---- **************** Burn settings end ******************
2009-02-20 21:14:53 Info Default speed selected: 1x
2009-02-20 21:14:53 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
2009-02-20 21:14:53 Info BURN: Drive has IDE-ATAPI physical interface
2009-02-20 21:14:53 Info BURN: New Drive selected : 0:1:0 - _NEC DVD_RW ND-3500AG 2.1B [H] (Ide)
2009-02-20 21:14:53 Info [ ] Delete DVD folder after burn complete
2009-02-20 21:14:53 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2009-02-20 21:14:53 Info SAO setting: Automatic
2009-02-20 21:14:53 Info [ ] Add original files to DVD (if possible)
2009-02-20 21:14:53 Info [x] Burn result to DVD
2009-02-20 21:14:53 ---- **************** Burn settings begin ****************
2009-02-20 21:14:41 Info Project "E:\Anime\Anime to Burn\Full Metal Panic\Full Metal Panic.XtoDVD" saved.
2009-02-20 21:13:42 Info Project "E:\Anime\Anime to Burn\Full Metal Panic\Full Metal Panic.XtoDVD" saved.
2009-02-20 20:46:52 Info Project "E:\Anime\Anime to Burn\Full Metal Panic\Full Metal Panic.XtoDVD" saved.
2009-02-20 20:34:53 Info Project "E:\Anime\Anime to Burn\Full Metal Panic\Full Metal Panic.XtoDVD" saved.
2009-02-20 19:59:54 Info 34 Menu templates loaded.
2009-02-20 19:59:48 Info BURN: 1 writer(s) found.
2009-02-20 19:59:48 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\3\vso_hwe.dll" [3.2.4.406]
2009-02-20 19:59:48 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
2009-02-20 19:59:48 Info BURN: Drive has IDE-ATAPI physical interface
2009-02-20 19:59:48 Info BURN: New Drive selected : 0:1:0 - _NEC DVD_RW ND-3500AG 2.1B [H] (Ide)
2009-02-20 19:59:48 Info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2009-02-20 19:59:47 Info Supported instruction set: 3DNow
2009-02-20 19:59:47 Info Tuning Performances for AMD Athlon(tm) 64 Processor 2800+ with 1 core(s) CPU
2009-02-20 19:59:47 Info System default language : English (United States)
2009-02-20 19:59:47 Info User default language : English (United Kingdom)
2009-02-20 19:59:47 Info Version : 3.3.4.106
2009-02-20 19:59:47 Info ExeName : C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe
2009-02-20 19:59:47 Info OS : Microsoft Windows XP Professional (build 2600) with Service Pack 3 5.1
2009-02-20 19:59:39 ---- ******************** Log session start 2009-02-20 19:59:39.906 PID 3724********************
Ninja88
Postby DeathNya » Fri Feb 20, 2009 10:40 pm
I saw somewhere in the forum that turning off "Conversion DTS->AC3" solves the problem.
DeathNya
Postby Ninja88 » Fri Feb 20, 2009 10:47 pm
Hmmm.. I quickly glance through that one... It doesn't make sense to me and I don't even know where to change that.. (>_<) I'm rubbish on computers ! (o_O)
I've not had a problem with converting files previously and the setting I have used remained the same as before.
I was wondering whether it will still be ok and that my audio will not be out of sync, as the conversion still continues despite the error.
So far from my experience, if there is an error the conversion stops.
Ninja88
Postby JoeB » Fri Feb 20, 2009 10:56 pm
Ninja88 wrote:Hmmm.. I quickly glance through that one... It doesn't make sense to me and I don't even know where to change that.. (>_<) I'm rubbish on computers ! (o_O)
Try unchecking the option in Settings to Check for audio discontinuities (or something like that - I can't be more specific 'cause I'm converting and can't get at the Settings). Also uncheck the option to Burn after completion. Then when the conversion is finished play it in a software player and see if things are fine.
JoeB
JoeB
Postby hansK » Fri Feb 20, 2009 10:57 pm
Hi Ninja88,
This is just to tell you that it stops reporting/writing down this info on adding audio sync, otherwise it will fill it for kilometers till it finishes this titleset conversion.
You have to see what the result is after conversion project if it did harm .
You can try to check [X] do not fix audio discontinuities at Audio tab (if this file was recorded from TV).
hansK
_________________________________________________________________________
FILL IN, in your Profile, your LOCATION (country) for even better/quicker help. It gives us( forum helpers) the info
about used local TV format and when a reply can be expected(time zone, when you are awake/available and sleep).
Location will then show up under your forum name.(my Location shows Netherlands)
Where to edit : Go to top of this forum page, 3rd line, 3rd (middle) option (Profile).
hansK
Postby Ninja88 » Fri Feb 20, 2009 11:04 pm
With regard to the earlier post, it's already on DTS > AC3 in the settings.
With regards to 'do not fix audio discontinuities' this may seem like a silly question, but what would the implications if I select this option?
I've never had this problem before without selecting it.
I've had a really bad experience with audio out of sync and not finding out until 6 hours have pass to convert and burn and a disc has been wasted ! (>_<)Verbatim are expensive here (~_~)
Ninja88
Postby Ninja88 » Fri Feb 20, 2009 11:08 pm
hansK wrote:You have to see what the result is after conversion project if it did harm .
(>_<) I guess I will just have to wait! fingers crossed!!
I'll let you know if it was ok in the end... or not ok.. (o_O)
Ninja88
Postby hansK » Fri Feb 20, 2009 11:15 pm
Hi Ninja88,
Recordings from TV could have audio discontinuities in it.
They will not be fixed when checked when converting, causing this add of time in the audio stream.
You do not need to burn to dvd to find out if a sync problem exist.
Just uncheck burn to dvd at burning tab and play converted IFO file with software player on your PC
BTW i can't find "here".
hansK
hansK
Postby Ninja88 » Fri Feb 20, 2009 11:26 pm
Cool I'll test that out. I didn't know you could do that (>_<)
Oh 'here' as in UK.. (^_^)
Thank you!!! (0_<)
Ninja88
Postby hansK » Fri Feb 20, 2009 11:33 pm
Hi Ninja88,
Read/download maual from VSO website.
Oh 'here' as in UK
Fill that then in at your location.
regards,
hansK
hansK
Postby Ninja88 » Fri Feb 20, 2009 11:33 pm
Oh one more question.... a silly one too.. what software player should I use?
Would I be able to use media player?
Ninja88
Postby hansK » Fri Feb 20, 2009 11:46 pm
Hi Ninja88,
VLC, PowerDVD, Classic Media Player(k-lite codec pack),windows media player, as long it can play the VIDEO_TS.IFO file in the VIDEO_TS folder (created in the working folder after conversion, see General tab)
You know what expencive is ?
Buy cheap DVD media and throw more as half of them away, not taking in account the time what was involved with it to burn it a second time and that it does annoy you.
I have done 400 burns with Taiyo Yuden / Verbatim without a single coaster.
hansK
hansK
Postby Ninja88 » Sat Feb 21, 2009 12:00 am
hansK wrote:VLC, PowerDVD, Classic Media Player(k-lite codec pack),windows media player, as long it can play the VIDEO_TS.IFO file in the VIDEO_TS folder (created in the working folder after conversion, see General tab)
I have powerDVD I can test it there.
You are right (^_^) I wouldn't buy cheap discs... I've always use verbatim dual layer at that too... I only have loads of coasters because of out of sync audio... and all because I didn't know the converted file could be played before burning. (O_o) lol
Well hope this turns out ok. Have a good night !
(^_^)
(^_^)
Ninja88
Postby Ninja88 » Sat Feb 21, 2009 11:09 am
Well I couldn't test the converted file because none of my software could play that format.
I burned the converted project on disc anyways in hope that it would work.
Unfortunately, each addition to fix the audio discontinuity has caused the audio to be out of sync with the picture....
So if you ever get that message just be warned that your audio will be out.
(>_<)
Now I have to do it all over again.
Thanks anyway! (^_^)
(^_^)
Ninja88
Postby JJ » Sat Feb 21, 2009 12:08 pm
Did you try PowerDVD?
If it can not play converted result (open dvd-files) then something is badly wrong.
Re: 25th Audio discontinuity HELP!!!
Postby deksta » Sun Aug 04, 2013 3:47 am
Just for the record - if you want to burn to DVD to see results without wasting discs, I find using DVD-RW (Rewritable) discs very useful. Imation brand has been the best for me. And Convertx has no problem with them.
I use them if I don't want to sit at the computer and they can be used over and over again.
deksta
Return to ConvertXtoDVD old version 3.x
  • Related topics
    Replies
    Views
    Last post
Who is online
Users browsing this forum: No registered users and 1 guest
